Gusthebus
Everything posted by Gusthebus
  1. They have done very well so far. Most of my mileage is on streets...varying from some highway, in town and back country roads. They perform well on all surfaces. A little tire hum but nothing excessive. They out performed my expectations in the snow. I tried to make this thing slide on blacktop with 2" of wet snow and it acted like the snow was sticky! Deeper snow wasn't an issue either. I'm guessing that doesn't concern you being in Jax though. With my rig being 2WD I don't push the limits much when it comes to off-road. Mostly trail and camp roads. That said traction isn't a problem. The treads clean out well and don't tend to pack unless you get into clay( careful around Middleburg). I don't have any up here so no idea how they'll handle the sugar sand. I didn't have these tires when I lived out at Jax Beach.
  2. New wheels and tire carrier. No more wheel spacers!
  3. UPDATE After fighting with a persistent wheel bearing issue I decided to eliminate the wheel spacers to reduce stress on the front geometry. Went with the Vision HD 84 D Window wheels. 16x8 4.00 backspace works perfectly with the 265/75R16 Falken tires. Good stance, all the clearance and no rub! I opted to get a 5th rim and tire to have a spare that matches the rest...which lead to a need to get a new spare location. Introduce the Rola and a ratchet strap. The rack and tire mounts are both temporary. this weekend I'm gonna low-pro mount the rack and try to fab a solid tire mount(can't see spending $100 for a prefabed mount).
  4. Thanks for the confirmation! I agree about the stance width. That's partially why I'm replacing the wheels...the current track width is causing some rub in the rear of the wheel well. Wheels got delivered already today. Hopefully I can get them mounted up this weekend. Pics pending...
  5. HI FOLKS Let me start by apologizing for potentially beating a dead horse. I've tried searching for days and can't seem to find a definitive measurement on backspacing for factory 16" "5 star" style wheels. I am currently running Falken Wildpeak 265/75/16's with 1.5" wheel spacers. I am looking to buy the Vision HD 84 series wheels in 16x8. They have a 4" backspacing. I just need to verify the 4" backspacing will accommodate enough clearance for the strut tower without using spacers. I see a ton of recomendations for 3.75" backspacing working well for similar set-ups, not sure if the .25" difference would cause any issues. Any advice or experiences are much appreciated! Falken Wildpeak AT3W All Terrain Radial Tire - 265/75R16 116T
  6. That tire should clear the strut. Might be close but it should be fine. Like previously stated you're probably encountering rub on the inner fender. If that is the case the spacers will most likely make the rub worse.you can easily move the mounting screws forward on your bumper cover to gain a lot of clearance. If still needed a heat gun works wonders. I would think that should be enough to solve your dilemma. If not you might need to send Fleury some $ and get some lift spacers.
  7. It makes sense the more I think about it. Just didn't seem right initially.
  8. I'll start by apologizing up front. I'm sure this has been covered but I can't for the life of me find any torque specs for the front spindle nut. I'm doing wheel bearings on my 2000 2wd. FSM I downloaded tells me to torque to 78ft. Lbs. Then back off to 0. Then re-torque to 13 INCH lbs. This does not sound right to me. Any help would be fantastic!
  9. Yeah I got an wedged in. Wasn't too bad. 1.5" wheel spacers gave me more strut clearance than I needed but I like the stance they provide. 2.5" front/2" rear, stock spring replacements (moog). BILSTEIN 5100's on the rear. Had to do some trimming of the bumper and relocated the inner fender wells. Good enough for an old 2 wheel drive.
  10. Any idea where? I can't seem to find any other info on the webs.
  11. My heat hasn't been working as well as I would like on these colder days. I found this thread and thought I had solved the mystery.After removing the glove box I found that my Pathy didn't even have cabin air filters or the resistor pack. I can see the cut outs where they would be if they had actually installed them. I did cut out the slot and installed the cabin air filters. But how in the wild world of Nissans do I have a multiple speed fan if I don't have the resistor pack to control it??? I'm confused! Anybody else have this set up?
  12. https://www.amazon.com/dp/B0002BG6B4/ref=cm_sw_r_other_apa_DLvYybK0JKRKG
  13. As far as I know everything is stock. The previous owner was the original buyer, and he didn't change anything. Even took it to the Nissan dealership for oil changes. I've only used it for kayaks and a canoe. Held up fine for light stuff. I'll be eliminating the cross bars when I mount a rack. I prefer a low profile.
  14. I did it more out of curiosity than anything else. I liked the "visual lift" but the tires were about 3" outside the fenders. That and the retention clips in the fenders are ugly as sin. I have since put them back on. They don't really extend past the fenders much. As you can see, it still throws mud a little bit. They don't create any clearance issues with my set up, but I have had to do some bumper cutting and fender well reconstructive surgery. Still have a small rub at lock in reverse. Nothing a heat gun won't remedy.
