Mr. Pickles Posted February 16, 2006 Share Posted February 16, 2006 Dude, there is tons of info. in here to be had. Try searching for something like "body+lift+install", etc. Statikuz, 88Path and I have posted a fair amount alone, along with everybody. Also check out this thread. -study- Link to comment Share on other sites More sharing options...
Guest will Posted February 24, 2006 Share Posted February 24, 2006 cool thanks, that helped a lot. im going to be installing hte lift today, so ill be sure to post some before and after pictures when im done Link to comment Share on other sites More sharing options...
thatguy03 Posted June 22, 2006 Share Posted June 22, 2006 is there a write up for this or did it fall by the wayside gettin ready to finish my frame swap and add the 3 inch bl lift just lookin to find as much info as i can possibly find.... Link to comment Share on other sites More sharing options...
Ramithepimp77 Posted June 22, 2006 Share Posted June 22, 2006 Aaron? Rami Link to comment Share on other sites More sharing options...
88pathoffroad Posted June 23, 2006 Author Share Posted June 23, 2006 Heh, I still have all the pics and whatnot, just never got around to writing it all up. You can still check out the writeup I did on my 2-door 3" BL install here: http://www.damagedreality.com/tmaster.html Link to comment Share on other sites More sharing options...
thatguy03 Posted June 23, 2006 Share Posted June 23, 2006 kool thats all helpin a bit has anyone installed teh 3 inch rads drop down kit from ac is it pretty simple they just threw everyting in a box and sent it an i never did this befor so im just tryin to visuallize it all Link to comment Share on other sites More sharing options...
Ramithepimp77 Posted August 13, 2006 Share Posted August 13, 2006 I'm guessing its not a must since we installed my BL without the drop brackets for the radiator. Aaron just made the hoses longer. I'm sure its not to hard though. Rami Link to comment Share on other sites More sharing options...
89_trailboss Posted September 29, 2006 Share Posted September 29, 2006 longer? I had to make mine shorter. the bottom that is. the top was just fine. Link to comment Share on other sites More sharing options...
88pathoffroad Posted September 29, 2006 Author Share Posted September 29, 2006 Yeah, the bottom hose needs shortening. What I did for mine was split the hose in the middle, shorten it up a little and use a piece of tube with two hose clamps to get the angles/positioning right so it wasn't kinked. Link to comment Share on other sites More sharing options...
speedbuggy67 Posted November 24, 2006 Share Posted November 24, 2006 any new pics? Scott Link to comment Share on other sites More sharing options...
Mr. Pickles Posted November 25, 2006 Share Posted November 25, 2006 any new pics? Scott Pics of... ? The lift, the rad hose in particular, etc.? Link to comment Share on other sites More sharing options...
StatutoryApe Posted October 28, 2007 Share Posted October 28, 2007 has anyone had any problems with their brake lines after installing a BL? i just installed mine today/yesterday and i noticed the lines were a bit taut. i imagine this would be worse if i had a suspension lift too. can you uncoil the lines a bit to make them longer? Link to comment Share on other sites More sharing options...
88pathoffroad Posted October 31, 2007 Author Share Posted October 31, 2007 Yeah, just pull a couple of coils apart a little. Don't kink the lines! Link to comment Share on other sites More sharing options...
Splinter Posted October 31, 2007 Share Posted October 31, 2007 When you mention that your brake lines seem taught, I assume that you mean at the master cyl? Like 88 said, you can pull the coils apart a bit. When you do a suspension lift you don't have to worry about them at the master, but you do have to add extensions at all 4 wheels. Link to comment Share on other sites More sharing options...
Simon Posted October 31, 2007 Share Posted October 31, 2007 That's not true, unless you're referring to the Trailmaster suspension lift. Any 3" suspension lift requires no brake line extentions. Link to comment Share on other sites More sharing options...
88pathoffroad Posted November 1, 2007 Author Share Posted November 1, 2007 Ditto, no brake line mods on mine either. Link to comment Share on other sites More sharing options...
StatutoryApe Posted November 1, 2007 Share Posted November 1, 2007 id' say they're just taut in general. i don't mean to sound like an smarta$$, but the definition of taut is tense; not slack. therefore the lines don't have to be taut in any one place, just generally tense. Link to comment Share on other sites More sharing options...
Splinter Posted November 1, 2007 Share Posted November 1, 2007 My bad, must be a Jeep thing then. Link to comment Share on other sites More sharing options...
Simon Posted November 1, 2007 Share Posted November 1, 2007 My bad, must be a Jeep thing then. No worries. Just try to remember that you're now driving a Pathfinder. Some things are MUCH better. Some things (#6 sparkplug location, starter location, alternator location) might make you wish for a HEEP. Link to comment Share on other sites More sharing options...
StatutoryApe Posted November 1, 2007 Share Posted November 1, 2007 My bad, must be a Jeep thing then. it's all good, mang. and i have to agree with simon. some things are in the worst positions Link to comment Share on other sites More sharing options...
Splinter Posted November 1, 2007 Share Posted November 1, 2007 No worries. Just try to remember that you're now driving a Pathfinder. Some things are MUCH better. Some things (#6 sparkplug location, starter location, alternator location) might make you wish for a HEEP. I can pull the front clip off of a YJ, yank the motor, install a new one and drive it out of the shop in 8hrs. Sounds like it'll take me that long to change the plugs lol. Link to comment Share on other sites More sharing options...
Simon Posted November 1, 2007 Share Posted November 1, 2007 Naw...it's not THAT bad...once you get the hang of it. The #6 is a pain....but once you've done it a few times, you just sort of "feel" where it is. It becomes only marginally more difficult than any of the rest, which are pretty standard. Link to comment Share on other sites More sharing options...
harrisons94 Posted October 21, 2010 Share Posted October 21, 2010 Where can i get me one of them fance NPORA stickers?? Link to comment Share on other sites More sharing options...
nunya Posted October 21, 2010 Share Posted October 21, 2010 Where can i get me one of them fance NPORA stickers?? wrong thread...pm fleurys about stickers though Link to comment Share on other sites More sharing options...
Hamz Posted October 20, 2013 Share Posted October 20, 2013 Any chance we could get the pics re-uploaded? they no longer work Link to comment Share on other sites More sharing options...
