Transfer Case And 5spd fs5r30a manual oil
The transfer case takes ATF (Dex-Merc), and the manual transmission takes GL-4 75W90. Make sure it's GL-4! GL-5 rated oil (which is much more common) will eat the synchros.
The drain plugs should be pretty obvious once you're under the truck.
3 minutes ago, FirstGenFreak said:
My one tip is to make sure you can get the fill plug loose before draining the oil.
Good tip, especially for the rear end.
On 3/18/2026 at 1:29 PM, ThatOneNissanGuy said:
Its the 2nd year with my r50 thus my 2nd maintenance,when i got the truck i didnt check either tc or mt oil,what compound does it have and where do i drain it
Here's a video on the Subject I hope this helps
Chris.
