Guest Posted December 7, 2017 Share Posted December 7, 2017 Hi guys, the r50 I recently purchased came without a hitch so i took a trip to the junk yard and picked one up. My question is I have two types of lock washers; one thicker than the other. Does someone know where these specific bolts go? I have four total. Edit: i also just noticed i have two bolts that have thin washers but are shorter. Thanks! Install instructions maybe? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
jjonez Posted December 11, 2017 Share Posted December 11, 2017 If your truck didn't have a hitch is there even holes/threads to bolt it on? Link to comment Share on other sites More sharing options...
johann_peralta Posted December 11, 2017 Share Posted December 11, 2017 If your truck didn't have a hitch is there even holes/threads to bolt it on? They all should have holes for a hitch/ strap down bracket. Link to comment Share on other sites More sharing options...
Mrelcocko Posted December 12, 2017 Share Posted December 12, 2017 Holes should be there and maybe wiring if your lucky. Sent from my SM-S337TL using Tapatalk Link to comment Share on other sites More sharing options...
Guest Posted December 12, 2017 Share Posted December 12, 2017 Thanks for the replies... unfortunately that doesn’t answer where the different bolts are positioned. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
adamzan Posted December 12, 2017 Share Posted December 12, 2017 You could contact one of the hitch brands and just ask for the instructions, may even get lucky and find them on the net somewhere. Otherwise I would just try the bolts in the holes and see what happens. Link to comment Share on other sites More sharing options...
mjotrainbrain Posted December 12, 2017 Share Posted December 12, 2017 Since it's an OEM hitch, I bet the FSM would have the answer. Link to comment Share on other sites More sharing options...
adamzan Posted December 12, 2017 Share Posted December 12, 2017 It might but the hitches were usually dealer installed. Link to comment Share on other sites More sharing options...
Bax03SE Posted December 12, 2017 Share Posted December 12, 2017 Do you have the hitch already? Seems like the easiest thing would be to just get under there with the hitch and see where all the holes line up. If it installs like any of the aftermarket hitches then the factory tow hooks need to come off. Each one is held on by 3 bolts, and there is a 4th unused factory hole there as well, giving you a total of 4 mounting bolts on each side. That should take care of 8 of your bolts and have the hitch mounted to the truck. From there you should be able to figure out where the other bolts go if there are any additional holes on the hitch that line up with mounting points on the truck. 1 Link to comment Share on other sites More sharing options...
Mrelcocko Posted December 16, 2017 Share Posted December 16, 2017 Thanks for the replies... unfortunately that doesn’t answer where the different bolts are positioned. Sent from my iPhone using Tapatalk I would just use your judgment. I would put the longer ones where most of the weight would be distributed on the hitch while towing. Sent from my SM-S337TL using Tapatalk Link to comment Share on other sites More sharing options...
Guest Posted December 16, 2017 Share Posted December 16, 2017 I installed the hitch today! What a B that was. I had to clean out the rusted screw holes before I could even get hitch near the car. I was able to figure out where the screws were supposed to be. The only thing that threw me off was the tailend of hitch has a vertical bolt but nothing to thread into. I guess the donor car at JY had some sort of nut inside frame that i missed. I ended up taking a trip to Home Depot for a couple of nuts but it was very difficult to tighten the bolt 100%. I’ll see if I can take a trip there tomorrow to see the car and I’ll upload a photo of the finished product too. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Bax03SE Posted December 16, 2017 Share Posted December 16, 2017 Glad you got it figured out! Link to comment Share on other sites More sharing options...
Guest Posted December 18, 2017 Share Posted December 18, 2017 Here are some pics of the finished product. I gave the hitch a few coats of standard gloss paint. I even kept the original Nissan label on there. I am content with how it looks! Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
mjotrainbrain Posted December 18, 2017 Share Posted December 18, 2017 I didn't realize the Nissan hitch has a step, that's neat! Doesn't seem necessary though given how good of a step the bumper is. Link to comment Share on other sites More sharing options...
Bunchie Posted December 18, 2017 Share Posted December 18, 2017 I wouldn't worry about the "mystery" bolt hole, if you used 8 bolts, it ain't going anywhere. One thing I did learn was that if you wish to remove the rear bumper, you'll have to remove the hitch first-learned this the hard way on a buddy's '99. Hope you used some Neversqueeze-his was from Quebec and Rust was its middle name. 1 Link to comment Share on other sites More sharing options...
Guest Posted December 18, 2017 Share Posted December 18, 2017 I wouldn't worry about the "mystery" bolt hole, if you used 8 bolts, it ain't going anywhere. One thing I did learn was that if you wish to remove the rear bumper, you'll have to remove the hitch first-learned this the hard way on a buddy's '99. Hope you used some Neversqueeze-his was from Quebec and Rust was its middle name. Oh yes I definitely used anti-seize. I have another car that I purchased in Arizona that was originally from the salt belt and almost every bolt on that car was rusted on the underside. Luckily the unibody is intact. So now all mods get a dab of anti seize on the bolts. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Bunchie Posted December 19, 2017 Share Posted December 19, 2017 Good man! Work smart, not hard(it took me yrs to figure THAT out-lol). Link to comment Share on other sites More sharing options...
RainGoat Posted January 7, 2018 Share Posted January 7, 2018 When I bought my truck in '02 I purchased the OEM hitch at a discount elsewhere & mounted it myself. Just took it off for a bit in October and I was amazed to find no real rust anywhere (and it's been in the Pac NW for 12 years. I really like & trust the OEM design but I will mention that you can't mount a Wilco hitch gate in there due to the back plating. GSpeed151 managed to do it but his solution was imperfect. I'm planning on retrofitting a OEM swingate so it shouldn't matter. Yours looks good! Link to comment Share on other sites More sharing options...
