ahardb0dy Posted October 11, 2011 Share Posted October 11, 2011 Not a kitty cat, my cat converter !! LOL I thought my sentra sounded different last few months, so I've been meaning to pull the cat to check it and today I finally did. This is what I found, let me know what you think: input end: another pic same: output end: Link to comment Share on other sites More sharing options...
nunya Posted October 11, 2011 Share Posted October 11, 2011 Time for a high flow and to sell that one off to a recycler, older Nissan converters were on a better end of the price scale Link to comment Share on other sites More sharing options...
silverton Posted October 11, 2011 Share Posted October 11, 2011 yeah, what nunya said. sell it while you still can, it's definitely on its way out. if you don't have emissions where you live, just get a "test" pipe made. Link to comment Share on other sites More sharing options...
ahardb0dy Posted October 11, 2011 Author Share Posted October 11, 2011 No emission tests down here, and let's just say, the cat is back in the car but it is lighter now! Link to comment Share on other sites More sharing options...
Tungsten Posted October 11, 2011 Share Posted October 11, 2011 (edited) I have never seen one fail that way but it looks like the core melted. Cut it out and put a test pipe. End of story. Edited October 11, 2011 by Tungsten Link to comment Share on other sites More sharing options...
sewebster Posted October 11, 2011 Share Posted October 11, 2011 Cmon guys, save the world! 1 Link to comment Share on other sites More sharing options...
JamesRich Posted October 11, 2011 Share Posted October 11, 2011 I had to change the cat on my quest van because of a similar issue. I couldn't use a test pipe because nissan PUT THE DAMN CAT IN THE FRONT EXHAUST MANIFOLD AND WANTED $1400 FOR A NEW ONE! I'd like to thank the Ahole that decided that move! What happened was pieces of the exhaust manifold started flaking off inside, I'm talking large thin layers. The large chips fell on top of the catalyst and melted into a solid plug. I found a web site that was cutting the manifolds open and replacing the catalyst for around $350. I had to replace the rear manifold too because it was doing the same thing, the rear manifold dumps into the front manifold before the catalyst. I know it's a pain to pull the manifold to check this but you may want to at least drop the pipe and look inside with a light. You would hate to replace your cat and have it happen again. James Link to comment Share on other sites More sharing options...
ahardb0dy Posted October 11, 2011 Author Share Posted October 11, 2011 I put the cat back in, but now I need to find 2 new gaskets, one broke taking it out and the other looks like it is original, the auto parts store didn't have the correct part so I asked the guy to see if he had one that was close. He found one and I bought it but it is leaking. I need to pick up 2 OEM gaskets they really are the best, at least if they still are the same as what I used to get for my hardbody. I had so many problems with aftermarket exhaust gaskets in the hardbody and found the multi layer metal OEM one's were the best. No idea if Nissan still sells that type. Taking the cat out was fun too, the front 2 bolts came right out with the impact gun but the rear had studs screwed into the cat with nuts on them and had to cut both out with cut off wheel, problem is my compressor does not have the auto off pressure switch on it so I have to plug the compressor in, stand there until it reaches 135 PSI than unplug it, use the air tool (die grinder) than when the air runs out, repeat the process, pain in the butt need to get a new pressure switch and fix the compressor. Took about 6 tank fulls of air to cut the 2 bolts!! Link to comment Share on other sites More sharing options...
nunya Posted October 11, 2011 Share Posted October 11, 2011 No emission tests down here, and let's just say, the cat is back in the car but it is lighter now! just killed it's scrap value... prices are currently good and the coin you coulda got would bought a test pipe (which is a strait piece of pipe-cheap) and a fiew tanks of fuel, especially in your sentra. Link to comment Share on other sites More sharing options...
Radwaste Posted October 11, 2011 Share Posted October 11, 2011 I ended up cutting my own gaskets when I replaced a cat on the R50. i used Mr. Gasket 5960 Ultra Seal Exhaust Gasket <http://www.amazon.com/gp/product/B000BWAPHA> It's been a couple months and I haven't had any problems. Link to comment Share on other sites More sharing options...
Precise1 Posted October 11, 2011 Share Posted October 11, 2011 I'd definitely be looking for root causes!! So now is a good time to recycle the cats Nunya? I have two and a pre-cat from pathfinders. I should call around... B Link to comment Share on other sites More sharing options...
silverton Posted October 11, 2011 Share Posted October 11, 2011 JamesRich, that's what they call Three Way Catalyst. Link to comment Share on other sites More sharing options...
ahardb0dy Posted October 11, 2011 Author Share Posted October 11, 2011 I couldn't find a test pipe for it. Today I stopped at one of the local Nissan dealers (there are 3 in Orlando) and picked up 2 new gaskets. I think the metal Nissan ones are the best, always had problems with aftermarket gaskets. $21 later..... Link to comment Share on other sites More sharing options...
nunya Posted October 11, 2011 Share Posted October 11, 2011 I'd definitely be looking for root causes!! So now is a good time to recycle the cats Nunya? I have two and a pre-cat from pathfinders. I should call around... B prices are going to be regional, but pre cats are probably less valuable than the full length one either way ahardb0dy, I agree, if your gonna use gaskets and not just weld everything together I agree, the metal are better than the normal parts store off the shelfers. Link to comment Share on other sites More sharing options...
JamesRich Posted October 12, 2011 Share Posted October 12, 2011 JamesRich, that's what they call Three Way Catalyst. What is called three way catalyst, when they put the catalyst in the exhaust manifold? I just called it an expensive pain in the . James Link to comment Share on other sites More sharing options...
Tungsten Posted October 12, 2011 Share Posted October 12, 2011 It's such bull@!*% how they tack the catalyst right into the engine. Given it's more efficient but it's more damn trouble than it is worth! The engineers that design this @!*% don't have to work on it. Then way to mine the Earth for precious metals just so that some hippy can feel good about a cleaner exhaust. One catalytic converter is good enough! Link to comment Share on other sites More sharing options...
ahardb0dy Posted October 12, 2011 Author Share Posted October 12, 2011 Pulled the cat back out today after work, sanded the flanges so they were nice and smooth, re-installed the cat with those great Nissan gaskets, started it up, no more leaks!! Nissan gaskets are the best!! Now have to research if I can use the SE-R exhaust on the car to free up the flow a little more. Link to comment Share on other sites More sharing options...
Tungsten Posted October 13, 2011 Share Posted October 13, 2011 I didn't catch it but did you get another one or unclog the old one? Link to comment Share on other sites More sharing options...
ahardb0dy Posted October 13, 2011 Author Share Posted October 13, 2011 For now it's back on but "lighter", later on I may throw a high flow on as there is no way I would pay for a stock part, they want like $900 online!!! Link to comment Share on other sites More sharing options...
nige Posted November 8, 2011 Share Posted November 8, 2011 came in here for cat pics, left dissapointed Link to comment Share on other sites More sharing options...
Kafike Posted November 10, 2011 Share Posted November 10, 2011 I didn't realize you could recycle the cat. Good to know. Link to comment Share on other sites More sharing options...
nunya Posted November 11, 2011 Share Posted November 11, 2011 came in here for cat pics, left dissapointed cat clogged? Link to comment Share on other sites More sharing options...
BowTied Posted November 11, 2011 Share Posted November 11, 2011 It's such bull@!*% how they tack the catalyst right into the engine. Given it's more efficient but it's more damn trouble than it is worth! The engineers that design this @!*% don't have to work on it. Then way to mine the Earth for precious metals just so that some hippy can feel good about a cleaner exhaust. One catalytic converter is good enough! I can understand your frustration. Most engineering folks are not actually to blame. Most would rather design something that is practical. Management often direct them to make it cheaper or whatever and force them to compromise designs. There are dumb engineering type like there are in any walk of life, but chances are the company they work for places constraints on the design that preclude a practical or user serviceable end product - usually for the sake of cost or time. Link to comment Share on other sites More sharing options...
Tungsten Posted November 11, 2011 Share Posted November 11, 2011 Good point! I hope you don't have to deal with those converters on your R50 because you are in for a big surprise. Link to comment Share on other sites More sharing options...
adamzan Posted November 11, 2011 Share Posted November 11, 2011 they never really go bad anyway Link to comment Share on other sites More sharing options...
