ac92pathfinder Posted June 16, 2009 Share Posted June 16, 2009 (edited) will it urt to run any of those. the autoparts i went to dont have the ngk or denso'd and i need them by today will it hurt it? Edited June 17, 2009 by ac92pathfinder Link to comment Share on other sites More sharing options...
87pathy Posted June 16, 2009 Share Posted June 16, 2009 will it urt to run any of those. the autoparts i went to dont have the ngk or denso'd and i need them by today will it hurt it? Neither, NGK or Bosh I have had both autolites and champions BAD out of the box Link to comment Share on other sites More sharing options...
Kingman Posted June 16, 2009 Share Posted June 16, 2009 I put Autolites in my truck and the gas mileage sucked and so did the power. I switched to NGK and it seemed to like them better. Link to comment Share on other sites More sharing options...
k9sar Posted June 16, 2009 Share Posted June 16, 2009 Champions are fine for lawnmowers and chainsaws I wouldn't put them in my truck Link to comment Share on other sites More sharing options...
Kingman Posted June 16, 2009 Share Posted June 16, 2009 Buy whatever to tide you over for the day, then replace them with Bosch or NGK ASAP. You don't want to run crappy plugs for very long. Link to comment Share on other sites More sharing options...
nismothunder Posted June 16, 2009 Share Posted June 16, 2009 Both plugs that he said are sold at wal-mart...I stay away from wal-plugs...I run Ac-delco plugs and my truck runs good Link to comment Share on other sites More sharing options...
FUELER Posted June 16, 2009 Share Posted June 16, 2009 i had bosch in and one failed after only a few months, causing a nasty misfire NGKs on the other hand, ive run forever with no problems Link to comment Share on other sites More sharing options...
Kingman Posted June 16, 2009 Share Posted June 16, 2009 Both plugs that he said are sold at wal-mart...I stay away from wal-plugs...I run Ac-delco plugs and my truck runs good Just because of where it's sold doesn't reflect on quality, unless it's a store brand name. If quality were to be affected by stores, then Wal Mart wouldn't sell BFGs, Goodyear MTs, Castrol, Pennzoil, Mobil1, etc etc. Link to comment Share on other sites More sharing options...
morpheus Posted June 16, 2009 Share Posted June 16, 2009 When it comes to plugs, I've always recommended running what the factory made. If it's a Nissan, use NGK, if it's a gm use ACdelco, Ford use Motorcraft. Can't just use the old plugs till you can get ngk's? Link to comment Share on other sites More sharing options...
alexrex20 Posted June 16, 2009 Share Posted June 16, 2009 When it comes to plugs, I've always recommended running what the factory made. If it's a Nissan, use NGK, if it's a gm use ACdelco, Ford use Motorcraft. Can't just use the old plugs till you can get ngk's? ^^^ x 1000 i stay away from brands like TripleFire and Bosch Platinum, and anything aftermarket really. Just use OEM and you'll get the best performance. Don't try to save a few bucks by getting the $2 plugs. Spend the extra $20-40 for OEM and you won't regret it. They offer better performance, better fuel economy, and longer life. Link to comment Share on other sites More sharing options...
tekazgtr1984 Posted June 16, 2009 Share Posted June 16, 2009 Yup, stick to what's good. NGK+Nissan=Giggity! Link to comment Share on other sites More sharing options...
ac92pathfinder Posted June 17, 2009 Author Share Posted June 17, 2009 so i would have to order the plugs. in the mean time i got lubricate to soak the plugs then brush them off with a mini wire brush and rinse with brake clean seems the clean it good. i let the oil drain over night to get most of it out. do u recommend me canging it again to get some of the gas out of the engine? well im hopeing this will work wish me luck. thanks for all your replies Link to comment Share on other sites More sharing options...
nige Posted June 17, 2009 Share Posted June 17, 2009 next time, spray some compressed air on the plugs to blast any dirt or grit out before removing them. you don't want that stuff falling inside the combustion chamber when you remove your old plugs. Put a thin coat of anti-seize compound on each new plug before you install them. i don't understand what you are talking about getting gas out of the engine. are your cylinders flooded with fuel? Link to comment Share on other sites More sharing options...
ac92pathfinder Posted June 17, 2009 Author Share Posted June 17, 2009 next time, spray some compressed air on the plugs to blast any dirt or grit out before removing them. you don't want that stuff falling inside the combustion chamber when you remove your old plugs. Put a thin coat of anti-seize compound on each new plug before you install them. i don't understand what you are talking about getting gas out of the engine. are your cylinders flooded with fuel? ya my spark plugs smell like strong fuel. it was damp. Link to comment Share on other sites More sharing options...
ac92pathfinder Posted June 18, 2009 Author Share Posted June 18, 2009 ok so i took the spark plugs out cleaned them took all the black crud off till i get new ones and changed the oil. when i start it up it smokes out of the exhaust like a mother basicly what it did before. started right up ran for a min then died, then i tried starting it u can hear it back firing through the airfilter box with smoke coming out of it then finally starts let it run for almost a min then dies but when i do keep it running i have to keep tapping on the gas cause when i press it it sputters like it wants to cut out but it likes to back fire through the air box when i try to use gas to keep it running seems to idle fine but then it goess down and dies. uuuuuuuuuuuuuuuuhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh my next thing is drain the gas tank? maybe fuel pump? Link to comment Share on other sites More sharing options...
Creekkid Posted June 18, 2009 Share Posted June 18, 2009 How's the timing on it....think you might of slipped a few cogs on the TB maybe...dunno.....what about the O2 sensor or the MAF or something like that. Link to comment Share on other sites More sharing options...
Nismojunky Posted June 18, 2009 Share Posted June 18, 2009 How's the timing on it....think you might of slipped a few cogs on the TB maybe...dunno.....what about the O2 sensor or the MAF or something like that. X2 Link to comment Share on other sites More sharing options...
ac92pathfinder Posted June 19, 2009 Author Share Posted June 19, 2009 X2 i'll look into it but it happened after they came out and put gas into it then it started running like this Link to comment Share on other sites More sharing options...
edicer2 Posted June 19, 2009 Share Posted June 19, 2009 so basically it ran fine then you ran out of gas and once you filled it up again its been acting like this? Link to comment Share on other sites More sharing options...
ac92pathfinder Posted June 20, 2009 Author Share Posted June 20, 2009 so basically it ran fine then you ran out of gas and once you filled it up again its been acting like this? it didnt run out it got to where the gauge wont go any lower so i had a tow truck driver came out and put 5 dollars worth in and thats when it acted up. Link to comment Share on other sites More sharing options...
