nismothunder Posted March 15, 2009 Share Posted March 15, 2009 (edited) Well I got a 1995 pathfinder XE v-6 Jan of 2008.Its been a great truck other then frame rust issues(fixed) and this.It leaks coolant from front of engine.I had he water pump,hoses(all of them...even that little SOB(main leak fixed)cam seals and T-belt replaced.But its leaking again.Its pissing me off that the damn thing leaks anti-freeze evan after putting $780 bucks in the front of the engine.So what could it be...head gasket,or I heard someplace thats theres a valve on the heads on the front end(fan side)If so...where,I dont see any valves. Thanks for any help. Edited March 15, 2009 by nismothunder Link to comment Share on other sites More sharing options...
Kingman Posted March 15, 2009 Share Posted March 15, 2009 Are you or them sure they got a good seal on the bypass hose? Link to comment Share on other sites More sharing options...
nismothunder Posted March 15, 2009 Author Share Posted March 15, 2009 Yeah Its not leakng there any more...I think thats the little Sob that was split and was puking all over my engine.But I did find out something from it.BAR's Rad Stop Leak does work.For a while until the hose splits completey. Link to comment Share on other sites More sharing options...
beastpath Posted March 15, 2009 Share Posted March 15, 2009 thermostat housing? Link to comment Share on other sites More sharing options...
MY1PATH Posted March 15, 2009 Share Posted March 15, 2009 thermostat housing? x2 Link to comment Share on other sites More sharing options...
94extreme Posted March 15, 2009 Share Posted March 15, 2009 do NOT put the BAR stop leak thing in there as it also tends to plug small passages that need to be open for the thing to operate properly. Link to comment Share on other sites More sharing options...
Slick Posted March 15, 2009 Share Posted March 15, 2009 do NOT put the BAR stop leak thing in there as it also tends to plug small passages that need to be open for the thing to operate properly. amen! i blew my HG shortly after using bars leak Link to comment Share on other sites More sharing options...
Whitebrick Posted March 15, 2009 Share Posted March 15, 2009 do NOT put the BAR stop leak thing in there as it also tends to plug small passages that need to be open for the thing to operate properly. ya we did that to my moms old yukon and it did stop the leak but two month later it needed a new radiator for the temp was going past 210. we broke off one of the plastic sides and it had crap blocked the little water passages. it sucked. Link to comment Share on other sites More sharing options...
KLL Posted March 15, 2009 Share Posted March 15, 2009 did you check expansion tank? for instance mine is constantly dripping... it is somehow cracked. Link to comment Share on other sites More sharing options...
88pathoffroad Posted March 15, 2009 Share Posted March 15, 2009 Where is it leaking from? Could it be the heater hoses? Link to comment Share on other sites More sharing options...
GrimGreg Posted March 16, 2009 Share Posted March 16, 2009 Where is it leaking from? Could it be the heater hoses? Or the hoses that go to the throttle body? Link to comment Share on other sites More sharing options...
nismothunder Posted March 16, 2009 Author Share Posted March 16, 2009 Its Mutli port injected not throttle body.Also I put the pellots in and not the stuff that looks like sand and smells like crap.I looked at it yster day and it looks like its coming from the passger side of the engine where it was leaking before.Also it looks like the A-hhole who replaced the parts put Silicon on a ...I dont know what the hell it is but its up above the water pump on the left side and a hose goes to it.Its black silicon and I dont know if you can put silicon on a anti freeze line(it does have anti freeze going through it I know that much and the peice is only there so you can mount a hose) also the guy did not replace the thermostat even though he was told to.This guy also wanted to give me the truck with out the little SOB hose fixed.He went"I thought you wanted the water pump and t-belt replace only" He didnt see it(or says he didnt) but I'm not going to hold that agaisnt him.I just went to the wrong guy and he's done it before.Finesed a job half-assed.My buddy took he Grand Pre there for the same thing and its undriveable know because of a huge coolant leak. But what's done is done so no more b^&**ing out of me. But can you seal it with sillicon.I know you can do valve covers but doesnt anti freeze get hoter then the oil.I allways beleaved this. Link to comment Share on other sites More sharing options...
GrimGreg Posted March 16, 2009 Share Posted March 16, 2009 (edited) You still have a throttle body with multi port injection . Sounds like the thermostat housing, and it is perfectly fine (actually better) to use RTV to seal it. Edit to add: They make RTV hot enough to seal exhaust systems, my 93's exhaust has no gaskets. Edited March 16, 2009 by GrimGreg Link to comment Share on other sites More sharing options...
nismothunder Posted March 16, 2009 Author Share Posted March 16, 2009 You still have a throttle body with multi port injection . Sounds like the thermostat housing, and it is perfectly fine (actually better) to use RTV to seal it. Edit to add: They make RTV hot enough to seal exhaust systems, my 93's exhaust has no gaskets. This is dumb then.I always thought a TBI was a Carb that was controled Electrnicly.I didnt know that true fuel injected (TPI engines)engines had TBI.I knew they had mass-air flow sensors but I thought the fuel was injected from injectors(I know it is)or a fuel rail...or on carbed and tbi unit jets.Also I dont know what I was thinking about the sillicon since I new they made High temp types.I didnt know if he put water proof sillicon on(diffrent colars,blue,red white clear black) Link to comment Share on other sites More sharing options...
Slick Posted March 16, 2009 Share Posted March 16, 2009 your pathy is MPFi.................... Multi port fuel injected. Link to comment Share on other sites More sharing options...
GrimGreg Posted March 16, 2009 Share Posted March 16, 2009 This is dumb then.I always thought a TBI was a Carb that was controled Electrnicly.I didnt know that true fuel injected (TPI engines)engines had TBI.I knew they had mass-air flow sensors but I thought the fuel was injected from injectors(I know it is)or a fuel rail...or on carbed and tbi unit jets.Also I dont know what I was thinking about the sillicon since I new they made High temp types.I didnt know if he put water proof sillicon on(diffrent colars,blue,red white clear black) TBI just has the injector in the TB, but MPFI have a TB at the opening to the intake manifold, after the MAF. Link to comment Share on other sites More sharing options...
Nytrosfinder Posted March 17, 2009 Share Posted March 17, 2009 I heard you can put an egg in your radiator and it will seal it.... dont know if thats true or not... I say get a new radiator or whatever leaks... Link to comment Share on other sites More sharing options...
Kingman Posted March 17, 2009 Share Posted March 17, 2009 I heard you can put an egg in your radiator and it will seal it.... dont know if thats true or not... I say get a new radiator or whatever leaks... Mythbusters did it! And it worked! Along with Coke for coolant! And mothballs for higher octane fuel! Link to comment Share on other sites More sharing options...
nismothunder Posted March 18, 2009 Author Share Posted March 18, 2009 Fixed the leak.It was the termostat houseing.Just resiliconed it.Alls good now. Thanks to all that helped and those that clear up the Throttle body thing. Link to comment Share on other sites More sharing options...
