flnl Posted August 11, 2008 Share Posted August 11, 2008 I know some of you moved the ECU to the glove box. Did someone else moved it to another place? I don't want to lose that space, but I couldn't find such an easy place to move it to. Link to comment Share on other sites More sharing options...
k9sar Posted August 11, 2008 Share Posted August 11, 2008 I have one in a box on a shelf in my garage... does that count? Link to comment Share on other sites More sharing options...
flnl Posted August 11, 2008 Author Share Posted August 11, 2008 I have one in a box on a shelf in my garage... does that count? Well, that's an idea... that way I wouldn't worry about someone stoling my Pathy to part it out in a JY... when I want to drive it, I plug the ECU again and put it over my legs Link to comment Share on other sites More sharing options...
nige Posted August 11, 2008 Share Posted August 11, 2008 I think Iron Locust has the best idea by putting all the electronics on the ceiling of the cab. you will have to extend a lot if wires to do it, but you can pretty much guarantee you will never get it wet and if you do, you have a lot more to worry about than a wet ecu. I put mine in the glovebox, but it's not safe there either as you can see from what happened to SkinnyPedal last year: you could always carry a spare, but be aware that the donor vehicle's transmission has to be an automatic if yours is an automatic. If you have a manual transmission; you can use either an automatic or manual trans donor ecu. Link to comment Share on other sites More sharing options...
Red87Path Posted August 12, 2008 Share Posted August 12, 2008 is there anything you need to splice to use one from an automatic? or is it just plug and play? Link to comment Share on other sites More sharing options...
Kittamaru Posted August 12, 2008 Share Posted August 12, 2008 Why not simply waterproof the ECU with a lockbox and, when at risk for deep water, close the box? It can take the heat for a little, can't it? Link to comment Share on other sites More sharing options...
TerranoNZ Posted August 12, 2008 Share Posted August 12, 2008 is there anything you need to splice to use one from an automatic? or is it just plug and play? AFAIK (Auto) ECU into manual = fine, (Auto) ECU into Auto = fine, but (Manual) ECU into Auto = auto has no idea The (auto) ECU sends the auto ECU a signal so it knows what revs the engine is doing Clear as mud huh? Link to comment Share on other sites More sharing options...
GrimGreg Posted August 12, 2008 Share Posted August 12, 2008 My 88's sits in a sealed box (tupperware style) under the seat in it's original location. Never had an issue of too much heat leaving it sealed up all the time. Link to comment Share on other sites More sharing options...
flnl Posted August 12, 2008 Author Share Posted August 12, 2008 (edited) My 88's sits in a sealed box (tupperware style) under the seat in it's original location. Never had an issue of too much heat leaving it sealed up all the time. Maybe the ECU doesn't generate too much heat, so that won't be a problem... How did you seal the hole for the wires? Silicone rubber? Edited August 12, 2008 by flnl Link to comment Share on other sites More sharing options...
GrimGreg Posted August 12, 2008 Share Posted August 12, 2008 Maybe the ECU doesn't generate too much heat, so that won't be a problem... How did you seal the hole for the wires? Silicone ruber? I used tube silicone and worked itinbetween all the wires to make them basically a solid bundle. Then once I fed them through a hole in the side of the box I sealed around the outside and inside of box between the wires and the edge of the hole. I cut the "feet" off the ECU, and mounted the box using 2 of the factory mount points by drilling the box and sealing each screw, and the ECU just "floats" inside the box. I even ran a bead of silicone around the lid seal before I closed it up. I never did take a finished pic (did the work 2 years ago), I'll try and remember to get one. Link to comment Share on other sites More sharing options...
daver123 Posted August 13, 2008 Share Posted August 13, 2008 The answer to this age old question really is how deep do you plan to go? If you like to see how well your truck can swim, then put it on the roof, if your just concerned about water on the floor waterproofing or the glovebox move are your only easy options. i probably moved it to the glove box in 3 hrs and im anal about wiring and such. Link to comment Share on other sites More sharing options...
TEAMTRUCKER Posted April 9, 2010 Share Posted April 9, 2010 i put mine up in my dash, it sits inside the space where the drivers side vent used to be. had to take the vent out wen i did the manuel conversion Link to comment Share on other sites More sharing options...
Kingman Posted April 9, 2010 Share Posted April 9, 2010 ECUs shouldn't generate any heat at all, so sealing it would be fine. I like GGs idea, may have to try it myself. Link to comment Share on other sites More sharing options...
MY1PATH Posted April 10, 2010 Share Posted April 10, 2010 (edited) for the square dash I've tossed arround the Idea of moving mine to on top of the dash flush against the insrument bezel. I'd postition it with the light facing the seats and run a toggle switch next to it wired to the diagnostic switch. The harnes could then go straight down next to the defroster vent and to the firewall. I think it may be long enough to reach as is too... 3 scissor snips and seams later my dash mat would contour and cover it just as well as it coverd the original set up. AND I could run diagnostics from the drivers seat! Edited April 10, 2010 by MY1PATH Link to comment Share on other sites More sharing options...
