Kittamaru Posted November 20, 2007 Author Share Posted November 20, 2007 JC Whitney? Never heard of em... Remember, I are teh newbie. Link to comment Share on other sites More sharing options...
GrimGreg Posted November 20, 2007 Share Posted November 20, 2007 The same has happened to my catalytic converter casing Casing or heat sheild? As for the pans they shouldn't have been undercoated to begin with, just painted. Link to comment Share on other sites More sharing options...
88pathoffroad Posted November 20, 2007 Share Posted November 20, 2007 JC Whitney's been around for a LONG time, and the pans are rather thick to begin with. I'd take the trans pan off when you can to check thickness. Link to comment Share on other sites More sharing options...
Kittamaru Posted November 20, 2007 Author Share Posted November 20, 2007 I may be thinking of the wrong parts... I'm guessing that's what they are due to location... and, well, they look like a big pan Link to comment Share on other sites More sharing options...
Kittamaru Posted November 27, 2007 Author Share Posted November 27, 2007 Alright, got a big worry on my hands... my truck is running very, VERY rough. Very little power, and it sounds bad... think like rototiller when it can't find the right fuel / air mixture... I'm thinking either injectors, spark plugs, or bad lines? Fuel filter, PCV valve, air filter, are all good... know this for a fact (they're brand new ) I am due for an oil change soon... and I have a small oil leak from the headgasket which I want to replace ASAP but it isn't major... like... add a few ounces once a month and I'm good kind of minor leak. The strangest symptom is, as I approach about 3200 rpm, it starts to smooth out... and as I drop under 2000 rpm it gets SO rough I fear it will stall and I cannot maintain speed no matter what... I've seen before about pulling codes... no check engine light or anything and I don't know how to pull codes anyway. Any ideas? I'm starting to wonder if I should be running her at all if she's sputtering like that... my poor baby is sick Link to comment Share on other sites More sharing options...
Kittamaru Posted November 29, 2007 Author Share Posted November 29, 2007 *bump* My truck is running a bit smoother... not by much. It seems that in the rain it gets much much worse... this leads me to believe it's either: Bad fuel injectors Bad fuel/air ratio Bad air intake any ideas? Link to comment Share on other sites More sharing options...
adamzan Posted November 29, 2007 Share Posted November 29, 2007 (edited) Maybe something in the wiring somewhere, have you checked that? I remember when my dad had the skidplate off our 94 for a bit when it rained the cruise control, signals and tach would die Oh and I saw something on hear about the mass airflow sensor, the wiring for it at the sensor can get flaky IIRC and if you wiggle it while the someone tries to keep the truck running you'll see. Its the one right on the air filter tube. Someone correct me if im wrong Edited November 29, 2007 by redfinder Link to comment Share on other sites More sharing options...
Kittamaru Posted November 29, 2007 Author Share Posted November 29, 2007 (edited) Nah, it's dry now and it's still doing that... been dry the last three days *pouts* I need to replace my plug wires and all that... it's a plan for when I have $$$ I'll check the airflow sensor ASAP Edited November 29, 2007 by Kittamaru Link to comment Share on other sites More sharing options...
sammyb33 Posted November 29, 2007 Share Posted November 29, 2007 maybe a clogging cat? Link to comment Share on other sites More sharing options...
Kittamaru Posted November 29, 2007 Author Share Posted November 29, 2007 cat... catalytic converter? Link to comment Share on other sites More sharing options...
Simon Posted November 29, 2007 Share Posted November 29, 2007 Yes....cat = catalytic converter. My guess is the MAF. The wiring on top is known to cause issues. Go give it a wiggle with the truck running, and see if the idle smooths out. Link to comment Share on other sites More sharing options...
Kittamaru Posted November 29, 2007 Author Share Posted November 29, 2007 I actually odn't know where the MAF is Can you post a picture or give a description? Link to comment Share on other sites More sharing options...
Simon Posted November 29, 2007 Share Posted November 29, 2007 There's an electrical plug just past the airbox. That's the MAF connector. Link to comment Share on other sites More sharing options...
Kittamaru Posted November 29, 2007 Author Share Posted November 29, 2007 You underestimate my newbness... airbox = air filter? Link to comment Share on other sites More sharing options...
Simon Posted November 29, 2007 Share Posted November 29, 2007 The box in which the air filter resides. Link to comment Share on other sites More sharing options...
Kittamaru Posted November 29, 2007 Author Share Posted November 29, 2007 Aight, that's what I was thinking I'll take a look asap Link to comment Share on other sites More sharing options...
MarkGardiner Posted November 29, 2007 Share Posted November 29, 2007 http://www.nissanpathfinders.net/forum/index.php?showtopic=5194 ^link for cleaning your maf sensor, has some pictures to help you better find it. Link to comment Share on other sites More sharing options...
