terra88 Posted June 24, 2007 Share Posted June 24, 2007 Hey all , Just bought another rano for the miss's. Needs a gearbox and a tidy up but got it hell cheap, plus I have a wrecked rano still to rob parts. But my main concern is that whilst driving it back (1200klm trip) the radiator boiled dry several times and upon inspection by torchlight lol, there is tiny bubbles coming out of the radiator filler. In my experience that is a tell tale of a blown head gasket ?? Has anyone done a head gasket on the TD27 motor or had this problem ? Thanks Guys Link to comment Share on other sites More sharing options...
unccpathfinder Posted June 27, 2007 Share Posted June 27, 2007 run a compression check...you could have a bad water pump i think esp if there isnt any water in the fuel and you dont see residue on the heads where the coolant would have leaked out... Link to comment Share on other sites More sharing options...
bryfry Posted June 27, 2007 Share Posted June 27, 2007 Look for signs of white smoke (not blueish like oil smoke) coming out of the tailpipe especially when first started in the morning. This is usually indicative of a bad gasket. You are also correct about the bubbles. The best way is doing a compression check. Link to comment Share on other sites More sharing options...
94extreme Posted June 27, 2007 Share Posted June 27, 2007 fluids do tend to mix at least somewhat when the head gasket is shot. Link to comment Share on other sites More sharing options...
unccpathfinder Posted June 28, 2007 Share Posted June 28, 2007 fluids do tend to mix at least somewhat when the head gasket is shot. ohh yea i forgot to mention that if u check the oil and its milky then you've got a problem...be it head gasket or a cracked block/head most likely a head gasket Link to comment Share on other sites More sharing options...
terra88 Posted June 28, 2007 Author Share Posted June 28, 2007 no water in oil, no white smoke, water pump works fine cause you can see the water moving fast in the radiator. got a co2 test and all good. The mech told me maybe blocked radiator... Link to comment Share on other sites More sharing options...
Slick Posted June 28, 2007 Share Posted June 28, 2007 try burping the radiator Link to comment Share on other sites More sharing options...
fondo Posted June 28, 2007 Share Posted June 28, 2007 Well, considerin' you have a td27 motor, what is it equiped with? N/A or turbo? Thats diesel right... thats higher pressure on the heads gaskets and all the parts associated with the internal moving parts of the motor for that matter. Just a few things to consider. Link to comment Share on other sites More sharing options...
Simon Posted June 28, 2007 Share Posted June 28, 2007 I do believe the TD designation in td27 stands for turbo diesel. Link to comment Share on other sites More sharing options...
94extreme Posted June 28, 2007 Share Posted June 28, 2007 did the temp guage peg out? Link to comment Share on other sites More sharing options...
sw Posted June 28, 2007 Share Posted June 28, 2007 to know for sure do a compression check, you will probably have to go to a diesel mech as compression is much higher being a diesel btw nissan diesel td27 t - now im not 100% on this but i believe the t stands for timing gears - as in no timing belt or chain but metal gears. similarly rd28 (another nissan diesel) - the r stands for timing belt d - is diesel. 27 - is capacity td27t - the last t is for turbo td42ti - which is what i have :) the i is for intercooled Link to comment Share on other sites More sharing options...
CrazzyMax Posted July 23, 2007 Share Posted July 23, 2007 I had the same problem, no white smoke, no oil mixing, just air in the water circuit. I opened up the engine and it was just the head gasket. (in the year before i did a gasket check and replaced it with gasket that wasn't Nissan) I put a new one bought at Nissan, and so far, runs great. Link to comment Share on other sites More sharing options...
adamzan Posted July 23, 2007 Share Posted July 23, 2007 Look for signs of white smoke (not blueish like oil smoke) coming out of the tailpipe especially when first started in the morning. This is usually indicative of a bad gasket. You are also correct about the bubbles. The best way is doing a compression check. I get white smoke when she first runs for a while, but could that be because its been sitting and hardly run for 2 years? Because I let her run for half an hour last week and it stopped and hasn't done it since. All Fluids are good. Link to comment Share on other sites More sharing options...
