terra88
Everything posted by terra88
chasing a 100mm / 4" suspension lift (trailmaster etc)
terra88 replied to terra88's topic in 90-95 WD21 Pathfinders
might go check out the front end again to see if that would work? -
yeah I looked at modifying the cross member but the cv's sit close to the torsion bars as it is so you wouldn't gain much without dropping the whole lot. If I could get the kit or at least the main parts that would make life a lot easier -
Hey mate, can you send me the link? I have never used craigslist before -
Just cos it looks cool... I already have a 2" body lift and 2-3" of suspension lift, but the cv's are maxed out. -
Thanks Mate -
Hey guys, I'm in Australia and these 4" lifts are not available over here. I have previously had a 2 door terrano with a trailmaster lift but that kit is discontinued and not in stock. I am looking for a similar kit for my 94 wd21 but can't seem to find anyone that makes them. I know a sas would be a better idea but don't have the time or resourses to do that. any info would be great, Thanks Lee
Thanks mate. The factory fuel lines will be in negative pressure because the IP sucks the fuel from the tank. I looked into holley red or some walbro pumps that pump between 4-7 psi and pump on demand.
Has anyone fitted a Holley (or electric) fuel pump to their TD27T terrano? Apparently the factory manual injector pump can starve at higher revs and the extra fuel pressure being supplied to the pump helps power etc?
Seen on here about advancing the injector pump timing a few degrees, but can't find any info about how to measure it or how far to turn the pump. Saw on another site that you should move it towards the engine block by 1-2mm?? any help would be great...
awesome thanks mate..
I did a quick search but couldn't find the font used in the NPORA website logo. I want to make a windscreen sticker up and thought that the website banner would look pretty good..
Thanks mate, I can see I need the m12x1.25 x150mm bolts for the rear and m10x1.25 x150mm bolts for the middle(6 of?) but are the radiator support ones a bit shorter?
Yeah I wanted to get everything ready to do this week without pulling I half apart. Surely someone knows the standard bolt size and thread for the rears ?
Hey all, I bought myself another Terrano, this one is a 1994 4 door, and want to do a 2inch body lift. I have searched unsuccessfully for bolt lengths so hopefully someone knows the bolts I need for the 2 inch lift blocks. Many thanks Lee
UM ..... Well I just bought a pair of ironman rear coils $130 and rear shocks $140 ... that was the best price from a lot of brands made ... not bad as they have a 2 year 40,000klm warranty and are made in the same factories as monroe ,pedders , and king springs ... should be good going to put them in this week , miss's is already smiling
Hey fellow aussie's , got a question for ya's . Just bought the miss's a 91 4door terrano and wanted to know who make the highest locally made spring for the rear. I myself put pedders on my 2 door but thats only because I was working there at the time.... any help guys cheers Lee
Hey mate , did you end up getting a manual ?? got one with terrano #3 I bought ....
Dude, didn't you guys know we have flying cars ova here now.... get with the times will ya .... lmao
Thanks bro, seen that topic and been on the jap site but its so frigin confusing....
all good mate, as for upgardes to the turbo motor i think I have done it all. I have incresed boost three ways. 1. spaced out the wastegate acuator. 2. longer wastegate acuator boost line 3. GFB boost controller currently run 15-16psi boost with no problems Three inch exhaust (stainless steel) with no muffler PWR glycol intercooler kit Injector pump fuel increase Pod filter off turbo Um I think thats it ??
Hey Pathie4Me, what font did you use???
LOL, it broke off because it was trying to tell you its not needed...
Does any one have a picture or something with the npora windscreen banners, (the website) so i can get my own cut downunder.... Lee
Ok want some for mine and the wifes terrano, am after 2 windscreen size and 4 of these ones you have. But my problem is im in australia. Would you post that far? Thanks Lee
