Sas
Guest SuperSon
  • Replies 50
  • Created
  • Last Reply
Top Posters In This Topic
I love purpose built pathies! My roomate (aka Tbecktold) is doing an SAS on his HB. We recently swaped in an H233B with a lock right and he also just picked up a driver drop front axal a of a waggy. Now he just has to decide wether to go spring under or spring over. I can't wait to see his beast hit the trails.
Edited by Extreme90path
Probably spring under for now, 5.14s/lockrights f&r. As far as the NEEDing the SAS goes, I honestly don't NEED it. However, my steering isn't the greatest anymore (244k on stock steering), I've already had one UCA pull out of the frame, and the rest of my frontend is just going down the tubes. So instead of throwing $$ at the IFS, I'm going solid axle now because that's where I was going to end up eventually, it just costs less over the long run if I do that right now instead of rebuilding the IFS now and going to SFA later.
Oh, and as far as the axle stuff goes. It was touched upon, but the newbies may not know about the different flavors of driver-drop D44s. There is the Waggy 44 that comes out of 80-91 (I think) Wagoneers, driver drop, already 6x5.5 pattern, 60" wide I think. There is also the Cherokee Chief/J10 D44 that is about the same thing, only a couple of inches wider, 62" I think. The other flavor is the Ford high pinion D44, it's about 65" iirc, is high pinion where the others are low, uses coils rather than the leaves the others use, and has a 5x5.5" bolt pattern.
:tonguefinger: <--kick@ss smiley!
When the $$ allows. Like Ben said I've got the Waggy axle and have it partially cleaned up, but haven't pulled anything apart on it yet. I'm goin to concentrate on getting it under the truck and steering first, and then worry about gears/locker. This is going to sound incredibly stupid, but I'm hoping to use some of my school loan money from summer term to build it, if I can get it all worked out right. I'm hoping to have it finished by the end of September, so I can sell the Escort and be back to only having one rig by the time school starts again next year. :aok:
Dude, you're not the only one to have this thought cross thier mind.... :beer:
hah after this summer, im expecting to see quite a few people having SASed :)
Let me correct this
hah after this summer, im expecting to see quite a few people having STARTED THEIR SAS
hahaha, not the simply overnight process many think it will be.. eh? :D
well if they stay with the nissan rear and go sua then its pretty easy and could be done in a couple weekends. (if you have done it before).
The way i did it... no chance finished by end of summer
good luck all
And that Sir, is the key. You have built a beast and gone farther than most would or want to. Just a front SAS is a bit easier, but is still not for the unexperienced. I personally, applaud their efforts.
i dont know. im betting i can get mine started within a month, and have front coils and radius arms.....finished by the end of the summer. we will see what the money situation is, and how much time i have to work on it. but i think it can be done. like what was said a few posts before, anything is possible, so dont rule it out yet
so you got a U100 axle? chev outers?
  • 1 year later...
God... I'd love to do this, but here in lil ole PA, no place to take advantage of an SAS... that and I don't have the money OR experience to do it :(
My lil IFS will have to do I guess
Dana 60 44in in pickups carrier bearings fail
Ford 10.25in 44in similar in strength to Dana 70 and 14 Bolt Full Floater
If you want something else, you'll pretty much have to change transmission, t-case and go with a different front axle. Expensive and you'll pretty much have to engineer everything yourself...steering, driveshaft, etc...
I beg to differ :stickwack:
