TopOfTheLine89
Everything posted by TopOfTheLine89
VH45 Swap & SAS Update (Merged Threads)
TopOfTheLine89 replied to tmorgan4's topic in Solid Axle Swaps, Hardcore Custom Fab
damn tyler that thing is a beast. i cant wait to get mine done! im thinking mine is not gonna be quite as radical as yours though. my suspension is not, just a good old three link in the front with panhard and a four link with a panhard in the rear with coils. im just wanting the engine you've got to jump into mine already. lol -
i had some of the same thing happen to me. i cleaned up the threads in the frame with a tap, got new, hardened, longer bolts from copper state and tah dah.
mine leaks too. i just got a box off a 91 in the junk yard and was gonna swap them, but first i was thinking of attempting to do the 40 dollar rebuilt kit on my new one just for good measure. has anyone done it before? comments on the project?
TORSION BARS COMING OUT!?
TopOfTheLine89 replied to TopOfTheLine89's topic in 86.5-89 WD21 Pathfinders
well i have my old t-bars but will it change the lift cause right now i have calmini t-bars which are a little thicker. what "keys"? are you talking about the anchors? I havent had any time to tear it down yet so maybe this or next week end I will rip everything apart and see whats going on. I have a parts pathfider that I can take any parts I need from, so I prolly dont need to buy anything. but thanks -
Im in the same boat as lowrider. IFS is all crapped up and I want to wheel it hard. how much money is it to SAS. how hard and where do I get parts?
how much money would it be to do a SAS on a 89 SE? How hard is the swap/install? where do I get everything I need for parts? I want to go higher! Current. 3in BL; 3in Calmini suspesion lift. thorley headers. 33 12.50 bgf Muds
I got a 89 SE im thinking about doing the SAS. after everything's said and done what am i looking at price wise and how hard is the actual swap., ( stand alone toolbox mechanic.) where can i get everything to do the SAS?
DiD it pop in and out again? Guess what! this exact thing happened to me yesterday. I was wheelin down this creek and my front driver-side tire fell in this hole and the same time i heard a loud crack/pop and while I drove out of the creek and my tire rubbed like crazy my pathy was leaning to the left about to squish my front left tire. I had to reidex my torsion twice on the trail. I have calmini's suspension lift with HD torsion bars. I had the same problem with the reverse torsion and what I had to do to get it so there was not pressure was jack up the truck and then jack up the lower A arm until there is no more reverse pressure; take the anchor arm off and drop the tire back on. Along with that I bent a tie rod and my alignment is a joke. if you need any more adivice let me know. Im dealing with this today so ya.
So i went four wheeling after finally getting my 3 inch body lift and my 3 inch calmini lift and my brand new 33 12.50 BFG muds on, and guess what? something breaks. Well nothing really broke but my torsion bars actually popped out while bouncing over a couple holes. So After having to reidex my driver-side torsion bar in the rocks and sand, it popped out again! so again put it back on there and didnt have anymore problems after that. but my truck is crooked and I am about to go fix the torsion and alignment but I had a few ?s before starting. 1. Should the anchors to the torsion be flush against the cross-member?, or should there be space in between the anchorr and Xmember? 2. Has anyone else ever had this happen to them? 3. how do I make sure this never happens again? ( besides SAS which I might do.)
wow. is that bumper compatible with a 89 SE?
should the anchor be tight up against the cross member? I recently just put the calmini lift on my 89, and the front of my truck is squatting down in the front, a lot. since I was putting new torsion bars on, I didnt have any where to start from so this write up was only partial help. . the first time I put the t-bars on, the anchor would not go all the way up to the crossmember so I had to re-adjust it so the anchor would go all the way up. but I think I over adjusted, and now I am just confused so if someone has dealt with this before I really could use some help.
how do i take the shifter boot off? manual SE 89
stock gear ratio HELP!(tried searching)
idk if it is LSD or not. it is just stock. I am prolly just gonna swap the third member. -
i just put headers on mine and have yet to do sn oil chsnge with them on... what am i up against?
every once in a while about every 5th time i drive my temp gauge and fuel gauge stop working... how do i change that regulator and where can i get it?
I need serious help with this
anyone one else got a thought? or the calmini directions? -
so i bought a parts pathy that had the calmini lift on it and I am in the process of putting it on my pathy but i dont have the directions but ive done alright up until now. I have no clue how to put the torsion anchors at the right angle and both at the same angle before tighting it down. right now its on but its WAY off. one side i could tighten the anchor all the way up to the cross member but the other side i have tightened as much as i could turn it but the anchor doesnt even fit up to the cross member. if some one can help me with directions or who has done the lift before i would be very grateful as my truck is on jack stands until i complete this. unfortunately it is also my daily driver...
sorry still learning the Lingo...."LSD?" -
Calmini Suspension Kit - Anyone Know About It?
TopOfTheLine89 replied to pathy689's topic in The Garage
can someone please tell me how to take the t-bars completely off? i have an 87 pathy with the calmini lift on it and and I want to put it on my 89. thanks -
3rd member diference in 87 auto and 89 manual
thanks everyone for the info. i found the plate on the inside fender and the 87 auto and the 89 manual bot have HG43. kinda a bummer cause i thought if the 87 had 4.6s the i could regear my manual to a little better gears but i guess that means the swap is gonna be easier.. thank you again... btw.. im currently stuck. im trying to take the calmini lift off the 87 and put it on my 89 but i dont know how to take the torsion all the way off... is says in the how-to to reindex the t-bars but icant seemed to get them off in the front. okie dokie.. let me know! ps i should be putting pics up soon too. -
okay and if I wanted to switch the whole third member locker and all from the 87 auto to my 89 manual I would have to switch the gears in the front as well? would this be a good move because im gonna go 33 12.5 BGF muds. -
if the gears are not the same... can i still use the same locker? -
I did my exhaust last week! ive got an 89 with Doug Thorley Headers going to 2and a quarter Y-pipe. from there I got 2 and a quarter through the cat and 2.5 from cat to dynomax turbo mufler! alls well ends well. 3" chrome tip. SOUNDS AWSOME!!!!!!
