NPORA header pic
88pathoffroad
  • Replies 154
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Precise1 Posted on Dec 4 2006, 11:01 AM
  Hey now, if you have ever high sided a Panda, you'd wear protective gear too !!!
B, What you do in your free time is your business... In this case its TMI!!!! :hide:
Well, I figured if we did something like that one we could change it every January with the past years winners... you just gotta win December's :P
I can resize, do you mean height, width, or file quality?
:lol: I made it 1028 wide... my bad :X
Perhaps we should find out what res. people are running at...
I can remake that for 800x600 screen (so there is no loss in quality, as there is when an image is simply resized), but as with the others it will look small for many of us :shrug:
:blink: whoa, forgot what 800x600 looks like. I have become so used to 1280x1024 with my 17in CRT and now 1440x900 with my 19in LCD
I'm probably killing 88 with my questions about the forums software, but...
Does it (forum software) allow for custom header displaying based on the resolution detected/reported by the browser requesting the page?
IOW, can it automatically display a smaller of larger header so that it "fits" any give screen?
Well you can change the CSS to instead of giving the header a definite pixel amount, you can use a percentage value, so not matter how big someone's screen is, you can set it at like 75% or something along the lines of that.
By the way, I must say, the new header looks good. Much better than the last, as the letters were hard to see.
Just took a look at the source and it would be an easy fix.
Currently, the html is :
<center>
<img src="http://hosting.damagedreality.com/redpath88nporaheaderpic2.jpg">
</center>
You can add a div tag and give it an id and then up above where all the CSS is displayed, add the style. For example:
<div id="headerpic><img src="http://hosting.damagedreality.com/redpath88nporaheaderpic2.jpg"></div>
And add in the CSS:
#headerpic{ width: 75%; text-align: center; }
I removed the <center> tags in the HTML and added them to the CSS, since <center> tags in HTML are no longer the best way to format in compliance to W3C standards.(If you have no idea what that means, thats ok.)
This is what I do for a living, so if anyone has any ?'s, I'd be glad to help out.
Edited by DJ Dank
<center>
</center>
And add in the CSS:
:huh::clap: Wow, I wish I could do that! :laugh:
The header is still rather large in my window, and to view it I have to scroll sideways
Edited by Jdpathy
heh, where were you when I was arguing with the header I made? That was a learning experience!! DJ, is there a way to make my file smaller, but not kill the quality??
Hmm, I must have missed that. :P
Well I always use the Save for Web feature in PS. That way I can compare the original to the modified file, side by side and see how much the quality has depreciated. PS does a good job with preserving file quality and decreasing file size at the same time. Example:
Here's an original JPEG at 172kb:
And here's the same picture thats been modified the way I just mentioned and its only at 45kb. Doesn't seem like the quality has been decreased as much as the file size, does it?
