k9sar
Everything posted by k9sar
  1. don't you need the '01 rather than the '96?
  2. mine was filthy after about 70k miles. Of course, I was living in the desert southwest at the time. It all depends on how much crap you let through your air filter. Use a good quality one and don't drive in dust storms and you may never need to clean it.
  3. the corner ones look like this
  4. the rectangular ones look like this
  5. if your MAF ain't happy... your truck ain't happy. I'd check that first.
  6. k9sar
    WD21 K&N
    gonn punch a hole in the hood and add the K&N like a mutant little Christmas tree sticking up in th air?
  7. let's see... he's in the 96-04 forum and his profile says he's driving a 98. sheesh Dan!
  8. k9sar
    Heated Seats
    for your 92 XE, I believe you can consider it a spare fuse. Universal parts... I don't think the 92's even had an option of heated seats.
  9. My connector on my MAF was bad. The hood was touching the wire cause the connector had it going straight up and every time I'd hit a bump, the truck would run like crap. I finally got hold of it while it was rough and flexed the connector/wire and it made a big difference. That evening, I rebuilt the conenctor and turned it 90 degrees so it'd stop hitting the hood. no problems since.
  10. k9sar
    WD21 K&N
    I always wondered about the succeptability of an open filter like that.
  11. k9sar
    WD21 K&N
    it's out on his old site here
  12. Now that you've had it in place for a bit, how's that bracket holding up? Is it a simple 'C' shape to get you above the wiring or did you build some structure to it? With the shape, mount points and weight of 2 full PH8's, I was wondering about wobble/flex/banging on underside of hood. Mine is sitting on the bench waiting for a warm weekend (which may be soon) and I like the idea of a tray or something to stuff a rag when changing it. Perhaps I'll figure out a pivot system so I can rotate them 90 degrees before removing. hmmm..... (puts enginerd hat back on)
  13. if the engine was sitting for any length of time, I'd use cheap oil and other fluids for a break-in. Then do a good flush and replace with a good high-mileage oil. I use Castrol in mine
  14. Glad you were able to pick one up. I'll stop looking.
  15. best thing to do is get her up on a lift and start pushin and pullin on things to find out where the play is.
  16. nice idea for location Aaron, 'cept that my damned tailgate likes to hit me in the head as it is now. No need to add extra weight to it.
