Precise1
Moderator-
207
Everything posted by Precise1
Not just the weight, but the size of the boxes as well. The 94-95 is almost 3" more in the first dimension. A US gallon is defined as 231 cubic inches. Assuming a tank dimension of 20x30" with an additional 2" of depth, this equals 1200ci, divided by 231 gives you 5.19 US gallons, the missing 5 gallons. I'd bet the 80L (21ish US gallon) tank is: V6 94-95 P/N17202-61G00 16x27x37 inches 35 LBS Again, this is assuming the same foot print/mounting features for the tanks (boxes are roughly within 1" in these dimensions). B
have idea want to know if anybody's done it before
Precise1 replied to thorpe991's topic in General Forums
^ Done in one! B -
New to building a 95 pathy and new member here
Precise1 replied to Nissanland's topic in 90-95 WD21 Pathfinders
Well said, says the one who was laid off last year... There good things about being self employed, I tried to do that years back but made the mistake of having a partner. Oh well, live and learn. Snow storm in Shasta? Not a drop and hardly cloud here, it's not that far away! Good luck with the mods, don't be shy about asking for input if you get stuck. Most things are documented fairly well though. As for pictures, you need to upload them to a hosting site like photobucket (free) and then copy the direct address into the picture icon box above the text field once you have clicked on it. Pretty simple once you now the recipe... B -
Holy crap! I hope it bolts up and lasts more than 6 months! Not second guessing you, but at least with the Borla you know it isn't going to rot off... B
You can check the tranny brain for stored codes as well, but unless there is a light pattern at start up, there shouldn't be any, kind of like the CEL. Disecting the old inline filter sounds like a good plan; always try to learn... B
Whoa! Only 1/2 of bad to begin with? Sounds like something is wrong. Is there any OBD system? Can you test the O2 sensor? Does it even have a MAF? Like I said, I don't know Jeeps at all... B
^ This is exactly where I would start as well... B
Cool! I'm glad it wasn't a big deal and thanks for the heads up! I have to change the rear drum brake shoes since they are contaminated from a leaking seal, so I'll be taking all that apart anyway.. B
Who will copy a chipped key to a non-chipped key?
Precise1 replied to Towncivilian's topic in The Garage
If you can't find anyone and have a dremel and a file and a clamp, it isn't hard to cut your own. B -
Do you have it running through the radiator cooler and do you have an inline filter on it? B
Agreed! Nothing wrong with those who want to build up like that, I just choose not to on this vehicle. Yeah, I grew up on dirt bikes so 4 wheel drives are mainly for getting to where it is worth riding the bikes. Yeah, while done is a relative term, I am just finishing a last major project before winter and should have time then to spend in the garage with a wrench, a truck and a beer. I don't mind the comments though, they are just jealous. A rally sounds like a lot of fun and there are many members up that way. There is usually a run in the fall called the Mr. Jim run to commemorate the founder of the site, so keep your eyes open for when it is discussed. It is often set up so even stock rigs can participate. (7000 miles a week. Damn!) B -
Thanks for the correction, I obviously haven't removed one. This makes me wonder if the two tank sizes aren't the same dimension other than depth... B
Paying job... B -
So what changed your mind? Thanks, I try to steer people in what I believe to be the right direction. Yes, it makes sense not to beat up a mint Titan! IIRC means I'm to lazy to type things out all the time. Here is a handy list of acronyms... http://www.nissanpathfinders.net/forum/topic/9577-acronyms/ By expedition style, I mean that I'm not trying to make a rock crawler out of it, install a solid axle, jack it up as high as possible or put the largest tires possible on it. I'll be using it for daily driving, camping and general light wheeling and exploring so it needs to be robust and reliable but also easily drivable with good road manners. The kind of truck you wouldn't hesitate to drive a few states, go exploring and then drive home while living out of it. In my version of wheeling, you don't get any points for getting stuck or breaking down. Here is how it sits now in my garage awaiting rear axle seals/brakes, power inverter, gauge pod and Xterra roof rack. I've been working on my house for years and haven't had the time/energy to get it back on the road, hence all the flack I catch from people with too much time and not enough responsibility. http://www.nissanpathfinders.net/forum/topic/24287-precise1s-pathy/page-3?hl=rims I'm sorry, I'm not sure how I missed this. Thank you, I appreciate the thought, but I have an idler arm brace mounted that I bought from AC (Automotive Customisers) I believe a few people have had similar thoughts and I believe that there is plenty of room for it. I like the lock box idea and would do it if mine wasn't pristine. Nothing wrong with packing, I always am when I'm in the woods. B -
Finally some 4 wheeling fun w/ Pics!
Precise1 replied to TahoeRunner's topic in 90-95 WD21 Pathfinders
Correct. Following the chart, +32mm offset would give you 5.25" backspacing on a 7" rim. 7" wide but I have no idea about the offset, I've never owned any. From what I understand, that is a chicken and egg debate which is why I prefer using backspacing methodology. Hard to get that wrong... You are mixing up your offset and backspacing nomenclature, it is impossible to have negative backspacing. B -
I think you'll find that the vast majority of them are the 80L (21 gallon) ones. Make sure to get all the hardware and straps for the larger size tank, no counting that they will be the same... B
Yeah, the manual says you can shift on the fly at 55 MPH as well (or whatever), another thing I wouldn't recommend. B
I really wouldn't advise engine braking with an automatic like that. Having it locked in one gear and letting it run up and down in RPM is one thing but manually downshifting is really just putting a significant strain on the tranny. Brakes are far cheaper and easier to replace... B
Let me know how it goes please. I have to replace my axle seals and might jsut replace the bearings as well when I am in there... B
I rather liked the looks of those when they came out, but I know nothing about their mechanics or quality. I'm glad you got what you needed/wanted, even if it is a Jeep. We bag on Jeeps a bit, but it is more out of envy for their aftermarket support than anything else. Don't be a stranger Bud, you are always welcome here. B
Anyone ever had a coolant leak from the exhaust manifold bolts?
Precise1 replied to rlg999's topic in 90-95 WD21 Pathfinders
Yup, sounds like you did it right. Yes, it should last a lot longer than 180k, and the only thing that went wrong here is you having to fix what some careless PO did. It isn't like something failed... B -
I'm glad you got it figured out, but I don't understand how slight brake drag would cause "some crazy sounds like tapping and wobbling heard from the drivetrain". B
Offset is the deviation of the mounting surface from centerline of the rim and backspacing is the distance from the mounting surface to the back of the rim. This chart should explain... B -
Yes, many people who install a body lift remove the lower piece (if they don't relocate the radiator) and it hardly affects the cooling at all. I'd be surprised if it was making any significant noise though... B
