Precise1
Moderator-
207
Everything posted by Precise1
Hot exhaust..melting carpet..carpet on fire!
Precise1 replied to SteeevO's topic in 90-95 WD21 Pathfinders
Yes to the fire extinguishers (having them, what kind, how to use, etc) and I'd guess that it was an exhaust leak at the Y that caused the problem. B -
Thats a definite maybe. There is no exact equasion to this, just like you may not get 3" lift in the rear from the coils. Count on 2-2.5" all the way around, and see what you get... B
So, whats the deal ? B
Ok, I'll bite... Quite frankly, I don't care what you celibrate as long as it doesn't interfere with my sleep, block my driveway or get blood/paint on the lawn, etc... Enjoy your holiday with all the dignity it deserves and remember to be courteous to others ! Best wishes for 2006 !! B
Yeah, I keep 2 spares also and that hasn't been enough at times !! I like V6's thought of a patrol tank installed (26 gallons I believe). B
LOL, I've spent 2 months camping and snorkeling in Baja... It's not THAT bad !!! Water, vehicle and weapon will see you through most anything !! You can just never afford to make any real mistakes... I miss it though and due for another trip !! B
Another steering wheel issue, '95 5spd
Precise1 replied to prginocx's topic in 90-95 WD21 Pathfinders
Yes to all of the above, and hand tight is fine... You need one of these filter wrenches. This one grips harder the more you rotate CCW and is entirely made up of 1/8 or 1/4" steel, 3/8 ratchet drive in the rear. Pretty cool item for an oil filter wrench... B -
Horsepower is a remarkably poor measure of off road ability... B
I'd guess going too slow, using too low of a gear and/or poor traction. B
2mm, dime sized and 4 miles long !!! Wierdo !! Here, this has 3 threads that apply. Regardless of which you choose to use, just be sure to treat the rust, and not just paint over it... http://npora.ipbhost.com//index.php?act=SF&f=26&st= B
Thanks for the input QuismO. I agree, the volume of information here is enormous and it is definitely the members who make the site what it is. :cool2: B
I got a used one for $150. That shop is jacking you around, go somewhere else... B
This may help some... http://www.nissanpathfinders.net/forum/index.php?showtopic=6486 They are a fairly common item, searching at your preferred Auto Parts site should turn up results. B
LMAO !! Um, we are here (other than to have fun) to help, not beat a solution into him... Yes, I could see some of the plastic by the steering wheel rubbing... Go take a look. B
Ok, so what have you tried ? For lack of better answers... pull a plug, put the wire on it and hold to/near the motor. If you get a fat blue spark or a zap good enough to inspire the macarena, your coil is fine. That would mean distributor on down... Any answers are helpful. B
Automatic I assume ?? SE or LE package ?? Have you checked the fuse or the lamps, for either ?? No, they shouldn't be linked. B
Yes, the wheelbase is the same for 2 door and pre96 4 door's. Never having wheeled them together in a shoot out, I suspect the WD21 with a SE package (Including factory 31", adjustable shocks and LSD) would be the most off road worthy in stock form. Then, as I'm fond on saying, it's 1/2 the truck, 1/2 the driver; we've all seen enough internet videos and photos to agree on that (much less first hand experiences) !! B
Yes JJ, it is new to me also. The steering angle adjustment "is adjusted by stopper bolts located on the inside of the steering knuckle/spindle. Loosen the lock nut on the stopper bolt and turn the bolt in or out to obtain the the proper maximum steering angle..." When it stops raining, I'm going to look at this... B
LOL, not if the motor wasn't cranking... Look, once you have the motor cranking over and know you have spark, you can worry about the fuel... One step at a time. Of course, putting some gas in it could be required when you get there. Sorry, I don't have/have never worked on an R50, but I'm guessing the starter is down low on the passenger side ?? Well, I feel better, Pezzy has no clue and she ownes one... :o B
Very well could be. Not hard or costly to fix either (generally). B
The insurance is for the value of the vehicle before the damage... I'd take $7k for my 95XE with 115k on it, then buy it back and have a field day... *sigh* Wishful thinking... I'm glad mom got what she wanted, that will keep everyone happy... B
Sorry, we overlapped posts there... Ok, the motor will not crank but you have power to everything else. Make sure the starter/selenoid is getting power... I'll look for a thread about a 'hot wire' test. B This isn't the one, but it may help you... http://npora.ipbhost.com//index.php?showto...l=test++starter This is the one, try it... http://npora.ipbhost.com//index.php?showto...l=jump++starter
Damn, I'm sorry, that is what my truck does with the bent frame horns... Sucks, don't it !! I'm assuming your slashes represent top down view. I'd wonder if that Cl isn't bent or buggared... It sounds like the geometry is off, but I hesitate to guess. I don't remember anyone else ever mentioning anything like this. There is a steering angle adjustment, seems to me like if thats off, it'll throw the tires out during turning while aligning straight. I doubt most shops check, adjust that; they just look at camber, castor, and toe. The steering angle adjusted + toe out maximum + minimum positive camber + minimum positive castor would help (If I'm looking at this right). You have a manual ? Study up on this and ask a 4x4 shop what they think... B
Absolutely nothing ? A rapid clicking noise ? The motor turns over, but slowly ? B
