Everything posted by dagwoodzz
There was a topic a few months back about brush guards causing more damage than offering protection in an accident. Were you wearing yours? Just curious if this is an Urban legend or causes more damage than had you not had one.
lime green with liciense plate "WITH NV" j/k I like Nissan Red!
Another post reminded me of this one. The stock sunvisors have good instructions on the back side how to engage and disengage 4wd. Attention to Detail or required by law? Not really sure.
If you have the stock sunvisors, push down the drivers side visor. There are pretty good instructions on the back side. Recommend he stop, read, and think the first 3 or 4 times he engages 4wd. It becomes 2nd hand after that. Let me know if you don't have the visor. I will post a pic that you can print out.
Sad but true. I've lived in 4 different states and have only taken one written and one driving test my whole life. I'm 36 now. Go to the DMV give 'em your old license and they keep giving you a new one. I'm sorry for not asking how the family was earlier. I do hope they continue to be well.
The only time me starter died was right after an oil change. Gotta put a rag over it before you pull the filter. keep it clean, gravity hates you! overheating how long? how old is the T'stat and H2o pump? I did notice about two weeks ago we got our 1st hot summer days. 95deg+ the temperature gauge goes almost to halfway point now. Used to hover around a quarter of the way up. It was a noticeable difference. Not overheating though.
Check the light in the trunk and glove box. You might have to look at it at night. Cost me $75 bucks once to be told my glove box light wasn't turning off. The fix was to remove the bulb. Tallk about feeling stupid!
Do you currently have a sunroof? I looked into it once before, but it was not possible. My '87 did not come with a sunroof. The one I found in the J/Y that was a factory installation. The factory installation has a pressed opening that I couldn't duplicate. If you do have the factory pressed opening and the measurements are the same you should be good to go.
Sound like some skid plates might be up for sale. No kidding every time my wife drove my Chevy truck, she broke something. she won't touch the pathy
I would call the police and report it stolen. Tell them the story. Legally speaking the Landlord is holding property that belongs to you. I don't think it would be grand theft or anything, but they might have a way to allow you to legally enter the property to obtain your stuff. I would meet the police at the shop with a chain and a side grinder. See if they would let you make entry on the property if you promised to secure it when you left.
It would be nice to have a post devoted to Acronyms for reference from time to time. I just threw a couple of common ones out there. Please feel free to correct me. Also, please post the ones that come to your mind or PM me. I will edit the 1st post to include what you've added and keep them alpha/numerical order. Not that I am looking to maintain a "G" rating, but would like for this post to be useful. If a suggestion gets too stupid or plain vulgar I won't edit the post. You will have to start your own post. Hope you find it useful, interesting and maybe even fun. Here we go! Technical: 5MT = 5 speed manual transmission 6MT = 6 speed manual transmission 4EAT = 4 speed automatic transmission ABS = AntiLock Brake System AC = Automotive Customizers www.4x4parts.com A/C = Air Conditioning ASE = Automotive Service Excellence AT = Automatic Transmission ATF = Automatic Tranny Fluid AWD = All Wheel Drive BDC = Bottom Dead Center Bhp = Brake Horsepower BJ = Ball Joint BL = Body Lift BTDC = Before Top Dead Center CAI = cold air intake Cat = Catalytic Converter CEL = Check Engine Light CF = Carbon Fiber *or* Cubic Feet CFM = Cubic Feet Per Minute CL = Center Link CV = Constant Velocity CVT = Continuously Variable Transmission DS = Drive Shaft Diff = Differential DIN = The standard radio slot (about 7"w x 2"h) DOHC = Dual over head camshafts Dyno = the “rolling road†where a vehicle’s power is tested ECU = Engine Control Unit EFI = Electronic Fuel Injection EGR = Exhaust Gas Recirculation FMIC- Front Mounted intercooler FSM = Factory Service Manual FWD = Front Wheel Drive JDM = Japanese Domestic Market HID = High Intensity Discharge Headlights HP = High Pinion or Horse Power IA = Idler Arm IAB = Idler Arm Brace IAC = Idle Air Control Valve IB4TL = In Before The Lockdown IC or I/C = Intercooler IFS = Independent Front suspension IRS = Independent Rear Suspension (or Internal Revenue Service) JGC = Jeep Grand Cherokee KPR = Kilometers Per Hours Kw = Kilowatts (like HP in the metric system) 1kw = ~1.341 HP LCA = Lower Control Arm LHD = Left Hand drive LSD = Limited Slip Diff LP = Low Pinion MAF = Mass Airflow Sensor MAP = Manifold Air Pressure MPFI = Multi Port Fuel Injection MPG= Miles Per Gallon MPH = Miles Per Hour MTF = Manual Tranny Fluid MT = Manual Transmission NOS = Nitrous Oxide Systems NGK = maker of spark plugs OEM = Original Equipment Manufacturer O2 = Oxygen PA = Pitman Arm PB = P'Blaster PCV = Positive Crankcase Ventilation (valve) Pot = number of pistons per caliper (ie: 4 pot brakes) PS = Power Steering (could mean Post Script) PSI = Pounds per Square Inch PTO = Power Take Off system RP = Ring and Pinion RHD = Right Hand Drive RPM = Revolutions Per Minute RWD = Rear Wheel Drive SAE = Society of Automotive Engineers SAS = Solid Axle Suspension SC or S/C- Supercharger Speedo = Speedometer (or men's wear) SOHC = Single over head cams SYE = Slip Yoke Eliminator SL = Suspension Lift Tach = Tachometer TBI = Throttle Body Injection TB = Throttle Body T-Belt = Timing Belt TBar = Torsion Bar T/C = Turbocharger TC = Torque Converter TCU = Transmission Control Unit TCM = Torque Control Module TDC = Top Dead Center TMIC = Top Mounted Intercooler TPI = Throttle Port Injection (or tuned port injection) TRE = Tie Rod End T-Stat = ThermoStat TSB = Technical Service Bulletin TT = Twin Turbo or Turbo Timer TCase = Transfer Case TPI= Threads per inch TPS= Throttle position sensor UCA = Upper Control Arms VC = Viscous Coupler VIN = Vehicle Identification Number VVT = Variable Valve Timing WMS = Wheel Mounting Surface Whp = Wheel Horsepower Specific to Nissan Models: WD21 = 87-95 Pathfinder R50 = 96-2004 Pathfinder R51 = 2005-up Pathfinder D21 = 87-97 Nissan pickup D22 = 98-up Frontier H233B = Hitachi 233 B (as opposed to A, B is most common)(V6 Pathfinder rear axle) R200A = V6 Pathy front differential SC = Supercharged ( R ) R also means oversized turbo when used next to T or TT SOHC = Single OverHead Cam DOHC = Dual OverHead Cam OBD II- On board diagnostics system (95 and up) Also refers to the newest emissions standards TD27T = Nissan 2.7l diesel engine VG30i = 87-89 3.0L V6 Engine (TBI) VG30E = 90-95 3.0L V6 Engine (MPFI) VG33E = 96-00 3.3L V6 VQ35 = 01-05 3.5L V6 VK56DERRTT = VK series 5.6L DOHC direct injection SC'd, oversized twin turbos The VQ35 came in... (not limited to) (First set of numbers is HP, second is torque) 2001+ Pathfinder VQ35DE/240/265 2002 Altima VQ35DE/240/265 2003+ 350Z VQ35DE/190/205 Non Technical: AFAICT = As Far As I Can Tell AFAIK = As Far As I Know AKA = Also Known As BFH = Big Freakin Hammer BOHICA = Bend Over Here It Comes Again BS = Back Space (or Bull $hit) BTW = By The Way DD = Daily Driver DIY = Do It Yourself FS = 4sale FSM = Flying Spaghetti Monster FTW = For The Win FUBARed = F'ed Up Beyond All Repair FYI= for your information HW = HomeWork IBMS= I bruised my spleen IDB = In Da Butt IIRC = If I Remember Correctly IMHO=In My Humble Opinion IMO = In My Opinion KISS = Keep It Simple Stupid LOL = Laughing Out Loud LMAO = Laughing My Ass Off MSIB2 = My Spleen Is Bruised As Well NA or N/A- Naturally Aspirated NSFW = Not Safe For Work NWS = Not Work Safe PITA = Pain In the A$$ PHDTS = Push Her Down The Stairs PM = Private or Personal Message POHO = Post Whore (A place to shoot the breeze. everyone's welcome. Nothing serious please.) POS = Piece of $hit ROFL = Rolling On Floor Laughing ROFLMAO = Rolling On Floor Laughing My Ass Off SNAFU = Situation Normal, All F*cked Up SOL = $hit Outta Luck TB = Trail Bitch... (anyone in the passenger seat) TLA = Three Letter Acronym TWAN = Tool Without A Name TYVM = Thank You Very Much TYVMAH = Thank You Very Much Ahole WFO = Wide F'ing Open WTB= Wanting To Buy WTF = What The F$$k WOT = Wide Open Throttle (maybe technical vs non) W/ = With W/O = with out Us being Us: supr3m3 h4x0r 43v3r = Homage to '88 88 = Aaron, Forum Admin B = Precise1, Moderator K9= Pezzy Stalker Slick = Postwhore Dowser = TNZ=TerranoNZ Cheese Whiz = Any dork dating Casey's daughter
On mine the wire was ran from roof lights to floor. The driver seat was already removed, so I ran wire under the carpet along the door. This was easier than doing it right (along the door sill as you mentioned). The seat made for a convenient ground where it bolts to the floor. What you have going sounds good.
Thanks for reminding me at 36 I am closer to 40 now than to 30. :oops: Coasting downhill and picking up speed!
Not to pile on Jay, you appear to have a million ideas but are only working on one or two of them at a time. Focus your energy on the one or two things you have control over, post pics of the progress. It gives others the satisfaction that they are in the garage helping you. You and I are alike in some ways, with exception of age. I'm and old fart. I have a pathy, some good knowledge, but limited resources and not a lot of practical experience. I've found that I get more help and insight when posting about present projects than future projects. People just seem to be more interested in the NOW stuff than the later stuff. Don't take things personal, if someone gets under your skin with a post. Do not reply. That's an invitation for a pile on. my $.02 Regards, Daniel
Distributor in the front of the engine. The front lip on the ashtray can be used as a bottle opener -alcohol-
Aw Shucks Guys, I'm tearing up. :sniff:
See if this helps The door latch mechanism is the circle at the top. The power door lock is the circle at the bottom This is the power door lock. the rod with the arrow need to go straight up to unlock. With the passenger seat removed you should be able to get your hand in the hole and pull the rod up. This is mechanism that opens the door. In this photo it is in the down position. (closed) In this photo it is in the up position. (open) Hope that helps. Either way your in a tight spot.
Can you edit the title of your post? I'm going to want to find this again but the search function might have trouble finding it. BTW, looks like your on to something good!
Jack Link This is what I have, it has plenty of lift capacity and works fine. My biggest gripe is the total lift is not much. Constantly being placing on blocks to get enough lift. It was not much help when changing out coil springs. However it is cheap and can quickly get a tire off the ground.
My '87 had a quirky passenger door lock when I bought it. If you would lock it from the inside, you could only unlock it from the inside. If you locked it from the outside you could only unlock it from the outside. Weird. One day I got mad and locked the and unlocked from the inside as hard as i could about 20 times. It has worked right ever since. I know this doesn't answer your question, but the experience was similar. Perhaps some forceful persuasion can get it to free up.
Great job, and write up as well. How visible is it from the driver seat? Is it a distraction or just a mod that has to be gotten used to?
Previous thread on Timing Belts My water pump/timing belt was $420. A backyard mechanic did it for me. Dealer might be little more. He's got to cover his real estate and insurance.
My only gripe is I wish you could search all forums with the exception of Off-Topic. I find a lot of my searches will find 2 or 3 topics relative to my search, but about 30 off-topic political debates. Oh well, when searching you get out of it what you put into it. I'm happy
