8
Everything posted by SilverPath
Ive been running Silverstat Ultras for a couple years. Seem to be fairly bright with a hint of blue aswell. Not sure they compare tot he PIAAs
Heh, you aint kidding about the for less part. I got pulled over having a tinted license plate cover..... and I see everyone with them on now... Anyway about them CBs
The firestick is only like 1cm wide, so you can barely tell its there once the brake light is on.
Did you give your cat a Lion cut?
Warn M8000 Self - Recovery Winch Installed
SilverPath replied to OfftourRoadie96's topic in 96-2004 R50 Pathfinders
Looks good, glad to see the required bottle opener on there -
I mounted my right to my rear bumper, Its out of the way, and its on a spring if it gets hung up on anything. Mine is longer then 3' however, so it sticks above my roof giving me a relatively low SWR reading.
Trail Gear Rock Sliders on R50
SilverPath replied to SilverPath's topic in Solid Axle Swaps, Hardcore Custom Fab
Looks good mang. Now go beat them up -
Yea I use Simplecenter, works wonders also.
AC means Automotive Customizers. Its just a name brand lift sold at http://www.4x4parts.com/nissan/
Yes, the AC lift doesn't move the subframe any. Just the suspension. When you do the SFD is when you need custom plates.
I know what you mean. I could use one also.
No problem Sadly there are not many options If you have an LSD you can pack more clutch plates into the unit which gives it a higher breakaway rating. Super packing I believe there is a Lokka for the front diff also. In terms of lockers.
He is working with Lock Right, coming out soon(ish)
Finally started it up, thanks to the optima battery there was no delay. Drove it around the block to get its once a month leg stretching and parked it back in the back yard.
I know how that goes. It took me a little bit the first time I took my drive flanges off. They get stuck pretty well. Had to use a mini sledge to break them free
I'm taking a class on the 9th that will let me get my Utah and OR CCW. Will see how it goes.
While that holds true for a lot of places down here I would rather have it and never need it, then need it and not have it on me.
Excuse my I guess it was raised to $55.25 in '10 heh. Anyway While I agree. some take classes. Alaska doesn't even require a Permit, so anyone can carry as long as they are legal. (Not that that stops anyone that isn't)
Yea, Salvage means a lot of things as stated above. My brother has a ranger with a reconstructed title, only because it has a new engine. The ex-owners slipped it in gear before pulling it behind their motorhome and destroyed the motor. So look into it.
yea its $50 here, no class needed. Now the chore starts to get my non-res through OR which is a hassle
I kind of like the Ellure. Nice and sleek
meh, 6.8 spc is for sissies. You need an AR in .50 Beowulf
The hiking one looks fun, the bike, eh I'm good.
Piaa 1500 Back-Up Lights Installed
Yea pretty much, just find the hot wire when the reverse lights are on and tap into it. Though depending on how much they draw you may want, the stock reverse lights to switch a relay on which turns your top lights on. -
Must See: Lizard Lick Towing And Recovery (All Worked Up)
SilverPath replied to unccpathfinder's topic in Off-Topic
Its fun to watch, I used to watch the OP Repo show, it was cheap amusement when I wasn't doing anything. Watching the Rhino try to fight was great.
