fleurys
Vendors
Everything posted by fleurys
  1. The issue comes from the auto mode. When your hubs are unlocked, you cannot leave it on auto because of the way the transfer case works. Since it is a shift on the fly type, you can imagine what kind of carnage it would do if the transfer case was to engage the front while nothing is turning in front and that the rear is rolling at 50mph... That's it really... The hype came from the fact that at one point I assumed the mechanical oil pump for the transfer case was being activated by the rotation of the front driveshaft... It was finally proven that it is from the rotation of the rear (main) driveshaft..So there is no problem between the transfer case and manual hubs... simply have to use it with either 2wd unlocked and 4wd when locked....no more auto... Here's the post that started it all : http://www.nissanpathfinders.net/forum/topic/25855-locking-hub-install-with-pictures/?p=475352 then a nissan mechanic (morpheus) put that assumption to rest here : http://www.nissanpathfinders.net/forum/topic/25855-locking-hub-install-with-pictures/?p=475399
  2. You can reindex the front and install spacers for the rear. I can help with the spacer. Click on my signature. For the front there is a good post on it here. Envoyé de mon iPad en utilisant Tapatalk
  3. That would be great .. Please go ahead . Thanks Envoyé de mon iPhone en utilisant Tapatalk
  4. R50 Crosslink, Mid Skid and Rear Skid PreSale -Ends December 31st- https://r.tapatalk.com/shareLink?url=http://www.nissanpathfinders.net/forum/index.php?/topic/42686-R50-Crosslink%2C-Mid-Skid-and-Rear-Skid-PreSale--Ends-December-31st-&share_tid=42686&share_fid=45554&share_type=t Envoyé de mon iPhone en utilisant Tapatalk
  5. Thank you ! Envoyé de mon iPad en utilisant Tapatalk
  6. I do not have a SFD installed neither did I found installation pictures of what I am looking for. In this picture, can someone confirm me that the some of the SFD blocks goes under there ? I know there is one block under the Sub frame near the tie-rod (on the left in the picture), but I just want to make sure there is also one that goes in the red circle... Does anyone have a few good pictures of this ? Tks.
  7. Actually, the Crosslink and even the mid skidplate would fit without modification. The 2 other plates would need to be customized. I already sold a front SFD skidplate to a few members here by special order. As for the rear, I did not do it yet but it should not be a problem. If you are interested, let me know by email or private message. Steve. (sfcreation<@>yahoo.com without the quotes)
  8. Let the fun begin... :-) http://www.nissanpathfinders.net/forum/topic/42686-r50-crosslink-mid-skid-and-rear-skid-presale-ends-december-31st/?p=783943
  9. The Time has come... I'm offering you to be the first to receive my newborns. These new products will be available for the new year but exceptionally, I am offering them to the NPORA community first. Here's your chance to go offroad with a completely different set of mind knowing you're not going to bust an engine or trans oil pan or a front driveshaft, diff etc... This makes a huge difference between being stressed out and being zen during the trail. Like I mentioned on another post, even if you do not rock climb with your pathfinder, I have seen , more than once, a simple branch going through an oil pan during a trail. You can imagine how this can turn a nice trail day into a nightmare. I have 3 new products to offer. They are: 1) Control Arm Crosslink. This item will serve two purposes.First to stiffen the front by linking both control arms, then to serve as a solid platform for the mid and rear skidplate. Complete Description and pricing at the bottom of this post. 2) 1/4" Aluminium Mid Skidplate. Connects on the sub frame in the front and to the crosslink in the rear. Protects Front diff and engine oil pan. YOU WILL NEED THE CROSSLINK TO INSTALL THIS SKIDPLATE. Complete Description and pricing at the bottom of this post. 3) 1/4" Aluminium Rear Skidplate. Connects on the crosslink in the front and to the trans. crossmember in the rear. Protects complete Transmission, Front Driveshaft, Front ujoints, Transfer Case.YOU WILL NEED THE CROSSLINK TO INSTALL THIS SKIDPLATE. Complete Description and pricing at the bottom of this post. Listening to the members here, I have decided to offer everything either raw or Powder Coated. One very important thing to note is that raw aluminium is rarely free of scratches when the plates are delivered. This usually happens during the handling and transport before they even get to me. After a few complaints of unknowing clients, this is when I decided to powdercoat everything. The scratches are usually on the surface and not very deep. But it has happens once or twice where I needed to sand the plate before powdercoating it. This means that surface scratches will be present and if there is deeper ones, I will sand them in order to make them look better. So the RAW ALUMINIUM Option will possibly have surface scratches and/or sanding marks. There is not much more I can do on that subject :-) I have made a serious effort to lower my prices (with the design and also for this special one time only offer). SHIPPING IS FREE FOR USA AND CANADA.. So please consider this in your comparison with other products. It is most likely that the prices will be adjusted (read higher) when they get posted on my website in january 2017. For those who already bought my front skidplate, these new products are compatible with it. For those who already bought my crosslink in the past , then you will still be able to fit the mid and rear skidplates but you will need to drill new holes in them since the spacing is different between the old and the new crosslink. If you need more details, please send me a private message or get in touch by email at sfcreation<@>yahoo.com (without the brackets). The preSale is open from now to December 31st. The fabricating will start on January 9th (because of the construction workers winter vacation) and depending on the options taken, the first items will start shipping before the end of January. The shipping is insured and tracked. The tracking number will be communicated to you when your items ships. I will use this post to list the members that have ordered. It will be an easy way to confirm the items you ordered and also the state of the fabrication and shipping. Instead of updating everyone individually , I will post the state of the different steps in here. Finally, you can see a few of my trail test in the past on my personal youtube channel https://www.youtube.com/user/fleurys2.. I have been running these skidplates since 2010 and my truck never suffered any breakage from hits on rocks.. I know these are probably the best investment you can do to your truck if you go offroad. Procedure to ORDER: Send me EITHER a private message here or an email at : Sfcreation<@>yahoo.com (without the brackets) with the following information 1) Full Name 2) Your NPORA member name (ex: mine is fleurys) 2) Full Shipping Address 3) EMAIL ADDRESS that your paypal account is linked to. (This is where I will send the paypal invoice) 4) QUANTITY and OPTIONS of the products that you want 5)*** I only Ship to paypal confirmed address. Make sure that your shipping address is correct when doing the paypal payment*** From there I will send a paypal invoice. Once paid I will add your npora name here, in this post, with the items your ordered and the status within 48 hours. In order to be part of this presale, the payment must be done before December 31st. NAMES OF LUCKY BUYERS: 1) CORNPONE99 - 2 Stickers - Front Skid Powder coat - Mid skid RAW - Rear skid RAW - Crosslink RAW 2) PISTE - Crosslink Powder Coated 3) RICHMOND - Crosslink Powder Coated 4) RANGERPATHY - Mid Skid powder Coated - Rear Skid Powder Coated - Crosslink Powder Coated 5) BLACK = IN STANDBY ORANGE = IN FABRICATION BLUE = AT POWDER COATING STATION GREEN = SHIPPED (Check you emails for tracking number) Here are the details and price of the products: 1) Crosslink 100$ RAW STEEL (Optional Black Powder Coated Finish +15$) This Crosslink's primary function is to increase torsional stiffness of the unibody of your pathfinder. You will immediately feel the benefits of this with improved steering response and reduced body rattles. The second function of this Crosslink is to serve as a point of attachment for our mid and rear skidplates. Built from 3/16" steel all around and 5/16" Support tabs, this link will not break. It has been overbuilt in order to provide an unparalleled solid platform for our mid and rear skidplates. Recessed to the maximum, this crosslink is as high as possible in order to keep maximum clearance. 13 Lbs 2) MID skidplate 155$ RAW ALUMINIUM (Optional Black Powder Coated Finish +20$) This skidplate will protect the very exposed engine oil pan and front differential. It attaches to the Sub frame in the front and to the re-inforced crosslink (sold separately) at the rear. Light and resistant, this plate will protect expensive drivetrain parts from rocks and off-road mishaps. It is independent from the front skidplate and does not requires it. PLEASE NOTE : The Control arm Crosslink is necessary in order to attach this skid plate. It is not included with it. 1/4" 6061-T6 Aluminum Only 10 Lbs Bolt on installation - no drilling or cutting Powder coated black for a top notch finish as an option ** ** SYMMETRIC AND FULLY REVERSIBLE- IT'S LIKE HAVING 2 PLATES IN ONE IF IT BECOMES TOO SCRATCHED *** What's Included: 1x Skidplate 2x 1/4" spacers ** To be used with the front plate , If present *** 2x M10x1.25 Grade 8 Bolts and washers (front Bolts) 2x 3/8"/16 Zinc plated Bolts and washers (rear Bolts) 3) REAR SKIDPLATE 235$ (RAW ALUMINIUM + RAW STEEL (BRACKETS) (Optional Black Powder Coated Finish +30$) This skidplate will protect the very exposed Transmission oil pan, Transfer Case and Front Driveshaft and Ujoints. It attaches to the re-inforced crosslink (sold separately) in the front and to the Transmission Crossmember at the rear. Light and resistant, this plate will protect expensive drivetrain parts from rocks and off-road mishaps. It is independent from the front or mid skidplate and does not requires it. PLEASE NOTE : The Control arm Crosslink is necessary in order to attach this skid plate. It is not included with it. 1/4" 6061-T6 Aluminum Only 20 Lbs Bolt on installation - no drilling or cutting Powder coated black for a top notch finish as an option ** ** SYMMETRIC AND FULLY REVERSIBLE- IT'S LIKE HAVING 2 PLATES IN ONE IF IT BECOMES TOO SCRATCHED *** What's Included: 1x Skidplate 6x 3/8"/16 Zinc plated Bolts and washers (rear Bolts) 2x 3/16" steel Brackets For the installation part, I am working on producing a video where I will show how to install the whole sets of skidplates. It will be available before the plates ships. :-)
  10. What about the crosslink? Would you all prefer grey or black primer versus powder coat in order to save 10-15$ ? Envoyé de mon iPad en utilisant Tapatalk
  11. I guess it's a possibility, but you need to know that raw aluminium sheets have regularly scratches on them when I receive them.... So this is why I decided to powdercoat them... If customers are aware and ok with this, then the cost could be lowered a bit.
  12. not yet, but will have next week. I am waiting for the powdercoating costs. Also, I will probably do a pre-sale here on npora before making them available on my website. This will make sure that the npora community gets the first ones delivered to them in january 2017
  13. yep.. All USA made Bendpak.. I just love it... This garage is a life dream that I realized with a mezzanine and office, AC and heat, tv, overhead 1 ton crane that I designed, etc.... One day I should make a video of it...
  14. 1) Yes and no... You will have to make new holes in the rear skidplate in order to attach it to the old crosslink. I made some changes for more torsion force in the new one, but it is basically the same idea. On the old crosslink, the holes were 14" apart, on the new one they are 18". So if you have wood working tools, you can work with aluminium and make new holes. I have also removed the welded nuts from the new crosslink in order to save cost and bring the price down. The bolts are also downsided to 3/8" instead of 1/2" like I used to ship. 2) the mounting on the rear took most of my time as to what I was going to do considering the experience I have acquired with time and lots of offroad. I have settle for 2 brackets that wrap around the transmission crossmember. I went this way over making a bracket that would either bolt to the transfer case or sit right under. I did this because at the end, the stronger part of the transfer case is the bottom of it. So yes, in the event you sit the truck on a rock near the transfer case, the plate will bend and tuck itself under the transfer case hard spot. If I was to put a bracket, I could see either the bracket break and potentially become a spear-like object going through the TC, or if the bracket was to be attached via one of the transfer case bolts, I could easily see it break in two and then be stuck with oil coming out. The setup I choose uses all the strong point of the under carriage. Mind you, there is about 0.5" inch space between the end of the rear plate and the underside of the transfer case. So the bend will not be excessive and everything will be properly protected. As for the SFD setup, in order to have the plate sit flush underneath the transmission crossmember you would need a slightly longer plate and probably a bend in it to compensate from the 4" SFD drop as the crosslink would be sitting 4" lower. If you are interested with that I could design/fabricate you one... Just send me a private message and we can talk about it. yes , I now overlap the front over the mid skidplate. Again this is to bring cost down. It also makes it stronger since the mid skid is now full seated against the sub frame as of before it was bolted to a 3/16" steel plate that was bolted to the sub frame. The only down side of this is if you were to scrape the truck over rocks going in reverse... It could potentially create a spot were the skidplate would snag or hang, but being it's only 1/4" thick, I doubt it could become a real issue. For the fabrication time and material saving, i know it is worth it. Hope I answered everything you asked. Cheers. S.
  15. Yes I have For a long time now... (by the way, my front is in 1/4" aluminium too, not steel.) ... Back in 2010 I was testing different approach of manufacturing the skidplates and I basically dropped the truck many times on them. I literally slide down on the skidplate, wheel off the ground. Here's a picture of one of my first beta test for a full skid. It was all in one piece ( I welded the front with the mid-rear),, There was a slight deflection like you can on the 3rd picture, but the plate had done it's job..Which is to take the hit and save your equipment. I have twin lockers on my rig and I am an avid rock climber with it..I have NEVER broken any parts (transmission pan, oil pan, trans, steering rack, etc.. due to hit because I had these skidplates..) If you listen carefully , near the end of this video (2:44), when I finally make it up there, you see and hear when I fully hit the rock with the skid. This hit was directly on the transmission and transfer case... no damage and drove right back home.. Personally, I have seen many guys stranded in the woods simply because a tree branch just badly positioned on the ground went through the oil pan.. There is many thousands of dollars worth of items underneath our trucks. At the beginning of this all (when I was choosing the material for the skid, I did a sledge hammer test with 2 identical piece of material (square), one with 3/16" steel, the other 1/4" alu. I can honestly say the dents were the same on both.. So for me 1/4" alu is as strong as 3/16" steel, and the weight reduction, rust free attributes makes it a perfect material for these high end skidplates.
  16. It is unlikely. Simply because the chances of finding a 95 that is not rusted out in Qc in near impossible. I was lucky enough to find a npora reader to help me design the rear spacers, but designing a set of skidplate is a whole different kind of animal... There is no way i can do this remotely. I am not closed to the idea, but i doubt everything will line up so that i can have access to a good, not rusted, straight wd21 in the near future... Also , do you think there would be enough interest? Envoyé de mon iPad en utilisant Tapatalk
  17. ******* EDIT ****** THEY ARE NOW AVAILABLE AS A PRESALE UNTIL DEC 31ST ONLY FOR NPORA MEMBERS... CLICK HERE : http://www.nissanpathfinders.net/forum/topic/42686-r50-crosslink-mid-skid-and-rear-skid-presale-ends-december-31st/?p=783943 I'm on the final details of the fabrication of a full set of aluminium skidplates that will be available before Christmas. I thought I would give a small peak for all those that patiently waited for this moment.. If you have any questions, just go ahead and ask them in this post as it will serve everyone. Here's a few facts : 1) No price yet - still have to finalize cost before that 2) All parts will be powder coated black for a durable finish 3) They have been designed to be symmetric... This means you can flip them if they become scratched and you're back with a new fresh set.!! 4) The 3 skids are not dependent on each other, but the Mid and Rear will need the crosslink for attachment 5) The items for a full set are : Front Skidplate, Mid Skidplate, Rear Skidplate, Control arm Crosslink 6) Only the crosslink is made from steel, the skidplates are from 1/4" aluminium T6061 7) The skids are water jet cut. so no distortion from heat 8) The mid and rear are compatible with the front skidplate that were bought from me in the past. Pictures :-) BEFORE : AFTER:
  18. Mid skidplate, crosslink and rear skidplate will be for sale before christmas.... The mockups are all done i will have the first set finished in about a week... Envoyé de mon iPad en utilisant Tapatalk
  19. hahaha.. good...! Mine will have a plate welded under it for skidplate bolting... so It will be a little different, but I like the ends that you did... simple and no need to weld an additional plate (like I did in the past)...
  20. How did you figure out that this ujoint would fit the pathfinder....? The list of diff listed does not includes ours... ( I ask because when I started looking for ujoint, I looked for spicer, but figured that they were not making them
  21. I love your design... Hope you don't mind if I decide to <borrow> it !
  22. Love the choice of words here hahaha!
