nunya
Moderator
Everything posted by nunya
  1. Pick up the phone, one of your local shops should have a recovery system, and be able to tell you how much to do it. (Not being smart about it, just didn't see it suggested)
  2. Zip ties are your friend...Random objects falling and dangling in front of gas/brake/an-or clutch pedals=bad.
  3. $1,200-$2,000 for headlights? There better be a truck bolted to them as well...
  4. Guy that has a Chevy dually that stops oin where I work has the same basic clips on his winidshield. They are for a windshield shade on his at least. The interlock switch as said will let you start the truck without the clutch, just watch to make sure your not in gear or have alot of room in front of you...
  5. Get a broom handle and cut it to length to stick between the seat and gas pedal(I joke but have seen people do this unfortunatly and wonder why they wrecked...). Mine quit working righ tafter my BL, thinkign I ripped something off...
  6. Almost? I'd a ran. You check the classifieds here for any part-outs as well?
  7. dam, try a pick-a-part maby. pocket the hinges and walk up to the counter with just the wing.
  8. Actually kind of sounds like an alternator problem. Check to make sure your charging, if not it will kick on a bunch of warning lights(don't know if a 94 has a dash gauge but I think most parts stores will check for free for you to see if your charging)
  9. Quick idea to try to see if it's in the tires. Rotate them, put you matching pair on the front and the mix-match ones on the rear and see if there is any changes.
  10. for wd21's there was one with and one without a notch for the 3rd brake light. I have seen people on here with un-notched ones over the light so they work either way.
  11. The rear wing is easy, just take the hinges too. I tried taking the bars that actually mount to the roof off the 1 I ocasonally borrow parts from at the yard I deal with. Heads stripped out instantly, no patience for that right now.
  12. I have to agree with checkign your rear brakes, I see it alot on Neons with rear drum brakes. The stopping surface will seperate from the shoe and lock a rear wheel one way but let it move the other(which way depending on if it's the front or back shoe in the drum). That or possible hardware failure jamming a shoe into the drum when goeing a certian way. Still can apply with rear disc brakes, there is a small drum brake setup in the rotor for the e-brake.
  13. I'd say it looks stock honestly, maby the rear is set up for light towing/hauling with those bags in there?
  14. Park beside a known stock one and compare?
  15. Have the same head unit in my flatbed...works great for a salvage unit(pulled it out of a car we were taking to the crusher).
  16. If you got the parts and time at your disposal and don't need the truck you might as well get crackin at it. If your in need of the truck currently, I'd start with making sur ethe TREs are good and maby get an actual allignment.
  17. you bypass the switch and they work...means the truck wiring/bulbs/fuses are all working. Definatly a switch then.
  18. Remove the faceplate, it will not go off then... it's a reminder that you powered it off and the face is still attached
  19. A good welding shop[ can put you back togher. Don't let some flakes make you lose faith.
  20. I have smoe kind of Sony, it has an input jack in the front that works so I am happy with it. http://cgi.ebay.com/1994-94-NISSAN-PATHFIN...7C294%3A50<- no picture but maby what you are looking for ashtray replacement wise
  21. Right side of the transmission, about a center position. There is a rubber flex hose goeing to it. Grab a light and a creeper and you should be able to spot it. 2 bolts hold it to the tranny, 1 for the flex hose.
  22. Your thinking of the H4 conversion, gotta do the Hardbody complete front end swap to work them in(MY1PATH has the grille but modifyed it for wd21 headlights) He is looking for these http://cgi.ebay.com/ebaymotors/1987-1995-N...sQ5fAccessories Your thinking these http://cgi.ebay.com/ebaymotors/7x6-SQUARE-...3A1%7C72%3A1171 ($10? almost thinking about it, of course thinking about not as well)
