laxman0324
Everything posted by laxman0324
Who are the homeless guys in the pic? Pezzy, get the squirt bottle again...
Very good points, It is just a funny idea to those of us who aren't hardcore offroaders I guess...It is just so uncommon (do any stock vehicles use that setup?)
So do super duty Fords...and he was saying coils in the back and leafs up front would be off, and I agree, it would be weird, but I would like to see somebody do it...
I have no shift flare issues...come to think of it I have no power valve screws either. wtf Fueler?
What parts are needed for total front spring/strut swap?
laxman0324 replied to madmike283's topic in 96-2004 R50 Pathfinders
Do you guys think that anything other than the strut bearing should be replaced? I don't wnat any of the mounts wearing out or the insulator and having to rip it apart again... -
255/70R17 Revos on stock wheels does not rub at all.
R50/Terrano Projector Headlight
laxman0324 replied to dududuckling's topic in 96-2004 R50 Pathfinders
Thanks man, if I didn't have the X rims I would have bought something very similar to yours, they look great on the QX4... -
Even if you got them for half price I couldn't afford that...I need new tires for the X rims... -
I think the blacked out headlights look great on my 01... However their light dispersion is horrible as stated before. Thank god the fogs put out a lot of light. I wish I could get the HID's, but they are too damn expensive! And GPG: I am pretty sure the QX4 comes with a hatch glass opening mechanism, so who knows how much of the hardware is already installed in the Pathfinder for the switch... -
The camber adjustment bolts fit in the stock mounts with no drilling. If yours look like they need drilling then you got the wrong type. Mine were the +/- 2 degrees from Summit Racing by Ingalls Engineering.
Seriously? The god of R50's is asking us peasants a question? My only experience with an aftermarket clutch was on my W163 Mercedes ML, and it was a garbage unit purchases from Pep Boys, I ended up buying OEM online.
Ty: Drool. That is all. Kenmt stuff: I love the look of the 00-04 bumper with the PIAA light setup, but it is insanely expensive and the mounting points are very weak.
RS999010 Rancho Shock Question
laxman0324 replied to OfftourRoadie96's topic in 96-2004 R50 Pathfinders
One of the larger sleeves fits over the bolt but is too long...cut it shorter! I don't know what happens if you don't use the sleeve but I will let you know since my 01 couldn't fit a sleeve on either mounting point. -
Yep, just his hood would need to be modified for clearance...We can get a couple kits for the VQ35, lucky us!
If you are going to get a heavy bumper, get the HD coils. I think everyone who has both for just a lift has been satisfied, you can't expect the MD coils to be as firm as the HD and vice versa. And if you sandwhich the strut spacer between the lower and upper spring plates it limits your maximum extension to the same as stock since the top of the CV shaft is mounting in the same location as stock. The setup pictured here moves that nut down an inch and thus extends the CV another inch. If you look at my picture below you see that the upper and lower strut mount plates are sandwiching the spacer, compared to new4x4's where the spacer simply sits on top.
I think some people have done that, I think the main issue was finding a bolt that is long enough to get a nut all the way on but short enough to not rub the coil retainer...I think Chris (02silverpathy) may have done that...
Longer bolts mean you need to compress the spring and disassemble the upper strut mount to get the longer bolts through the holes, the upper spring retainer is just barely in the way so you can't fit bolts through without removing it...
Seems pretty expensive to me, and without a dyno chart like the one K&N posts for their intake system I would be hesitant to drop that kind of money...
The valve covers build up sludge with use of dino oil, combined with the PCV valve issue they can burn a LOT of oil...when I heard about the PCV valve issue I did research on Z forums and other VQ35 powered vehicles and all of them have this issue.
Agreed, my links made a TON of noise, now the worn out struts are clunking a couple months after I replaced the links...joy!
I wouldn't since VQ35's are well known for sludge buildup and mineral oil is the sludge culprit. First 5k miles with Mobil1 and the oil filter was filled with sludge that the synthetic cleaned out. Why would you want to anyway?
I don't think more than a handful have bent their links, Dan's were mangled when I saw the old black R50...
you would know...
I will just say I have had no issues with my wheel spacers, but I will not take my truck off road with them on, but I do check them once every month or two to make sure everything is torqued down...
Can we get some more updated pics and more details...
