36
Everything posted by Alkorahil
Yeah craigslist is a good place to look!
The stock horn relay is 3 pin............I looked it up in the computer and took a look for you part# 25630-79960 I am not sure what you got....
Yes they will. But as stated they will look odd with the steps for the rear door.....
imperical evidence supports this!
okay, i have alittle mystery with my car?
Alkorahil replied to Coucoui6's topic in 90-95 WD21 Pathfinders
I would say one of the muffler/exhaust hangers is busted. -
You will not find it in the FSM. It was a dealer installed accessory. The alarm control box is under the drivers seat. It is a black box witha a white sticker. How have you not harmed the alarm module but not the ECU with water?
Its a metal pully mounted on a metal stud that it rotates on and it is constantly spinning. It wears itself out. think of it as 'metal errosion'
My guess would be: 1) A woot l33t wiring problem 2) A bad dimmer switch as to your wheels....bad steering rack?
Compressor Idler Pully. Not the compressor pully. Arrow points to the idler pully.
Patherfinders they are all the same 86.5-95 The Hardbody Pickup from 85-92 and the Pathfinder 86.5-95 share the same part number: 65601-01G0A
Well I looked at the vid and listened a few times and I am going to go out on a limb here based on what I could hear when the camera moved around...... Given the age and milege, I was thinking actually Compressor Idler Pully (11195-88G00). It can wear out and make noise from causing drag on the engine, especially if te belts have been too tight at some point. With tension on the pully you cant tell. Take up the slack on the belt and you might be surprised how wobbly it is. But I do agree with the others, you are overdue at 95K for a new timing belt ,tensioner and water pump. Get it done soon regardless if it is this perticular problem or not. I also looked at your other video of your cold start......does it always idle at 1200 rpm??? Thats rather high.
It is called a wiper amplifier. Part number is: 28510-09G02. The Nissan parts diagram is not very helpful but I can send you one if you want.
Not on tight enough most likely.
I can do $177 plus shipping.
I agree with Fueler
Why not get a new remote???
I can get you a new Genuine Nissan Pump Assembly for less than that.
168K miles and going strong
I like this part the best: "For over 50 years International Institutions, Universities, Engineering Associations & Independent Testing Labs have compiled documentation and test results proving that small amounts of hydrogen added to the Internal Combustion Engine significantly reduces toxic emissions, increase engine performance & provides a more complete burn of the fuel. " IF that was true the government woudl require them to be on vehicles to reduce emissions! "The added hydrogen gas from simple homemade hydro-boosters enhances the flame properties of the air-fuel mix & catalyzes the combustion of the hydrocarbon fuel. WHAT?!?!? "Improving the conversion efficiency of the world's motor vehicles by one percent would reduce fuel consumption by one billion gallons per year! " well...............So would removing air conditioning compressors OR catalytic converters and mufflers!
Sounds like what I had starting on mine periodically. I too diagnosed it as the IAC valve, so last Saturday I replaced the IAC valve on the truck and the regulator. To get to the IAC valve you have to take the intake collector off. Since I already was taking the collector off I went ahead and replaced the EGR valve, which you have to take off to get the collector off, I also replaced the PCV valve and properly cleaned the intake and the intake collector. The biggest surprise was the air tube assembly under the intake I found was seriously clogged with crap from all these years. It took 3 cans of intake cleaner to get all the crap out of those pipes. I thought my truck ran great before, now it is like I took 100K miles off of it!
Dead Sexy IMHO!
bad miss fire and hesitation
Alkorahil replied to bitemedoughboy.com's topic in 86.5-89 WD21 Pathfinders
Bad plug or plugs? ignition coil? Fuel filter? distributor cap? distributor rotor? any or a combo of those could also cause it. -
Well I looked in the computer at work and they were not available in North America.... But there must have been one somewhere since there are notes of a 'van' body type.
So I saw that PIAA now has wipers and blades out there. I read though the literature/propaganda and am wondering if anyone ahs used them on their Pathy and what they thought...
