deej
Everything posted by deej
  1. Thanks.They must have changed something between 97 and 98 which is too bad cuz mines a 98. I like the price though.
  2. Mookie is there a beefier IFS set up (Tie rod ends,idler, centerlinks, control arm, etc) that a guy could go to instead of a SAS? Sorry for not getting back to you sooner on the Jamboree. Looks like I won't be able to make it this year......working, thanks for the info, definately gonna try next year though, looks like an awesome outing.
  3. What I would have said exactly.Points 1 thru 5 15"X7" rim 6X5.5 bolt pattern 31X10.5X15 tire
  4. Thanks Still doesn't look right but you get what I mean
  5. Tell them it's an auto air locker for bumps I think it's a cool sound that should be patended(sp)
  6. I saw that episode too, lotta work though for a whole Pathy! Did you see that Dodge he's working on, I think it's a 48? Those tires he's got for it..WOW :eek: Should be cool when it's finished.
  7. Looks like you got yourself a steal.....I mean deal my friend.
  8. I think its if you arm the system, any electrical "interruption" will set the alarm off.I.E. unlocking the doors with a key then opening the door turns the interior light on. I had this happen when I fell asleep in the Pathy and then unlocked the door manually from inside and then openned the door only to get rudely awoke :o your jumper connection was an electrical interruption.
  9. Did this topic just get officially hijacked?!!!?
  10. *clears throat* Could it be detination? Higher octane gas should clear this up. There's a thread on this exact sound, I know cuz I had the same noise. Thanks NPORA guys
  11. deej
    Tire Inflation
    32.254 PSI and 19.662 PSI if off road. sly
  12. deej
    CB Radio
    Cut and paste are his friend Now fess up..what site is that from?
  13. The only time I've had gauges go "wonky" like that is when I had a defective battery but it also wouldn't start, boosted it, then when it did start it did all that crazy stuff. Almost like it was posessed. I'ld say check the altenator too.
  14. Just one question.....how did you know "to replace the gas cap" :confused: Hey 88 Is there a sticky on this?
  15. deej
    Gear Oil specs
    Just did mine to the owner's manual and it said DexIII for transfer, GL-5 with LSD additive(or 80W90) to the diffs and GL-4 75w90 "only" to the manual tranny. The 90W is only good for temp above 0F which tells you really quick in our minus 40C winters...lot's of whining.
  16. deej
    LSD
    Recently got stuck and I was wondering if my LSD is working. Shouldn't both tires turn when in the mud even if stationary? And what should happen if one tire is off the ground and one has minimal traction (resistance)? Should the "aired" tire turn too? :help:
  17. Wo ho ho yeah! Supercharger! Yum, yum. I gotta find this vehicle, any pics...write ups...info? Where...where...? :cool2: Ok, I'm calm now, thanks. I'll check the AC board out.
  18. Put some switches in that don't do anything...then pretend they scratch that "itch" for you. Works for me!
  19. deej
    Thanks
    Tell her to love the truck and it'll have no problems loving her back.
  20. They changed the date to June 15, must be having difficulties. Any further word on the prototype Big_Johnson?
  21. Is my calculator broke? I thought it was 4.54 litres in a gallon last time I checked. Maybe they changed the formula so we wouldn't be so offended by the price?
  22. Just hit 95.9 cents a litre 87 octane here in Saskatoon. Calculate times 4.5 $4.32 a gallon :oops: Jeez, I gotta start charging admission to walk by my truck! Jim, Is there any monitary value in winning TOTM???? sly
