TowndawgR50
TowndawgR50 last won the day on June 8 2025
TowndawgR50 had the most liked content!
    2001 3.5 R50 4x4
    Skilled/Experienced Mechanic
    Choose
    Choose
    Washington state USA
10,959 profile views
TowndawgR50's Achievements
NPORA Old-Timer (5/5)
1.2k
  1. Cooked up some heavy duty sway bar links as part of my suspension refresh. Hard to believe its been 10 years since I installed the complete front end kit on this truck. Not a ton of miles since then (+/- 50K) but they were hard at times and saw some pretty fun adventures.
  2. Items in the works: I've got a handful of things still to do short term but the list is finally getting shorter. Firstly the important items learned from the recent Moab trip would be that I need axle limiting straps and a taller spring would be ideal. I want to eliminate the HDPE spacers I've used for years and get an all-spring setup. I may also move the spring perches forward and fabricate new lower shock mounts that will provide more clearance. Still have some research to do on that front. While I was coming through Oregon I took advantage of a sale+no tax+IST coupon to walk out the door with a 12K winch for $260 bucks. Just need to swap over my old 9.5K Smittybilt synthetic rope and figure out where to remote mount the solenoid. The front suspension really isn't terrible, especially given my KYB's are approaching 10 years of age, but my roots in high speed off-road really have me wanting to build a better front end. Long term I have plans to make a LT front setup that should fit the bill very nicely but it'll be a ways off. For now there are a set of motorsport coilover struts that should work with the Nissan suspension components after a few changes. I think the weakest link of the whole front setup is the lower control arm mounts and overall method of stamped sheet metal manufacturing. A set of chromoly tube arms with through-bolt mounts and the motorsport coilover struts would be pretty slick and get me closer to the machine I want. I'm sure there are a few bits I've missed but this should be mostly up to date now. A few pics from the recent Moab trip with @hawairish
  3. Changed out the front axle shafts for the Trakmotive extended travel units. Much beefier than OE and they come with the Thermoplastic boots. That said- they skimp on paint or any kid of coating so they rust quickly. I suggest immediately painting them if you get a set.
  4. The rear arms I built years ago got an axle side change to some beefy heims in recent years. I'll start by saying I don't recommend them and will be changing them to Johnny Joints in the near future. They are super high maintenance and started squeaking within a year of install. They're probably fine for a trail toy or someone who just doesn't care about the noise. The performance was impressive but not worth it in the end. I started by media blasting the arms I built to get rid of the damage from DOT liquid de-icer's used in recent years. Then painted everything and applied a healthy layer of anti-seize. I kept the body-side rod ends poly to provide some insulation from noise and vibration and the combo worked well prior to the heims making noise. At this time I made a driveshaft spacer from 6061 AL to allow me to push my axle further back into the center of the wheel arch. Pretty easy job and solved an issue with lifted R50's that most folks don't account for when going higher. At some point during all this I started rehabbing a spare HB233 housing for the eventual rear disc brake setup that I picked up from @hawairish. I had the axle housing media blasted and coated it in POR-15. My OE axle shafts needed to be turned down to fit the WD rotors but later models apparently don't need that modification as the axle flanges were smaller in diameter. All new seals, bearings, rotors, pads and refreshed calipers. When I eventually get the axle done it'll be a short period of down time since I should have everything ready to swap in.
  5. I said goodbye to my old set of KM2's on vintage mags and K02's on Tacoma alloys. Picked up a new full set, including a matching spare, of KM3's on some 15x10 AR alloys. With the impending long distance road trip the 8 year old rubber was a liability and it was time for a refresh. While I was at it I installed a set of OEM Nissan manual hubs that @hawairish sent my way. Much nicer kit than the Warn units I was running and they only need a 1/4 turn to engage. Gave the refurbished bumpers a quick coat of rattle can black to clean up the truck and get ready for the Southwest trip. I installed some universal mud flaps since the OE units wouldn't clear the tires to complete the look and so far they've held up really well. They come without brackets or mounting holes so it left a lot of room for interpretation but overall I think they're a great solution for my needs.
  6. The entire cooling and belt drive system was refreshed. New radiator, pump, thermostat and housing, hoses, belts, power steering pump, alt, idlers, fan bearing bracket, fan and clutch. During my repairs I've been finding that many components, brackets, bolts etc...they're all succumbing to rust. I started ordering full sets of all bolt and nut sizes/pitches of yellow zinc JIS hardware to have on hand as I go through my truck and other projects. Additionally, i found that electrolysis is a great way to clean up super rusty parts prior to painting.
  7. The universal sliders I've been holding onto for as long as I've lived here finally got mounted. Again, thanks to the brilliant engineering that @hawairish cooked up I mounted them via the OE locations using a set of QX4 step rail brackets and the adapter plates that he generously designed and cut out at his lab. They're robust, can easily support the weight of the truck and completely bolt-on. The truck also got a complete set of 2nd hand Coastal bumpers with a swing out that was conveniently located locally. The kit was professionally welded at a SoCal race shop so the fit up and quality was superb. Just needed a respray and some minor cosmetic repair. I bought the correct color matched silver to paint them but the window to paint outdoors here is very short and i have not managed to get the time in the 3 years since owning this set. I wasn't much of a fan of the Coastal options so I shaved most of what was on the bumper with the intention of 3D printing my own AUX/Fog light housings when the time comes around to painting them. For now its just clean and simple. An element of the Coastal design that seems pretty wild to me is the disregard for the power steering cooling line. These trucks use an aluminum tube that runs directly across the lower radiator support that the coast kit neglects, forcing users to bend it up out of the way. I opted to run a remote oil cooler next to my trans cooler and avoid what could be a disaster on the trail from a bump or collision.
  8. The truck now has 4.6 gears. Initially I installed a SuperPacked LSD rated at 236.5 ft/lbs of breakaway that @hawairish built but after driving it for a while I found it wasn't really appropriate for my intended uses and the wet PNW environment. Would be great for a trail toy or sport truck application. So I ended up going with ARB lockers front and rear. The front hasn't made it into the truck yet but is on the bench as the next major item. The truck is already plumbed for it so I just need to finish the install into the housing and stuff it under the truck. @hawairish hooked it up with a slick bracket that he cooked up for mounting my old ARB single in the engine bay. I had originally mounted it in the rear passenger cubby and it worked well for the last 10 years in that location serving the sole purpose of inflating my tires after trail runs but with the ARB's it was time to relocate. I installed the switch panel that @hawairish and I ordered a while back that replaces the sunglass holder to run everything- Compressor, front and rear lockers, light bar, trail lights and AUX backup lights. Super stoked with the result.
  9. Long time with no update! The truck is back from a recent trip to Moab with @hawairish and his build has inspired me to bring this thread up to speed... The truck has seen lots of trips and a handful of upgrades. Most notably is the rebuilt trans. Had some water intrusion in 2024 that prompted me to have it professionally rebuilt with a couple minor upgrades for durability and longevity. I paired that with a set of low-range gears for the transfer case that @hawairish helped make happen. Legend has it these gears are made by the same group that manufactures OEM gears but I have no proof so take that with a grain of salt. They are manufactured in Japan and have proven themselves in Moab but the install had a few hiccups that leave me curious how others have done this DIY in a garage setting. The large 4WD shaft required machining to match the OEM length otherwise it binds on the case. Not a problem as I chucked it in the lathe and made the needed modifications but unless you can machine the case or the shaft I would say this would be a show stopper. I drilled and tapped the output shaft so that I can run a SYE in the future while I had the case apart then reassembled everything and delivered it to the shop performing the rebuild so they could install everything and get the truck back up.
  10. The last of our kits will be liquidated soon. Once they're gone there won't be any future kits made. Expect an early 2025 release. Kits will be sold on a first come, first served basis with lower 48 shipping only. We will not take any orders until the remaining kits are completed and ready to ship. Stay tuned for the the final sale announcement and check out our YouTube channel for a highlight reel from our Moab trip where our gear is trail tested.
  11. This project is outstanding. Working with @hawairish and watching how he implements massive amounts of thorough engineering, design and consideration into his projects is incredibly inspiring. I'm super grateful to have the opportunity to help with a small part of this project and I'm excited to see it in action next year!
  12. Do you still have the R50? Did you do the sub frame drop? And How close to olympia are you.
    I'm putting in a TDI ALH 1.9 into the pathfinder. I drive 2001 as my daily and have 96/97 pathfinder which the diesel is going into. I have an oil pan which I call the $7000 oil pan, as I have been really slack in trying to get my aluminum tig welding to point which is useful, so that I can modify the oil pan to work with the stock subframe height.
    Somehow, I came across the subframe drop yesterday, if I do the subframe I will get sump clearance between the diff. At the moment in theory, I have lost half the capacity of oil pan.
    Also previously owned a red 1995 Nissan D21 Pathfinder and a WD21 TD27T Terrano in New Zealand.
    Cheers
    Shogun
  13. The Lokka is doing great. Just as good as the day I installed it. It's taken my rig through some incredibly challenging trails and never really gave me any reason for regret. Having driven HawaIrish's fully air locked rig, my Lokka equipped rig and a stock rig, an airlocker is hands down the best performance for trail use but may not be what everyone needs. A proper line choice, good spotter and quality tires will get an open differential truck through a lot of challenging terrain. The Lokka is the best bang for your buck if you want a huge gain in trail performance on a budget but comes at the cost of a substantial change in the driving requirements and limited street use. When it snows here I use 4WD on the street and highways without issue but that's the only time it sees use on pavement as my hubs stay unlocked and the truck in 2WD the rest of the year Still need to install my super packed LSD. I think HawaIrish set it up for 200-ish ft lbs? When compared to the OEM LSD it should be very nice improvement. It's been shelved with the 4:1 t-case gearset, 4.6 diff gears and my rear disc brake setup. I plan to get those installed for the next trail run in Colorado. Moab trip was a perfect example of where air lockers reign supreme but I'd wager the front Lokka and rear super packed LSD would have done well.
  14. x2 on the OME springs. They are a great spring that sells well for those not wanting more than 2" of lift. I had OME MD rear springs for a long time and paired them with a set of Bilstein's. Fantastic for hauling heavier loads like camp gear and dogs. With the assistance of a set of Airlift spring helpers they handled our 18ft toy hauler superbly. With no load they were well mannered and kept the truck tight on the road without being harsh. Definitely recommend them if you're looking for a heavier duty 2" rear spring. Cant really go wrong with ARB products. Installed with spacers and airlift spring helpers not long after I got the truck:
