Remus92
Everything posted by Remus92
  1. Yeah I'm good. Airbags never went off. Lower frame was untouched but that upper radiator support took all the damage.
  2. Another angle. Right side got pushed in quite a bit. At least we had one last trip to the mountains in September.... ?
  3. Well rough day to end it off. I know I've been MIA around here the last couple years. Ole Flapjack died on the way home. It's too damaged for me to repair it... So I guess I'll find something else to drive and hopefully get into another pathfinder sometime. RIP 334K to end it.
  4. I would never buy a today Nissan. Only model I have considered (frontier) dies next year with an ugly "upgrade" still a shot I could pick up a used one at some point but I'd probably get a hardbody instead. Pre2005 Nissan is the best Nissan. Ghosn may have kept the company from bankruptcy but he renault'd our Nissan.
  5. When mine went out like this. It was the speed sensor on the transmission. (96 automatic) replaced the sensor and it was reading both speedo and odo again
  6. I have the same size all terrains on stock wheels with no issues. According to the manufacturer my 31 inch tires actually measure at 30.5.
  7. It says these things for the factory roof tracks. This is the thing that connects the factory tracks to the towers. https://www.yakima.com/landing-pad-1 Then pair with whatever tower goes for your cross bars.
  8. I completely dropped z31performance... This forum is not like most. I do not see the complaining, the putting people down, and the general bitching about the questions. Npora is the best forum I have been on.
  9. It should. That's still the vg33 right? If so no problem. Same motor!
  10. 1. Yes. Shift quickly and firmly. Have the vehicle in neutral while shifting between 4H and 4L. I'll usually get a little chirp out of the gears while doing that. You are basically forcing the gears to mesh together. 3. Ac is a brand you can get them at 4x4parts. Other options are ome. And people have recently had success with front Landrover springs in the rear of the r50. Fleurys (forum member) has a website with spacer kits as well.
  11. I thought about doing that with the connectors but i need to check my wiring before i try that. These things work so intermittently it has to be something in the wiring. But i definitely want to change those out for led pods
  12. What size lights did you go for? I have been thinking about doing the exact same thing because my fogs rarely work and when they do... Well they don't Put out anything i could consider light!
  13. Before i bought tires i searched for reviews... But i got fed up and ignored them and just order what i wanted. I was sick of reading review after review of somebody with an opinion after 500 to 1000 miles. And in my mind that is no where near enough to get a good idea of a tire!
  14. Must have been the older versions... that experience would not make me willing to buy more. They were on an s10 i drove for a winter and even with 2 sandbags and a bed of snow, traction was lacking quite often. Granted i doubt 4wd worked half the time so my aweful highway drive one morning i attribute to that more than anything. But to each his own! I went from firestone destinations that were pretty plain but great tires to these yokohamas. And have not yet been disappointed by the purchase.
  15. ATs i suggest the Yokohama geolanders Fantastic traction this far. Have 24k miles and at 80% or 85% tread no issues on odd wear of lugs. I expect to easily get 60 to 70k miles out of them. Once these are worn out i may go for Yoko mud tires. Personally i never liked the bfg ats they are bad in the snow and terrible in the ice. They are decent in the mud.
  16. Micah what do you have on the front? I bet this Landrover parts dealer is wondering why so many people are ordering so many sets of 1 side from the us!! Lol Edit: i need to do this soon! But it'll probably have to wait until after my camping trip to big bend in March
  17. Just replaced some bulbs yesterday. Open rear hatch. Take out 2 screws on the plastic cover of the 3rd brake light. Take off plastic cover. 5 light (edit: bulbs) can now be accessed. If you have to actually remove the whole thing. There are 2 10mm nuts holding it in inside the plastic cover.
  18. Bundle up! I changed an o2 sensor laying on snow and ice in December before! You just gotta want it! Haha
  19. Hahaha!!! It's pretty easy to change the rears. Jack it up a little and 2 bolts each side. An impact helps if you have one.
  20. Yes. I may have had 2 stubborn ones and given the location i couldn't get enough force to just break the heads off. Certainly at least 1 on each side. I used a long socket extension and just bent them enough to gain access to the bolts. A small pry bar probably would work better. The replacements didn't have the spots to attach them again so i was not worried about damaging the shields.
  21. I assumed those are what he's talking... If it's just one bolt keeping the heat sheild on. Do what i did and bend that sob out of the way to get your access to the actual bolts to remove the part. Of the catalyst is already breaking down it will just continue to do so. Might as well replace it
