31
Everything posted by bushnut
yup. just a little outside the scope of my front street mechanic shop, and manufacturing ability. seeing as I don't want the full Krypton Fabs kit (a little to much drop and $$) I figure limit straps are the duct tape solution.
I haven't measured the angle but if i jack up the front of the truck and turn the wheel by hand the CV binds up.
you'd have to lengthen your rear control arms to push the rear axle back to the centre of the wheel well. I am running IronMan lift springs(35mm front and 50mm rear) along with 2 inches of strut spacers. so almost 3" of lift On flat ground and day to day driving everything is ok..HOWEVER...if my front wheels were to flex to full droop I have no doubt that I would rip my CV joints apart. so until I install some limit straps. no real wheeling for me.
I'd look at the FSM schematic and/or a Haynes Manuel, but it's not much more complicated than that.
I had the same problem. ( the seam that is under the air box) I cut out the rust and borrowed a buddy's MIG welder, and burnt in a patch and then another piece of 3mm plate on top to brace it ( first time welding and I think it should be Ok, no pics 'cause the welds are so ugly.) then sprayed in all down with bedliner and covered it up with epoxy putty on the inside of the fender well, sprayed that all down with bedliner too. I figure I'll get another 3 or so years out of it.
do zombies turn into skeletons after a certain amount of time? or does the flesh stay on them forever? I was never a comic book guy so I haven't the foggiest idea.
As far as I know Rebleord and and I are the only ones running IronMan springs. If I were to do it again I'd go new factory springs and lift, spacers from Steve (4x4designs) all around, to maintain a great ride and a little more hight.
I had this issue as well, check all the usual suspects (sway bar end links, ball joints, rotated tires and found that it was actually the right front strut that was dead, even though it was just 2 years old. ended up replacing both struts no more problem.
check out the max tire vs lift thread. or my build thread. I have 31x10.5x15 tires, 1 in lift springs, 2inches of strut spacers up front and 1.25 wheel spacers all round. and yes I worry about full droop and ripping my CVs apart, haven't done it yet but I've been playing it safe until I instal some limit straps.
that is one ugly truck.
I am definitely going to follow your advice for disaster preparedness. very sound thinking.
mine hiding in the bushes....
nice thread. well done sir.
Weird rattle noise when in 4 wheel drive
bushnut replied to guycar778's topic in 90-95 WD21 Pathfinders
were you on dry pavement? how fast were you going? -
after finishing all the mods I had planned on my truck, and reading what you've done to yours, I've figure what we've done to ours is how it should have come stock. 11in clearance at the front diff, steel skid plate, 31x15 tires, and maybe some better recovery points, now it's the way it should have been.
sounds like you've got a cracked circuit board or wire harness. good luck bro....electric gremlins are not my strong suit.
have you checked fuel lines and filter? Bad gas? The other day my truck was running ruff no CEL, I ran my code reader and a knock sensor code showed up, I ran it until almost empty, re-filled with premium gas and then cleared the code. no more issues. now runs like a champ.
I think I had luck with a kind of cork screw method.
Yes anyone can cook to pieces of metal together in some way or another, but WELDING I now truly believe is an art from.
well the project when Ok. Though it is fugly. I had to reinforce the strut tower on the drivers side under the air cleaner. that seam was mostly cancer. I welded in a couple of pieces of 3mm steel. I won't post pics because of how messy they are. (it was my first time MIG welding) I'm happy with the penetration I got. this will just delay the end. It should get me 3-5 years.
If I am going to weld a couple of patches on my rocker panels and fender, should I unplug the ECU or is just removing the positive connector on the battery good enough?
