Everything posted by Bluewulf73
Suspension In-Coil Airbag Durability?
Bluewulf73 replied to Karmann's topic in 96-2004 R50 Pathfinders
I read somewhere on someone's post (don't think it was this forum) that the bags got covered in grit and that combined with extreme flexing of the suspension heped ahnialtate them more quickly. I am sorry, I don't remember where I read that. I also don't remember if the person that posted aired them down a bit or kept them full. Not sure what kid of wheeling you do but keep in mind that the stiffer your suspension, the less flex you are going to get and you will lose traction to one of the wheels. Especially imortant if you have no LSD in the rear. Spend on a spring set. OME HD/MD or if you want to lift your truck AC 2" lift. If you really want to lift it, then get the SFD with WJ rear coils. All three options provide you with rear coils stiffer than what is in the truck OEM. If you don't do heavy wheeling and tow lots, then they might be right for you. -
Took me a while but this is the number for the strut mount bearing for my 1998 pathfinder. I asume it fits at least 96 to 11-98 pathfinders. Oops...tried to rotate the photo but it always comes out like this. Sorry.
Wicked! Nice work; how long did that take you?
All I use: Blockheater, Synthetic 5W30, battery blanket, winter washer fluid. Keep a wary eye on window chips. There is nothing like ignoring a little chip which is fine in the cold but turns to a large crack the first time you crank the heat. The biggest problem I have is with the washer fluid (not here, in the banana-belt, when I go for winter drives out to Banff, Edmonton or Calgary) the fluid freezes in the hoses. Especially to the rear window. Also, in winter, warm the car up before driving. Keep extra washer fluid, oil, a shovel, blankets, candle(s) flashlight, a small bag of sand, salt or kitty litter and a cellphone charger. Brother lives up in Fairbanks, AK and he added the oil pan cooler. When it gets really cold there, pretty much everyone on campus plugs their car in while at school/work.
Looks awesome linkinnn.....linkinpark! Sorry, wiping away the drool.
Help! New/replacement Axle shaft binding
Bluewulf73 replied to Bluewulf73's topic in 96-2004 R50 Pathfinders
Ahhh, I understand now. -
ZZ-Top - Legs
Hey Steve, If these spacers you are speaking of go where the red is in the photo below, they would, theoretically work as that is what was recommended by the shops. Photo below By adding degrees you mean positive camber? Is this + camber something tha I can fix using two camber bolts as opposed to just one? Very interested in your offer. I have PM'd you as well. -
First car I bought outright: 1988 Pontiac Sunbird - The BIRD - 2.0L OHV with slushbox. Brilliant Silver, tinted windows, ARE 15" rims, flip-up headlights. NIiiice. Even the cops that took my car away said it was a nice car. Bought it used and its timing belt killed it. Secodn car I bought: 2000 Neon LE - LEE - 2.0L SOHC manual. Silver. Did everything to it. KW Coilover suspension, upgraded swaybars, bushings, etc. Head work, street cam, shortshifter kit, lightened flywheel, the works. Loved my car. Auto-x'd it and did prety well. (pictured in my sig) Killed by a motorcycle going 120 in a 60 zone. Third car: 2002 Mazda Protege 5 - RED - Lowered, intake shortshift, exhaust, lip...not very happy with the car. Bought used from a local dealer. Engine suffered from oil starvation on hard right turns, turned out the engine in it was already it second. Looked nice and took me on a frew good ffamily trips. (In my sig.) Fourth car: 2000 Subaru Legacy Wagon - Not much done to it other than wheels and lights. Died only a couple of years after I got it. Started off with bad transmision issue. Supposedly fixed by a local shop but in actuality made worse. Eventually it died of a blown head gasket .Sold it to a Subaru master mechanic. (In my sig) 5th car: 2011 Grand Caravan: Nice. Tons of room and POWERRRRR!!!!!!!! Comfortable long-distance cruiser. (In my sig) 6th car: YoDa - 1998 Pathfinder LE Used to be my wife's until we bought the van. Now I drive this baby. (In My Sig)
YoDa because its old , its green and its whooping my a$$.
My kids screaming @ each other...
Thanks for your adivise, however they told me that it is the overextension of the axle shaft that is causing the boot to pull off so, even if I do get a new Rockford boot, I might have the same issue. I looks like taking off the Nx4 spacer is the best way to go. -
Niiiiiice! It'll look even better once its painted and your lights are on it. Perhaps you can use or copy one of the Thule or Yakima fairings to prevent it from becoming too noisy. Also, not sure what the bottom looks like but if you are intending on carrying someting heavy up there, perhaps some supportive bracing. If you want it to go lower and the length-wise edges line up with the rack runners, you gcould take off the cross bars and mount it directly on the runners a la stioc, I think...
Ok, so here's the skinny on things... Went to two different 4X garages today to assess the CV boot issue. Both garages state that the lift is too much and the angle is too high (measured at 3", comparing to my pre-lift measurements) so, basically, I have two options. 1- Take the 1" spacer off the struts 2- Make 1/2" spacers to sadwich between the transmission/transfercase and the axle, in order to push the axles out a bit more hence lessening the angle. Apparently, when I turn left, the boot is so stretched, it pulls off the cv housing. This is so incredibly frustrating!! I love the lift but I am not prepared to have it create more problems for me than I need. Has anyone here made these spacers? Does anyone here know if anyone makes these spacers? If I can't find a cheap alternative, soon I am taking these Nx4 strut spacers off. I was told alminium spacers matched to the diameter and the 6 holes of the axle assembly as well as 6 longer studs for each side would be sufficient. -
Correct...Im getting the passenger side axle boot, grease and calmps replaced tomorrow. There is no binding of any sort in the old axle shaft. Just the boot pulling itself away from the grooves. Tried re-seating the boot and it helped a bit. Not losing nearly as much grease as I did in the begining. Hopefully my manual hubs will get here soon and in a week, I can recheck and adjust my -1 degree of camber (if its still there). -
We should all pitch in, get it and copy everything about it so we can put it in our r50s.
If it is cutting out completely, check what all of the above members mentioned. If it is stumbling, all of the above and also check your fuel pump, filter and pressure regulator. Did you fuel up somewhere you haven't fueled up before? ie-cheap, no-name gas station? If you haven't changed the filter for a long time, I would recommend it. I find the VG33E in my Pathy is very sensitive to fuel quality. The engine in your 92 might be the same...or you could have alot of crud in your gas tank.
Hi-lift jacking point at front end
Wow, that's pretty stuck. Good thing you had the winch. That's all I need now. A winch and custom bumpers. -
To keep or remove running boards
Bluewulf73 replied to PrecisionX's topic in 96-2004 R50 Pathfinders
I think it all depends what you're going to be doing with the Pathy. Are you going to do serious wheeling? Is it a daily driver? How much do you use them? Do you have any shorties in your family? (I do in mine) Personally I am keeping mine on for protection (limited protection, yes but protection none-the-less) Once I can afford some sliders, I will be removing them and replacing them. In my opinion, although the Pathy's look nice without since when removed, give the appearance of higher clearance, I need them for my shorty kids 'n Wivy. Especially with the 3" lift afforded by the OEM/NX4 combo. It also depends what kind of running boards you have. Mine almost look like sliders, especially now that they are painted black. -
Any pictures of that? -
Just for $hits and giggles, I went to Nissan to ask what they'd charge to replace the boot and clamp on my axle. They quoted me $550.00 for parts and labour. So I asked what they'd charge for a passenger side axle. They quoted $680.00 plus labour, plus taxes for just one side. I almost pooped... How can it be that one can get a new axle online for $80-$100 but they charge over $500.00? I've seen boot kits online for $5.00 plus taxes. Locally, the cheapest I found it was $30.00. How does this happen? The guy who did my alignment, is away for two weeks and today, I once again, have some pretty hefty positive camber... So, I'm going to focus on re-greasing the joint and replacing the boot and clamp. Hopefully by the time the guy comes back, the springs settle a bit and camber will once again be more...normal. Some days the front of the Pathy just looks so high! -
Hey karmann, on some of my other vehicles, here is what I noticed when hearing a pop/twang...noise: On one vehicle, the spring was not seated correctly and every time I turned, it rotated ever so slightly but because it was under pressure, it twanged (a pop with resonance) re-seating the spring corrected the issue. The way I diagnosed it was by having a friend turn the steering wheel while I listened with the hood open On another vehicle, the nut at the top of the right strut was loose. Every time I turned left, the geometry changed and the threads on the strut top popped as they rubbed up/down against the strut top hat. This reverberated all over the cabin. I had to replace the strut. The way I diagnosed it was by having a friend turn the steering wheel while I listened with the hood open. To confirm my findings, I also rocked the car from side to side and up/down at both front corners while a friend watched and listened. On another vehicle, the culprit was a torn engine mount. I replaced and filled it to prevent it from tearing again, darn Mazda mounts. This one too a while to diagnose as the issue occurred on acceleration and turning to the left. Eventually, with the hood removed, driving around the block, I saw the engine rocking or rather bucking violently. Mount was so far gone that almost no rubber remained (This on a 5 year-old Protege5 too) Lastly, I've experienced popping noises coming from my Pathfinder's suspension. One was a worn ball-joint, another was due to weak/torn anti-swaybar bushings. Lately the noise is coming from the new strut boots (these are made of a more rigid plastic which make noise when they impact the top of the strut body as it compresses. Yesterday I was having issues with an axle replacement. The new axles were binding when turning left and every time the axle turned over the cups (inner axle CV) it hopped and made a popping noise. Diagnosed the joints and bushings by getting under the truck, prodding, pushing pulling, turning the wheels, looking in through the engine bay, checking all suspension components, etc) The axle issue, not 100 % sure yet but have a good lead thanks to rebelord and other great folks on this forum. In short, I'm just echoing pretty much all the answers given above by others with my experiences. All you need to do now is find the time and a place to go at 'er. If I remember anything else, I'll post again. Good luck and please post your findings.
Pics of the late winter and early spring! All pics welcome
Bluewulf73 replied to DsR50's topic in 96-2004 R50 Pathfinders
Wow! you gained MPG with no doors??? I can see how losing the weight would increase your MPG and power but towing and no doors increased your MPG!? Darn Vancouver rain, BC laws and wife!!!!I want to increase my power to weight ratio and mpg too. I didn't even think of or see the mirrors when I first saw the photos. Very stealth... -
That looks like a useful tool. Believe me theexbrit, I've been looking around for an alternative (brush-guard, bumper, etc) for a while. These are hard to come by around here. Well, at least decently priced ones... True-dat. I have been researching other uses (read - watching youtube) for the hi-lift and have it on my pathy with some chain and other recovery gear just in case. Never had to use it yet but am itching to try it as practise (before I really need it.) I don't rely on my cellphone in the bush. Ever. I do carry a CB and FRS radios with scanning possibilities but when I go wheelin' alone, I go expecting no help from anyone. If I get some, I consider myself very lucky.
