345
Looks like the 240 guys have a Honda motor they like. Might be inspiration if nothing else.
I've heard of people swapping in the intermittent wipers on older/base model rigs that didn't come with them, but hot-rodding the actual motor is news to me. Mine has always seemed plenty strong to me. It'll stall if the blades are frozen down or trapped by snow, but in that case I suspect more torque would just break something. If yours feel weak, I would check for voltage drop (weak switch or wiring), dry bearings/pivots, hard grease in the motor--basically go over it looking for something seized or gummed up or otherwise sapping power. With a little fabrication, and some wiring, I imagine you could get most any wiper motor to work. The wiring could be tricky depending on how the donor was set up. Some wiper motors have high/low/ground wires, some are case-grounded, and some are ground-switched. And then there's the wiring for the self-parking and the intermittent function, if yours has that.
Right in front of my eyes! No wonder I couldn't find it.
The throttle position sensor is one of the inputs the trans computer uses to decide when to shift. I think that's how it decides how hard to shift, too.
+1 for taking it out in stock form and seeing what it needs before digging too far into it. That said... If you've got the automatic transmission, consider adding an external cooler to help it out. Look up the Missing Link. I don't have an R50 to try it on, but I've read it firms up the unibody a bit. If you've got the open rear diff, you can swap in a limited slip. Hawairish did a great writeup on repacking the LSD for higher breakaway torque, and a table of donors and specs for the stock units (scroll down a little). Looks like early Xterra is your best bet if you want to drop one in without taking it all to bits. Just make sure your donor has the same gear ratio. That's listed on the data plate in the engine bay, look for HG43 or HG46. Other than that, I would check the strut towers and fuel filler for rust (hopefully low miles means it hasn't seen too much east coast road salt), and make sure it's up on its maintenance. At 78k, it may still have its original timing belt.
Halfway there! I don't remember what code it threw, if any, but IIRC my dad's '01 had a random intermittent misfire that the dealer said was probably a coil pack. They couldn't track down which one was the problem and wanted to do them all. A set of coil packs ain't cheap, so I would first look for any obvious vac leaks, gunk on the MAF, maybe check the color and condition of the spark plugs to see if you've got an overall mixture issue or an obvious single-cylinder fault (or a bunch of oil in the plug wells). Have a look at the coil packs while they're out, look for evidence of arcing. Do you feel the misfire under certain conditions?
Heat coming from engine bay
Slartibartfast replied to Mrelcocko's topic in R50 FAQ's & Pinned Topics
Running the aircon does make more heat, but I don't know how much of that heat would get around the inner fenders. The panels on mine get hot this time of year because the sun is out (usually, right now we're smoked in) and the paint is black. -
R50 Front Quarter Panels (pre and post face lift cross compatible?)
Slartibartfast replied to Tomek's topic in General Forums
From what I've read it sounds like you can swap panels pre/post facelift, but only if you do the whole nose. And yeah, the QX4 should be mechanically the same. Maybe more likely to have the auto transfer case. -
We have a dark theme?
The auto trans shifter connects to the transmission through a cable. My understanding is that the cable has more than enough slack to accommodate the lift, so this isn't a problem. The transfer case shifter may hit the floor after the lift, in which case you will need to bend the shifter or notch the floor.
Yes, these can be body lifted. Lots of info here.
If you're asking which hard line is supply vs return for the cooler, looks like this guy found the answer. Fluid leaves the trans on the driver's side, returns on the passenger's side. The procedure to set the fluid level (with target temps and all) is in the MA section of the service manual BTW. Good luck!
I haven't had a problem from changing old trans fluid. It was one of the first things I did when I got mine in hopes of extending the life of a high-mileage transmission. Brown trash out, red trash in. 20k later it's no worse than it was. I suspect the "new fluid kills it" story comes from people changing the fluid as a last-ditch attempt to save a trans that is already slipping, where the thin gritty fluid was the only thing making the clutches grab at all. A few years ago I changed the trans fluid on an S10 where the fluid was black and smelled like a wet ashtray, and that thing's still going, much to my amazement. Rather than fluid quality, I would look at the quantity. Trans fluid levels can be PITA to set correctly, and I've read overfilling can cause the transmission to act strangely. The dipstick's meant to be read with the engine and trans warmed up. I set mine cold, warmed it up, and had to drain some back out. I would also double-check any electrical connectors you disturbed when you thought you were dropping the trans, though if something wasn't plugged in I'd expect trouble codes. IIRC the WD21 manual tells you what temperature to check the fluid level at, which would be nice if they gave you any idea of how to check the fluid temp. I haven't checked the '01 manual but I wouldn't be surprised if you could check that through live data on an OBDII scanner.
The plug wells are supposed to drain into the area under the lower manifold, but the drain is usually blocked with casting flash that they couldn't be bothered to clean out. I cleaned mine up a bit when I had my intake out In hopes that it would make life easier if/when I was in there again. You want real fun, try getting a compression tester with a bent hose to thread into #6, with the intake on.
Black with cloth is bad enough!
I haven't tried to install it yet, but I bought a GPD drier for mine, PN 1411457, via Rockauto IIRC. It has bolts going into both sides at the top, one of which I assume I can just remove to install the pressure switch, possibly using a fitting from the old drier. One of these days I'll get around to fixing my aircon, but this is not that day.
Did you bleed the cooling system after fixing the leak? There's a bolt on the intake manifold, should be marked "do not open when hot." Remove the bolt (with the engine cold, obviously), gently squeeze the upper rad hose until coolant rises up to the threads, then hold it there while you put the bolt back in. Check the rad, top it off if needed. Might help. That said, the temp creeping up when you're pushing it hard on a 100° day does not surprise me. The one time my '95 tried to overheat was under similar conditions.
Sounds a lot like how my '93 drives! I think the trouble with mine is as much the engine being gutless as the transmission doing dumb things. Shifts up too soon, doesn't want to shift down again, then acts all surprised that my foot's on the floor and revs the tits off the engine trying to catch up. Turning off the overdrive on hills helps a lot, both because it can't grab overdrive while climbing and because I've got some engine braking on the way back down. It changes the behavior of the torque converter, too. Mine's also got an E-AT switch, which bumps up all the shift points. I leave that one on all the time. I don't think the R50 got that switch, though. I've got a VG33 with VG30 cams in it waiting to go in my '93. That's the usual strategy for warming these up. Past that, you're looking at forced induction and/or machine work. Sounds like you've got most of the tune-up stuff dealt with. Check your ignition timing (should be 15° +/- 2 at warm idle) and check the intake boot between the MAF and the TB for damage. While you're under the hood, check the data plate in the engine bay, see if you've got HG43 or HG46 diffs. Auto usually got HG46, but if you've got HG43, you can swap in the 4.6 diffs and get a little torque back. I hear you on holding up traffic. I got passed by a Winnebago in my '95. I wasn't even trying to let him by.
I've heard of people doing it. No drag until you need it, unlike the clutch fan. You can turn it off for water crossings, so that's cool, if that's a thing you do. But it's got more parts to fail, and if the fan motor itself dies, you can't bodge it to limp home like you can with a clutch fan. It's an additional load on the alternator. I've read they struggle to move as much air as the clutch fan. I've considered an e-fan for mine. It would be nice to free up a little power and get rid of the vacuum cleaner howl at high revs when the clutch is locked up. But the fan clutch is there already, and it's reliable.
Looks like it'll take it. The rack on my WD21 has a sticker that says 80 lbs evenly distributed, but I suspect they rated it for stability rather than roof strength, so they wouldn't get sued if some muppet went canyon-carving with a piano on top.
Electric rear hatch poppers were a thing on some R50s and can be swapped in if yours didn't come with one. I know I saw a thread recently of someone doing just that, but naturally I can't find it now. This thread suggests they weren't tied into the security system, though. I don't think these ever came with electric fans, so I doubt the computer or harness was designed to run them.
Slartibartfast replied to RedRider3141's topic in The Garage
Hooked it to a trailer it's entirely too small for and went on a rescue mission... for a Cub Cadet. -
If you don't see smoke, I wouldn't worry too much. That's not to say it couldn't catch fire--GM did a recall for their 3800s doing exactly that--but most things I've worked on were leaking some amount of oil onto the exhaust, and none of them came in because of engine fires. I can smell the leak in our snowplow, and it annoys me, but not enough that I've bothered trying to fix it again. My friend's Toyota was leaking bad enough that the oil was pooling between the head and the exhaust manifold gasket. That one was bad enough to smoke after driving, and bad enough that we replaced the gasket for fear of it catching fire. I'm running high-mileage oil in my VG because it's cheap and why not. I haven't tracked my rear main leak to see if it's slowed any. Thicker oil might leak a little slower, but I wouldn't expect any flavor of goo-in-a-can to fix the gaskets if they're hard and cracked like mine were. If you can get to the valve cover fasteners, you might try snugging them up a little. IIRC there's also an oil cooler on the VQs that can leak, something else to check. I wouldn't assume it's a crankcase pressure issue just because it only leaks while running. The engine only pumps oil to the heads when it's running. My dad had the PCV done on his '03 (chasing the quart/1000 miles oil consumption) and the guy said he managed it without pulling the intake, but it didn't sound like he had fun doing it. It didn't solve the oil consumption. I've heard various explanations for why some VQs guzzle oil, from the design of the PCV baffles to the power valve screws falling in and chewing stuff up to excessive bore taper. My dad's smoked on warm starts, but otherwise drove fine so long as he kept oil in it. And, yeah, the IACV leaks coolant into the electronics and smokes the driver mosfet in the computer. Genius-level design at work there. The VG has its own quirks/issues, but, yeah, I wasn't impressed with the VQ.
97 pathfinder speedometer and odometer not working
Slartibartfast replied to Kurtice's topic in 96-2004 R50 Pathfinders
Auto or manual? If it's auto, and it's shifting normally, that would suggest the trans computer knows what's going on even if the engine computer and gauge did not, which might help narrow it down. If it's manual, well, there's that theory shot. And, yeah, go get the '97 manual from Nicoclub. Should be some troubleshooting or at least a circuit diagram in the EL section. There's a lot of hand-holding for using the special dealer Consult tool, but there's usually an alternate method for the rest of us. If the sensor is good (and so is the gear that drives it), and both the cluster and the computer say they're not seeing anything, that would have me looking for a wiring fault in between them.
