345
Obviously you'd save yourself a whole lot of work by finding one that already has the interior you want--but, yeah, I've seen swaps the other way, so it's possible if you don't mind some screwing around. Round dash has an electronic speed sensor, square dash has a speedometer drive cable. Radio is the same AFAIK, though the amp location changed over the years. Vent controls should be the same. These never had airbags (with the exception of the '96/'97 HB), so you're not losing anything there. The slip rings are different between round and square dash wheels (because the later wheel had the cruise control buttons on the wheel), not sure how much you'll have to swap there. The door panels and seats should swap. HB parts should fit just fine. My '93 (tail end of square-dash) does not have those metal covers, not sure if they were an option or an earlier thing. The front seats from the two-door trucks have a flip-forward function that the four-doors don't. Pretty sure the Hardbody seats have the flip-forward action too. I don't think the bolt pattern changed, though. You can get a '90 service manual from Cardiagn and a '94/'95 manual from Nicoclub to compare the wiring diagrams. I would also look for a dash swap writeup on the Infamous Nissan forum. If anyone has a walkthrough, it would be them. I agree that the square dash fits the shape of the truck better. I'm less sold on the red interior, though. Blue is nice. I don't think I've seen that tan interior before. I'd take it over the red, but, yeah, definitely ten years newer than the look you're chasing.
Thanks for keeping the lights on Red!
Rear Pinion Seal Replacement Mess up
Slartibartfast replied to PFFlier's topic in 90-95 WD21 Pathfinders
Can you catch a fingernail on the groove? I did wonder about that when I saw the list of shims in the manual. What do you do about that when you re-gear these? Weird that the torque spec changed. Maybe they changed the thread pitch? -
First one has the pink/blue and pink/black wires of the dash illumination circuit, so it's probably for a dash switch. If all your dash switches are present/functional, it may be for an option yours doesn't have. Second one, not sure, picture's kinda washed out. Relay looks like the starter kill for the alarm (black/yellow are starter wires). The two plugs could be identified using the wiring diagrams in the EL section of the service manual, free download from Nicoclub. They're not too tough to read once you realize "L" means "blue." The alarm system is not in the manual.
Yeah, I got it too, on Safari. It's happened before, I think it's an expired security cert or something. I imagine Redpath will sort it out when he gets a minute. It's annoying how protective browsers get about that sort of thing (mine made me enter my admin password to get in!) but they're probably assuming we're about to send our bank info to North Korean hackers or something. I had to partially lobotomize Microsoft Entourage a while back to open an attachment it didn't like. Some weird obscure file format. I knew who it was from, and I knew it was fine, but try telling Microsoft that. I found the file with the list of blocked file types, removed them, opened the damn attachment, and felt like a hacker for about five minutes.
Yeah, it's weird that the manual doesn't show doing that. They show using a puller to get the flange off, maybe they thought the splines were tight enough that it wasn't necessary? I doubt a light coat would hurt anything, though I would wipe off any excess that squeezes out before putting the nut back on. And yeah, I hadn't looked that up before, and now I'm relieved that I don't have an H190 or C200! What a PITA to replace one oil seal. -
I haven't dug into this on mine, but I had a look at the service manual, and it looks like it's easier than you think it is--assuming you've got the H233B, which AFAIK all 4WD V6 Pathfinders do. PD-16 in the '90 service manual says that all you have to do to change the pinion oil seal on an H233B is remove the flange nut, remove the flange, replace the oil seal, grease the oil seal, reinstall the flange, and torque the nut to between 145 and 210 lb/f--and that's an acceptable range, not an adjustment. Pinion bearing preload and pinion height are set using shims. There are specs (in inch pounds) for how hard the assembly should be to turn, to make sure you didn't screw something up after an overhaul. If you haven't done an overhaul, these tests should not be necessary. I don't see anything about measuring the loosening torque. The H190 and C200 rear ends (only used in 2WD and/or four cylinder applications AFAIK) use collapsible spacers (crush sleeves) to set the pinion bearing preload. The manual says you can't replace the pinion oil seal on those without overhauling the whole thing. You can download the '90 manual from cardiagn.com or the '94/'95 manual from Nicoclub. Both are free. If you want to talk to someone who knows more about the H233B than the rest of us combined, try @hawairish. -
I remembered today that the only time I've had the steering fight me in a 4x4 was when I shredded the spider gears in the front end of our IH snow plow. What was left of them kept trying to lock up, which made turning very difficult, though I suspect that was more aggressive centering than torque steer. Jack up the front, in 4x, hubs locked, and turn one wheel. See if it all turns smoothly. Then check over all the front suspension. Strut rods and UCA spindles especially. If a damaged strut rod chose this moment to let go, or a spindle bolt pulled its threads because it was too short after the lift (too many shims behind it), or something along those lines, the wheel could be dragging the damaged suspension around when you put power down. If this is the case, I'd expect it to be spooky under brakes, too. Edit: if you've got a tape measure and a couple pieces of something straight (I use angle iron), you can get a ballpark toe reading at home. Sounds like that's the first thing to check.
Where did you find that part number? It's not getting me anywhere either. Poking around on NissanPartsDeal, I found what looks like the right critter, but there are two part numbers for what looks like the same thing, and both are discontinued. 33084-5W900 and 33084-5W905, both listed as 07/2002+. Your VIN might narrow down which one you've got, and the part number might turn one up elsewhere. Worst case, you might get lucky at a wrecking yard. TF-48 in the '04 service manual (available here) shows you where to find it in the truck. Did your mechanic say how they narrowed it down to the control module? I would go through the TF section of that service manual before assuming the module is in fact the problem. Should be some troubleshooting in there that'll help you narrow down what's gone wrong. It assumes you have Nissan's special scanner, but there's often a "without CONSULT" diagnostic procedure. The manual calls your transfer case ATX14A. The diagrams on factorynissanparts call it out as XN3, for some reason. Does it drive like it's stuck in 4x4? Does low range work? Long shot, do you have manual locking hubs? Sometimes those trigger the trouble light, not because they're hurting something, but because the computer wasn't designed with that in mind and it gets confused. The ATX14A is not a unit I would want to open up or try and jerry-rig. It's a complicated little bugger.
Yeah, that's all I can think of that wouldn't make it favor one side consistently. Does it drive normally in 2WD?
Still sounds consistent with a bad alt to me. The lights take power to run, the alt has to generate that power, so if the alt is weak, makes sense an added load would make it worse. Unless you mean turning the lights on kills the reception with the engine not running--that's a different and entirely more puzzling bag of crabs.
Did you align the front end after doing all that steering/suspension work? Could be your toe is way off.
94 Pathfinder odometer stopping working
Slartibartfast replied to xylicon's topic in 90-95 WD21 Pathfinders
Agreed that it sounds internal to the cluster, as it's clearly getting signal from the speed sensor if the speedo and trip odo are working. I haven't had a round-dash cluster apart to see what makes it tick, but I assume there's a little stepper motor in there that turns the odometer. Stopping on 999 suggests something wasn't up to turning four wheels at once. Might be some schmutz binding up the mechanism. Hopefully it just stalled out the stepper, rather than breaking a little plastic gear somewhere. If it's like the square-dash cluster, it should come apart without too much fuss. -
The idiot lights do have colored film in them, but I would match the LED color to the film color if possible. Tinted films don't change the color of light, they just block light that isn't that color. I would not expect a blue LED to push much light through the red film on the tach. After the fun my friend and I had with the cheap LEDs in his cluster, I stuck with tungsten bulbs for mine. I did however change out the dome and footwell lights, less for brightness than for current draw (so I can work out of the back all day without killing the battery). Those are great. The directionality of LEDs bit me on the map lights, though--the bulbs I got fit the sockets, but the diodes are facing the plastic housing, not the lens. One of these days I'll bother fixing that.
1) The bulbs in the cluster are easy. HVAC shouldn't be too bad. I vaguely remember seeing the bulb for the shifter under the plastic cover, but it wasn't burned out, so I left it alone. I've replaced the bulbs in most of my dash switches (rocker-style) with component LEDs and resistors, soldered in. The factory setup for those is a little tiny tungsten bulb with its leads wrapped around a rubber base, so I doubt a drop-in LED conversion is available for them. They're fiddly to get out of the dash, fiddly to disassemble, and fiddly to solder, but the end result looks a lot better than a switch with a dead bulb. I haven't tried this with the round-dash push-style switches, but I assume it's a similar arrangement inside. 2) I think the big bulbs in the cluster are 194, and the little ones and the HVAC bulb(s?) are 74. I could swear there was a list around here somewhere. Do not trust the bulb finder on superbrightLEDs, I made that mistake once. 3) The original tungsten bulbs, even the tiny ones in the switches, have tinted rubber condoms over them. The cluster itself is not tinted AFAIK, with the exception of the orange cluster in the early square-dash. The switches I've had apart are not tinted either, with the exception of the hazard switches, most of which are red where the light comes through (use a red LED). 4) I haven't tried LEDs in a WD21 cluster, but a friend of mine got hot spots when he used cheap LEDs in his Chevy. (Don't use cheap LEDs, they crapped out and started flickering.) Those had bare diodes facing out in a cube shape, so of course the light pattern was weird. I've seen bulbs with a frosted plastic cover over the diodes, which I would expect to work better. It may take some trial and error to get the look you want.
That I don't know. Hopefully someone more familiar with the VQ R50s can help you there.
New guy, looking at a 1st gen, price check?
Slartibartfast replied to grahm's topic in General Forums
Good, you should be well-equipped for this then. There's nothing too weird with the EFI, just the usual OBD1 stuff. Blinky-lights diagnostics, limited live data. It's not as easy to diagnose as OBD2, but it's not too bad if you don't mind spending some quality time with the EF&EC section of the service manual. Cardiagn has the '90 manual for square-dash, Nicoclub has the '94/'95 manual for round-dash. Both are free. I have not found a '93 manual in PDF form, and mine's square-dash, so I use the '90. -
That looks like a very clean rig. It's towards the higher end of pricing, but not the highest I've seen. One went for $20k on Bringatrailer. If you don't mind doing some wrenching, and you aren't looking for a museum piece, you can likely find one much cheaper than that. My '93 cost less than a grand (pre-Covid), but it had about 230k on the clock and needed some work. They are reliable, but any 30-year old truck will need some work done eventually. If you don't do your own wrenching, you may have some trouble finding a mechanic willing/competent to work on OBD1 fuel injection. -
2001 was a changeover year from the VG33E to the VQ35DE. This is why you are finding conflicting information. The 2001 service manual (VG33E) shows the sensor mounted by the computer, and has a wiring diagram, pinout, voltage checks, and step-by-step troubleshooting information. EC-160. The 2001.5 service manual (VQ35DE) says the sensor is built into the computer, which would explain why you've been unable to locate it. There are no diagrams or checks. The only troubleshooting shown is clearing the code to see if that magically fixes it. If the code comes back, replace the computer. EC-158. I would open the computer and see if there's an obviously damaged component or connection, or whether the sensor inside has any markings that you can use to locate a replacement. You might get lucky and find a broken wire or a cracked solder joint, or find that the sensor itself is a standard off-the-shelf component that's still available. Or, if you have a bunch of other codes, try chasing those down first, on the off chance resolving one of those somehow clears this up as well. Otherwise, looks like it's computer time. The cable-throttle VQs ('01 and '02) have a common fault where the IACV shorts out and blows its driver mosfet in the computer. This is unrelated to your P0105, but something to look out for if you have to go computer hunting. You can get both manuals here. I recommend downloading the whole manual for your year. There's a lot of good info in there, if you can wade through the hand-holding for the Consult scanner that they assume you have. and good luck.
Yeah, graphite's not gonna fix that.
Ahardbody posted ages ago that he'd had his lock cylinders apart and found them pretty easy to work with. Unfortunately his pictures are gone, and the beergarage writeup he linked to is gone as well. I got the frozen driver's lock on my '95 working by blowing a bunch of powdered graphite in there and working the key until it freed up. Worked great, never had another problem with that lock cylinder. Boy did it piss off the power locks, though. I don't know if the graphite got into something or if working the cylinder free exposed an issue elsewhere.
I don't know the R51, but I'd start by downloading the '11 service manual from Nicoclub and looking for a wiring diagram to see how that system is set up. Sounds like the motor is okay, but something in the controls is acting up. Maybe a loose connection, or a bad solder joint? Intermittent issues are always fun to track down. Good luck!
At least the leak stopped! Figures it came up with something new. If this started when you fixed the leak, I would double-check the stuff you had apart. PCV hoses back on? Any damage to the intake boot? Any vacuum lines messed up? Sounds like a vacuum leak to me. Mine stalls on warm idle now and then. Weak connector. Hasn't done it since I picked up a replacement connector, naturally. If you don't find a vacuum leak, inspect the MAF connector. Might as well check the sensor too, on the off chance something got in while you had stuff torn apart. You counted teeth when reinstalling the timing belt, right? I imagine you'd have worse symptoms if that was a tooth off.
Rear Side Window Trim Removal?
Slartibartfast replied to gamellott's topic in 90-95 WD21 Pathfinders
I am impressed that you got it out in one piece! I had a go at one of mine a while back and had enough trouble with it that I painted the other one in place. -
Random Body Clip Replacements?
What do they look like? I searched that part number and found some metal clips I've never seen before. IIRC the rear hatch plastic is held by white plastic clips. If that's what you're after, I probably have some in my bag of random clips off the partsfinder.
