Slartibartfast
  1. I dunno, it doesn't make sense to me. The hardbody in the vid looks kind of cheap with how the doors move... they open a little bit normally, then tilt up? Seems like if you're gonna do it, it should be one smooth motion. Otherwise you'd get some idiot like me trying to open the door, and when it only opens three inches, reefing on it and screwing up the hinge assembly. (And it just looks sketch.) Also, with the shaving/fobbing, what do you do if you leave the lights on and kill the battery? You can't jump it without getting inside to pop the hood. Do you crawl in through the rear window, or is it on the fob too? Or maybe the battery in the fob craps out after a few weeks of showing off your new doors. Either way you're standing in the parking lot waiting for the locksmith (or deciding which window to break). Having the doors swing up might be nice in tight parking spaces, but other than that, I'm not feeling it. It's not my truck though.
  2. Well, there aren't any good codes... the knock sensor code can put the engine into 'limp home' mode, which limits the engine to 3000 RPM, if it looks like the engine is knocking due to pre-detonation. IIRC it needs to get above a certain level for the computer to go into limp mode? It's clearly not in limp mode, but the sensor code suggests that the steering wheel isn't all that's shaking. I suspect you have a timing issue, which is making the engine fire wrong, setting off the sensor.
  3. So it drives fine but struggles on hills? Mine does that if I leave the overdrive on. Assuming yours is auto, try going up a hill with the O/D off and see how that works for you. They'll slip into OD while cruising and then try to bog up a hill in it. I've heard that seafoaming the intake helps get some power back. There's some disagreement about putting it in the crank case, not for fear of buggering the seals, but on the off chance that the crud it loosens could clog something else. When I got mine, the exhaust was hammered, and at least one of the two cats it had was clogged. It got a lot quieter and seemed to pick up a little power with a new exhaust.
  4. This guy: http://www.nissanpathfinders.net/forum/topic/32903-wheeling-in-rocks/
  5. I imagine it's a matter of having enough room on the carrier to mount the can. If you've got a smaller can you might not need to.
  6. Mine had starting issues a while back that ended up being a gunked up fuel pump. I ran it real low (the light was on for, like, three days of commuting) and then sloshed the fuel around, which apparently got some crud into the pump. It wouldn't start unless you floored it, and it would run like absolute crap if you did. We didn't keep it running long enough to see if it evened out. A shop cleaned out the fuel pump, and it's run like a top since. I think it was somewhere around $100 including diagnosis, but you could probably do it yourself. Again this doesn't explain how it would start running properly after a while... maybe check the wiring to the pump first, maybe there's crud built up and it's holding water? Wouldn't hurt to check your fuel filter too.
  7. Very few companies make Pathy bits, so I doubt it. I'd stick with the trans the VQ came with if possible, it should be a lot beefier.
  8. I'd like to see a 3.5l WD. But the VG33 R50s are OBDII, right? Isn't the engine (minus the intake) basically the same?
  9. Looks like there's a strap (bike lock?) around the handle in the first two pics. Edit: didn't see OP's reply until I'd posted, and 'delete' is no longer a thing.
  10. If you're worried about people stealing it, just put a cheap can back there as a decoy, and fill it with horse piss. The lulz of somebody actually stealing it would outweigh the obvious downsides of carrying a jug of piss everywhere you go. Then again, maybe not. Nice work on with the carrier.
  11. So it's hard to start, doesn't run well, then clears up? Sounds like moisture somewhere, burning off once the truck's warmed up. If this was a VG engine I'd say dizzy, but I don't think the VQ actually has one.
  12. WDs never came with airbags that I know of. Good to hear your wife/gf is okay though! These things are built like tanks. And yeah, my dad always gives me crap about putting in more than it's worth. Resale value only matters if you're building it to sell!
  13. http://www.nissanpathfinders.net/forum/topic/32546-how-to-replace-strut-rod-bushings/
  14. For the tension/compression/strut (so many names!) rods, you'll likely need to replace the cups that hold the bushings in place. I had my uncle weld a set of L6811 bearing cups to mine, as the stock cups were busted and rusted out and holding on pretty much out of habit. Check out the thread (I think it's Tungsten's 'does this qualify as good strut rod repair' thread) before diving into yours.
  15. I drop it out of OD as soon as it feels like it's bogging, partially from impatience, partly because the longer it does that, the more heat it makes and the more it slows down. I drive the same route four days a week, so it's mostly habit at this point. At 65 you should be fine to drop it down. I routinely drive 60+ with the OD off, and it stays at around 3.5k. I've never felt heat coming off my transmission hump, so I dunno what to say there. I've heard that it's common. My commute is pretty short. Taking it out of OD should help keep the trans cooler, though.
  16. Go home, Pathfinder. You're drunk. Also, I see you're not the only one who likes olive drab.
  17. Did soldering yours change anything? I did pretty much every connection on mine, and it still spazzes out sometimes.
  18. I had a local alignment/tire place do what they said my front end needed. Upper and lower ball joints, centerlink, TREs, idler, alignment (my uncle and I did the strut rod bushings later). I don't remember the exact figure but it wasn't cheap (more than the Calmini kit IIRC). But the ball joints were cracked and oozing grease, and it wandered pretty badly. I didn't get the chance to check over the parts they pulled and see which of them were really the problem. They probably weren't all hammered, but my dad paid the bill (said he didn't want me wrenching on stuff that could kill me/others if I buggered it) so I didn't ask a lot of questions. I think it's better than it was before, but it's not dead tight yet. The shop suggested that the rear link bushings might be wearing out, which is consistent with what I've read on here. Maybe this spring I'll tear into those. If you notice the looseness mostly on bumps, this might be something to check out on yours. The centerlink should have a little tab on it where the stabilizer mounts. Should be in the FSM. I hear stabilizers make it ride better, but don't just throw one on and ignore the other issues! The stock system is a little sketchy if you plan to lift the truck or wheel it hard. If not, it's probably adequate. The Calmini kit looks like a much better design. This might be relevant:
  19. Is this with the engine running or not? If it sparks to the body it's clearly not ground.
  20. Works fine for me in Firefox. Another forum I use (vBulliten based) has an annoying habit of thinking I've logged in again halfway through a post, and so when I hit 'submit' it deletes the message... that site's a PITA. No problems on here though.
  21. Nice work. If your steering box is shot, chances are your strut rods need attention as well. They're something to get around to sooner rather than later. But yeah, those doughnuts had to go!
  22. I leave mine off up to 45, and even then I only click it on once I'm up to speed. My (likely flawed) understanding is that OD/off locks up the converter and disables fourth gear, which keeps the heat down and the engine speed up so you don't have to floor it to gain speed. OD's nice when you're cruising on flat terrain at a steady speed and you don't need to be pushing 3k rpm, but the rest of the time it makes the truck sluggish and makes a lot of heat the transmission doesn't need in the process. A new tranny cooler could eliminate the heat concern, but the truck would likely still drive like a heifer.
