RF600
Everything posted by RF600
  1. Something to think about. Fuel lubes and cools the pump. So I don't let my fuel gauge to get below 1/4 tank. Things happen and we all can't keep fuel in the tank.
  2. RF600
    Small lift
    I doubt the bar would be off that much. That may be something I would address after I get the lift on. There is a little bit of room to redrill a new hole and move the bar a little.
  3. Photobucket is a good site for storing pictures. They have upgraded an now have editing features. Pretty slick.
  4. RF600
    Small lift
    I read through the thread where a few guys talk springs and rates. Most of it does not compute. I understand the basics though. I'm trying to get as much info as i can so I can hopefully have no suprises. It is pretty straight forward. I am not worried about not being able to do it. My next concern is the pan hard bar. I have not decieded whether to redo the axle side or body side mount. I like the idea of raising the roll center. I will have to look at things and go from there.
  5. RF600
    Small lift
    I must have missed something when reading the lift spring thread before. The springs I have should give me the 1" to 1 1/2" lift I am looking for. Still if anyone has any pics please post them or let me know where I can go to see them.
  6. RF600
    Small lift
    I have read through the lift spring thread many times now. Has anyone installed the .50 springs that has info on how much it lifted it? I am figuring it will be the 1" to 1 1/2" I want. The spring diameter is .546 on the springs I have.
  7. RF600
    Small lift
    On the other side of the mountain from Tahoe. My dad lives up hwy 70. I see your post. If it was a snake I would have died.
  8. RF600
    Small lift
    Precise1 I searched your used name and nothing came up. What section did you put it in? I don't do a lot of off road. Maybe a couple times a year in the snow.
  9. WD, why, because that is what I have. I have not rode in a newer one.
  10. 31x10.50x15 Hankook Dynapro ATM on Legos. Small lift hopefully soon.
  11. RF600
    Small lift
    Thanks guys. My rockstar party days are over. Not as much fun as it used to be. Plus it takes a little longer to recover now that I am a bit older.
  12. RF600
    Small lift
    I have a 95 with the tire carrier on back. I just put on the proper sized tires and it need to be lifted some to make it look proper. I have been reading a lot about lifting the wd21. Most people are lifting 2"-3". I only want 1"-1 1/2". I have the .550 jgc springs. Which I think will give me the right lift. I do have a couple questions. 1. Do I need to worry about rear pan hard bar being not parallel to the axle? 2. Will this effect the ball joint angle on the control arm? 3. Is it better to crank on the stock torsion bars or get new ones? I know they will have to be re indexed. I have already cranked on them some to pick up the saggy front end. I have read that ball joint angle isn't affected until you go with a 2" or higher lift. Has anyone had issues with a small lift? I think I will be ok. I need some reassurance from some of you who have experience with this.
  13. Finally put the proper size tires on. Got an extra lego wheel for a spare. I had to grind a little off of the spare tire holder lip so the hub cap would snap onto the wheel.
  14. I have lug centric spacers on my car with no issues. Running 18" rims. I torque them down 3 different times. 1st is snug. 2nd is 30lbs. 3rd is 80lbs. I don't let the car sit on the ground when doing it. Kind of a pain but it works. If I don't do it right I get a vibration about 40. Torque in a star pattern. I also don't start and stop with the same nuts each time.
  15. I was talking with a tech from Nissan and he recommended not using platinum plugs. There were platinum plugs in when I did my last tune up. I didn't have any problems with them. I put regular plugs back in.
  16. That is the kit I used. If you go cloth braided it is easy to work with. I put an extra heat sleeve over my hoses. I had rubber lines made.
  17. If you already have the wheels you can buy a bunch of flat washers. Put equal amounts on 3 or 4 studs. Put the wheel on and see where it sits. The washers are approx 2mm each. Add up the amount of washers and get spacers based on that. Spacers usually go in 5mm increments. Like 20, 25, 30. Obviously depending on the amount of spacers you may not be able to put the lug nut on and have it hold.
  18. Sorry I misunderstood the question. I forget if I did or not. I believe the nipples are pipe thread.
  19. There are 3 wires on the connector. You want the solid black wire. I perfer heat shrink butt connectors. There is a ground on the core support that I used. Add in your ground and attach to the existing ground. Attach the wire to the butt connector. Heat shrink and wrap with tape and be on your way. I bought a new connector when I did mine. A 3 wire TPS connector.
  20. Like others have said you have to read what is and what is not covered. They might cover some internal items, but if you have a seal leaking that would be considered external, so that might no be covered. That was an example. If you can turn a wrench then I would say you can probably go without. Another think to think about. Some external warranties only pay so much per hour for labor. They might pay $50 an hour. The shop doing the work might be $80 per hour. You would have to make up the difference.
  21. No thread sealant. The ends look like AN. The hose is rubber but I think it is like hydraulic hose. I put a heat shield around it because it is close to the exh manifold.
  22. Added a ground to the maf connector. So far it's not wanting to die on me when I come to a stop. It acts like a iac valve was going out. Already replaced that.
  23. I had my local Napa make the lines for me. I'm using 45* fittings on the adapter end. Straight on the end of the line.
  24. This is gonna sound weird. I was having a similar issue. Would want to die when at a stop sign, not all the time though. Anyway I was reading through some older threads about this issue. A couple people had somehow figured out that the maf was dropping its ground at times. Their fix was to add a ground wire to the maf connector. After I put the extra ground in I am having no issues. Worth a try.
  25. I thought it was fixed. Still having the same problem. I'm just dealing with it for the time being. One of these months when other things stop using my extra money I will attempt to deal with it. I'm leaning toward the distributor.
