Nefarious
  1. Just replaced upper and lower ball joints on both sides as well as a bad outer tie rod. Also replaced the rubber upper control arm bushings with poly on one side so far. Never seen bushings that bad.. the UCA had nearly a half inch front to back play when I removed it from the ball joint. The old lady's truck is finally becoming a solid rig after all this work. Checked the other side UCA bushings but they are much more solid so we will save those for another day. Now time to go out for dinner.... i am tired and hungry after all that wrenching! Not bad for 8 hours work.
  2. I've never seen a wheel bearing even close to that bad. Brutal.
  3. Nefarious
    Odometer
    Hmm that's good to know... I need to replace the ones in my s13
  4. The small orange wire is oil pressure switch. I've seen them disconnected more often than connected on older pathy. Easy fix . As for your torsion bars you just need to re index as it's called. I would re index both sides if it were me but if you are only sagging on one side you could get away with just doing the one. The way I do it is this: First put a sharpie mark on the torsion bar and a corresponding mark on the anchor to show original orientation. Crack the upper 19 mm nut (on the stack of two that lock down the torsion adjustment bolt) and just twist it back a thread or two until it again lines up with the nut below it. Then stick the 19 mm wrench over top of both the upper and lower nuts on the back side of the torsion adjustment bolt; this let's you crank on it without ever having the clamp nut come down on the lower nut. Now loosen the torsion adjustment bolt all the way out until it drops out (if your threads are clean you can lube the length of threads and use a ratchet to get started to make sure no threads are galled and then use an impact to spin it out as there are a LOT of threads to crank through with a ratchet). Once the bolt is out you can tap on the anchor towards the rear of the truck to drop the anchor off the back of the torsion bar. You can then shift the anchors torque arm down away from the vehicle 2 or 3 splines. This will leave the anchor much more room to tension the torsion bars. Use your sharpie marks as reference. Then just slide the adjuster bolt back into the anchor and put the two nuts back on the top and spin it back to tension. You will notice now you have much more adjustment before the anchor bottoms out into the crossmember. I usually do both sides when I do it just so I know down the road I won't have the same issue again. I eyeball and make sure both anchors are pointing at close to a 45 degree angle between the crossmember and the torque arm before I replace the adjustment bolt. As long as no threads are seized or galled the whole job only takes about an hour. Although getting each side back to exactly the same height can take a bit more trial and error as you have to load the suspension with movement/braking to settle the torsion bars after you lift the truck off the ground. I usually jack up the front, make my torsion bar adjustment that I think is adequate, then drop the front end. Fire up the truck and drive forward while hitting the braked a few good times to load the front end. Then check height measurements from a solid reference point on the truck. Then keep repeating this until 1. I have the height I want and 2. The height is the same on both sides. Once that is all done then you can set the camber with adjustment shims/washers behind the upper control arm and then take it for a toe alignment at the shop. Your pathy will never have rode better!
  5. Actually excessive caster is what keeps the vehicle stable and planted at higher speed. Not enough caster will result in twitchy steering and the steering will not return to center. Or in proper terms more "positive caster" will increase steering wheel return and stability at speeds at the expense of increased steering effort and with no effect on tire wear. Too little positive caster will cause the symptoms you described. Just thought I would clear that one up I run 8.5 degrees of caster in my 240sx for high speed stability and a quick wheel return when tossing the corners And about the original post B is spot on about the toe assessment. Your front right wheel was heavily out of spec. An alignment was recommended with good reason. Will help save your tires and your fuel!
  6. I'm sure it's nothing like the out east there! We only get snow a few times a year so they definitely exist. Just a matter of the right price
  7. Lol they do exist, we found my perfect one and my ladies perfect one so far. If I see any other gems I'll let u know tho! I'm always scanning Craigslist and the like
  8. Yeah but it's worth it. My new pathy is 100% rust free frame that still has 99% of its original factory powder coat. Pretty much impossible to find on the west coast here...
  9. Just re keyed every lock on my new pathfinder to match the ignition key. Drivers side, pass side, rear hatch AND glove box locks all match the ignition now. It took me a bit to figure out how to disassemble the glove box lock...there's a tiny pin that's melted into the plastic that has to be removed before the cylinder will slide out! Now I know for next time...
  10. You can get an ngk o2 sensor on ebay for about 60$. 250 is way over priced! If you have been having an indication of o2 sensor then I would start there...I've had bad o2 sensors that never threw any codes personally. Keep in mind they really are old technology ecus, sometimes we as owners have to be smarter than the computer running things
  11. Just use good brake pads and you will be fine. Airbags in the rear coils I've been told help a lot when you are a little on the portly side (vehicle wise, lol), I will be installing some of those soon for when I load up to go camping.
  12. Update: brain fart. Mounting tps backwards was pointless. Works fine forwards. Lol. I'll post some pics of my creation
  13. Pulled apart my vg30 throttle body and gutted it for parts. Machined down the vg33 throttle body to accept the vg30 tps sensor. Mounted the vg30 tps backwards to match the throw of the vg30 throttle actuation. Machined the slot of the vg30 throttle shaft slot wider to fit the vg33 throttle plate. I now have a functioning vg33 throttle body with vg30 peripherals. Now just need to figure out the under plenum lines to make this tb work.... almost there! The vg33 throttle plate is so much bigger than the vg30 one, but the inlet outer diameter is the same so the accordion pipe will slip right on. Just a few more things to figure out and I will be running a full vg33 engine including throttle body and intake manifold in my 93!
  14. Dude i need to see that thing with wheels on flexing!!! That thing must articulate to a ridiculous level!
  15. My old one is the burgundy red colour..but my new one is .... BLACK! Always wanted a black 4 door w d21.. finally got it and it even has an immaculate frame to boot.
  16. Oh right on perfect, yeah a transistor driven to saturation will do just as well for a low current draw like that. Megasquirt sounds cool I want one for the pathfinder. Lol
  17. You can actually remove and deactivate the whole alarm entirely quite easily. The control unit is under the drivers seat. Pull out the seat and unplug the units two electrical connectors. You will see two wires going into the harness that are much thicker then the rest. These are the starter disable wires. Cut both of the wires off the harness and join them to each other with a good solid connector or solder and then tape it up well. Remove the alarm control unit. There you go. Now it's just like your truck never came with it and the wiring is all there ready to go if you ever want to have an aftermarket one installed.
  18. You can just run an interposing relay to power the iacv if the megasquirt won't power it. Just run the iacv signs wire to the relay coil and run run battery power to the relay contacts. i can't even count how many times I've snapped off pathfinder door handles... I'm at 5 or 6 times now honestly. Broke down and bought metal handle ones, even snapped one of those last winter lol. Note to self....lubricate door seals in the winter.... lol
  19. More pics!!! Sick build dude. Wasn't expecting to see all that underneath. Show is the front SAS build! How did you mate the 4l60e to the TX 10?
  20. Very cool! Good job getting back at it man! Are you planning to run maf sensor or map/iat? The fsm has really good wiring diagrams for the wd21 ecu so it shouldn't be too bad to retrofit, if u need any help deciphering any diagrams then let me know.
  21. 4wd still? What Trans and transfer case? Still ifs?
