Nefarious
19
Custom Tuning a Pathfinder ECU, the Project begins.
Nefarious replied to Nefarious's topic in 90-95 WD21 Pathfinders
Well just wanted to give a little update.... it works!!!! So freaking stoked right now, a year or so of part time planning, research, learning, acquiring parts and patience has finally paid off. So far the truck is running on a custom programmed flash eprom with the stock 1995 pathfinder tune. Next step will be to implement some fuel and timing changes and swap to the n60 maf! ??? Today is a good day! -
Productive day today. Swapped over parts from the old 93 into the new 92 again. Ngk ignition wires, non broken accordion intake pipe, replaced all the broken and cracked vacuum lines with new blue silicon lines. Also finished putting the doors back together after adding the defrosting side mirrors. I also finally tested the custom chipped ecu in my girlfriends truck and it worked first time!! Got to say I'm pretty stoked about that one. Been working at this one for a while now and it's nice to say it's working flawlessly. Next step will be to actually implement some changes in the tune. So far it's running on a programmed eprom chip but with just the factory 95 pathfinder tune. ??
Centerforce Dual Friction Clutch Install
Nefarious replied to msavides's topic in 90-95 WD21 Pathfinders
I think I'm going to have to get this clutch when I convert to manual Trans. .. -
I know right? Well see the problem is you live in the wrong end of the country! You gotta move over here to the land of beautiful ocean beaches, forests, lakes, weather and lots and lots of trails! ? haha no problem! I'm actually running Vista only on my purposely old desktop. Its an old pentium 4 box tbat i use to play old windows games (like system shock 2 that wont run on newer computers) and run my eprom programmer. The eprom programmer that I use was last updated in 200, lol. Keep in mind these chips are VERY old technology by today's standards so getting the old programmers to work with new computers can be a pain. It also has to have a dedicated parallel port with true LPT1 communication in order to function and none of my new computers even have parallel port! Hahaha. I actually run windows 7 on my laptop and 8.1 on my transformer t100 and I agree 7 is where it's at!! I like it more than prior and later versions. -
That would work just fine as long as you can track down a VQ table for one. I just plan to use the n60 maf as it has ample flow space and a much better more modern maf design with the suspended center element. They are also dirt cheap where I live! -
That would be the way to go. I didn't use Mr 510 adapter myself for my truck but I did for my girlfriends pathy and it made the swap go a lot quicker. vg33e swap , intake/headers/exhaust and vg30e cams was the best thing I ever did to this truck and really woke it up but I know there's more to be had...especially after my thezstore re ground camshafts show up! To run the n60 maf, you must run a Socketted ecu (28 pin, DIP socket ) with a custom programmed eprom with the VQ table for the maf of choice programmed into it. The maf values just tell the ecu how much air is entering the engine and can be run with an otherwise stock tune to keep your emissions the same for smog checks if you have that where you live. Where I live has zero smog laws at all, so I plan to add more aggressive fuel and timing tables as well as the n60 maf myself. ? -
oh that's a definite career change but sounds interesting for sure! And adamzan; yes those are snes controllers just finished fixing the power supply to get the old beast running again. I am also a major fan of retro video games. Snes, n64, early Playstation, so good.....lol. -
Oh right on man. Technologist?? What industry do you work in? I'm a technologist myself specializing in industrial automation, but currently I am working in building automation systems. -
Well my new flash eproms finally arrived from overseas. These will replace the factory uv erasable eproms and are much easier to work with once properly setup. Getting them setup on the other hand took some real patience but after a good 8 hours of tweaking hardware and software settings I finally got the new chips functioning properly! So far I have burned the factory 1995 pathfinder tune on to the chip and then verified the chip carries the tune successfully. Next step is testing out the socketted ecu in the truck with the factory tune. Once everything proves to function properly, I will then begin applying the changes i have made to enhance the tune and add support for the N60 maf. Making some real progress now.. -
Finally got my flash EPROMs in the mail. Spent the last couple evenings getting them configured in the EPROM programmer and after much frustration I finally got it cracked! Successfully programmed my first ECU chips today! Was a good day.
The voltage sensing auto disconnect is a nice touch and peace of mind if you plan to travel with it!
Sweet man!! That fridge looks rad...
Will a frame from a different year work?
Nefarious replied to Nename's topic in 90-95 WD21 Pathfinders
I would have to agree on this one as well. Hense why i said IF you want to keep the truck, 90-92 are better. But unless u find a steal of a deal on the frame and get a reduction in labour costs , you may as well just try and locate a new donor vehicle. Even one with engine or transmission problems as you have a good power plant now and an engine or transmission swap would be a lot cheaper since you already have everything you would need. -
Perfect thanks for the measurement info there! That's my take on it anyway, is that once a vg33 is swapped in and is using more aggressive cams, headers/exhaust, and even a vg33e intake manifold and throttle body, that small maf is not beneficial anymore since the low end torque has already been increased to a point above factory as it is. The rest of the gains to really wake the motor up on my opinion will be ditching the rest of the intake restriction to allow the mid range to really open up and make the most of the rest of the modifications. This should optimize in town and highway driving (120 km per hour speed limits here) and I am not worried about sacrificing a small amount of low rpm torque since after the work I have done I will still have much more than stock levels anyway throughout the rpm range. I'm going to do my best to log virtual dyno graphs before and after the changes to document effects on the power band
I would swap the frame personally of you plan to keep the vehicle. Any frame 90-95 will works but 90-92 are the best as they have powder coated frames instead of painted frames and hold up much better over time (generally). It's amazing how the powder coat keeps the frames in good condition. My 93 has frame rot, my 92 is almost completely immaculate underneath -
do you by any chance know what brand the mesh was so I could look it up? My girlfriends truck is missing the vent trims all around and this looks like a great alternative
Hey that looks really good. I like what you did with the vents there. How did you make the edges look so clean? Looks like you removed the vents and the surround trim.
It's in the EL section if i remember correctly. Harness layout section should show relay positions. So you read 12v at the starter? Or you get 0v at the starter?
I also plan to convert my wd21 to run the r 50 intake manifold/throttle body as well as some re ground cams from thezstore so the decrease in intake resistance will be even more important to make maximum efficiency
Well my theory is it was made with such a restriction to act as a venturi tube to increase air velocity at low engine speed and thus increasing low rpm torque slightly. This may help very low rpm torque to make the truck a bit more grunty off idle but sacrificing some higher end efficiency. I know the heads and cam shafts are the same between the m30, maxima, and pathfinder. The only difference is in the intake system (manifold and intake tube/maf). I have studied the fuel and timing maps of all of the above 3 vehicles and they are nearly identical to each other aside from some more fuel added under higher tp values on the m30 tune. I'm convinced nissan originally sacrificed some hp in the mid range to gain a bit of low grunt by tuning the intake in this way. Still my theory! I just love re engineering things and tweaking them to get the most I can. Please keep posted on the r 50 maf size. I know physically it looks just like the n60 maf dimension wise and it is 90 mm
They definitely did go to a 90 mm maf on the 3.3. My thoughts is that the stock maf was never large enough anyways. It may help with velocity a little bit at very low rpm but my truck spends most of its time between 2000-4000 rpm daily driving and that is not where a tiny maf like that would be flowing efficiently. Even the vg30e in the maxima and the m30 both use a 90 mm maf as well and that's on a 3.0. Those engines made 160 hp factory instead of 153 hp. I have copies of the tunes for all of the above mentioned vehicles and other than a slight bit more fuel on the m30 they are very similar in fuel maps and the timing are almost identical so it's doubtful that extra power was made in tune alone as they are so close. if peak torque on these engines is made between 2800-3800 rpm (depending on camshafts profile) and that is also where I spend most of my time while daily driving then that is also where I plan to tune for optimum flow. I don't need a few more off idle torque pounds but I do need more mid range torque and therefore power. this is all speculation based on my experience but I will be running several virtual dyno runs before and after my changes to document the improvements. Virtual dyno is known to be between 1-3% as accurate as a true chassis dyno, so with multiple runs to average before and after I'll be happy with the accuracy for confirmation of gains.
If you have 12v at the starter when the vehicle cranks then it's the solenoid. If you don't have 12v at the starter when the vehicle cranks it's further up the line. Easiest way to check
The top one is an old school check connector (analog signals) , not sure of the second one there ?
Okay well I like to work backwards personally. Start at the end and work back to where the issue is. Testing relays is pretty easy. You will have 4-6 wires going to each relay. Generally, a small coil and ground wire that engages the contacts and 2-4 thicker switched power wires. What you want to do is set the volts to 20 on your meter, place the negative lead on any ground point on the vehicle or on the negative battery post. Then you use the positive probe to test where there's voltage. First identify the feed line to the relay. This wire will be a thicker wire and will have 12 v high all the time, even when the vehicle is off. Identify which thicker wires have 12v and which ones don't have 12v. The thicker wire (s) that have no voltage when the vehicle is off are your switched side contacts that feed the starter solenoid. What you want to do is place the test lead on that thicker wire that natively has no voltage on it and then have someone turn the key to on. If you see 12v appear then you know the contacts closed and the relay works fine. You then move up the line to the next component in the circuit. This is usually the clutch interlock relay if you have manual or the inhibitor relay if you are automatic.
Lol!! Well played...
