WarehouseRat
Everything posted by WarehouseRat
  1. the jim wolfe is no better then a open air cone filter for a lot less money, a air intake would mean all the way from the t/b to filter being replace with better performing materials, ie no "donkey dick" tube better flowing airfilters heat shield added, not an adapter and filter with a magic venturi and a oiled filter that screws with the maf, call jim wolfe and ask for a dyno print-out of performance gain/s with this system on a pathy , POP charger lol "piece of poop thats over charged" its name discribes it to a tee
  2. ^ haha my other dog not mine but gf's dog is named sopie she almost 14yrs old.
  3. any chance you can come up with templates
  4. diy with parts from orielly auto parts cold air intake
  5. just be sure you dont burn of the new paint lol really easy to do you could even wet sand with 2000 grit and buff it back make sure you use a sanding sponge if you wet sand it other wise you will put groves in the paint from your fingers pressing on the sand paper
  6. it only show images to members just like npora
  7. ^ more bad brake advice, bleeding will not help the m/c if its failing, perform the bleed by test on the m/c like i posted if there is no bubbles, then move on to bleeding the system rr-lr-rf-lf in that order,wanna know how much water is in the fluid dip a test strip in if it good then leave it
  8. here is my boy tuckeryes he thinks he only weighs 5lbs and loves being a lap dog lol at least he thinks so...... last winter in capital forest
  9. actually saw one last friday it was a suburban and it looked like ass but thats just my opinion, too each there own i guess, for what it cost i would paint my rig instead
  10. its stock specs kinda speak for them self, op needs to decide what size tire he is going to run then crunch the numbers to figure out what gears he needs if its 33's leave it be, if its 35's well then you need to do the math, this thread should be moved out of the custom fab section and put in to the general tech section
  11. washing doesnt stop rust, sandpaper and new paint will though it to like the look of the tag/kma bumper i found a old warn winch bumper on my way up to mt st helens yesterday, the guy would sell it damn truck looked like it hadnt moved in 10 years
  12. minus the ecu a turbo kit would be easy to built for less them a 1k, just need to know what, were, who, how and pull up craiglist and look for a good used turbo, ebay piping kit a bar and plate IC, bov, wg, fab time, do not let people discourage you and what you wanna do you can turbo either engine, vg30e block has a high nickle content which means it strong as hell, the vg33 only makes better power due to intake and head being designed differently, i say throw some forged rods get the heads ported , get the intake extrude honed, high volume oil pump, head studs, knife edge the crankshaft, deburr the whole block of all casing flaws, gt35 turbo, tune the @!*% out of it too 20lbs of boost
  13. look 100% better wait a few months for the paint to get really hard and buff it out and i bet you couldnt see it at all
  14. i second the d-rings, i would box the ends in under the the fender cuts, i really like the design, should have made template patterns of all the pieces and sell them to the other members for a easy buck lol
  15. brake fluid takes awhile to cool down, a few pedal application wont make it colder only hotter yet, its not air in the brake lines either lol it dosnt just appear in a sealed system if there is air in the lines anywere there is a seal out ie wheel cyclinder or caliper, or at any line junction, tall tell, sign a puddle of brake fluid or a wettness around any brake equipment, easiest test have some one pump the pedal with the engine off and look in the fluid res for tiny air bubbles if there is any the m/c is goin out giving bad brake advice can lead to a person dying
  16. not really its a wow factor mostly, "look at me i got projectors" i have retrofitted projectors from a lexus in to honda accord housings and the light pattern was more defined and brighter is all i noticed
  17. you can get the euro housings and a good quality hid conversion kit and your set just besure to adjust on a dark road to check the light pattern
  18. lol koyo makes the oem radiators so i see no improvement, unless its a full aluminum unit
  19. i have euro h4 conversion housings you can find them herehousings, i notice nothing as far as a power draw when i have the high beams on
  20. best @!*% in the world lol i have tried mt dew, coke, pepsi,and a host of other juices with the vanilla ice cream, they all hit the spot
