sewebster
Everything posted by sewebster
  1. Just hit the reply button on the post you want to quote, then it is automatic. You can basically do it manually too, like below, but replace the { curly brackets with [ square brackets: {quote} text you want to quote {/quote}
  2. As far as I can see, this conflicts with the information on our stickied page: http://www.nissanpathfinders.net/forum/index.php?showtopic=25662 There it basically says that 90+ is 28 spline... Shasdakota, regarding the CVs, I think the attachments to the diff are not the same for the different spline counts, so I'd be careful...
  3. I mean force, not torque. The torque is determined by the engine and is applied to the wheels via the transmission, driveshaft, diff, and axles, and is independent of tire size. The engine torque is different than the wheel torque by a factor of the trans and diff gear ratio. Big tires are good because they get you high off the ground etc etc. Precise is right, if you want to run big tires, re-gearing is a good idea. Of course you can get the same force with bigger tires by just increasing engine torque, usually by running at higher RPM. But this means you are going faster, which might not be what you want.
  4. For camber/caster adjustment? Not sure, since the truck was lifted when I got it. Alignment was a PITA because shops couldn't figure it out, so I ended up messing with it myself until it drove straight. I should probably have it measured again.
  5. Cool. I guess the terranos have different spline counts than the pathfinders? Because I'm pretty sure a 91 pathfinder is 28 spline (stock anyway).
  6. Count the splines on your axles and the splines in the hubs... if they do not match, it won't work. I think you just need to get different hubs. They are available in all the different spline counts. http://www.nissanpathfinders.net/forum/index.php?showtopic=25662
  7. Weld the diffs, 12" wheel spacers, slap the 40s on and you're good to go! (about the length of your driveway anyway)
  8. The engine applies a torque to the wheel. The force that is then applied from the tire to the ground to propel you forward is that torque divided by the radius of the tire. Bigger tire, less force.
  9. I haven't done it, but I think you will want/need to replace the entire third member. Remove driveshaft, slide axles out, remove and replace third member. Make sure you get the same gear ratio as your front diff...
  10. I have a 1" lift and the stock bolts and it seems to work. I am basically at the limits specified in the FSM for shim thickness, which I assume means I am ok on thread engagement.
  11. You sure your injectors aren't leaking or your fuel pressure isn't too high?
  12. Mine is 31", so probably the same as your 31.5" and I just measured from a different place. I'll have to be careful with parkades with my ski rack on... must be getting pretty close. Thanks for the measurements!
  13. Thanks. I'll measure mine tonight. I only have a 1" lift and am running 31s so I was just a little surprised. Maybe you just couldn't fit a 3+3+33 truck into a parkade around here.
  14. My truck had no antenna so I got one from the pick-a-part (from another WD21). I just unscrewed the antenna itself and screwed it into my mount. So I guess this means it's not a power antenna or anything. Anyway, I just went into a parkade the other day and I noticed that my antenna was hitting on signs hanging from the roof. Yikes, not really a big deal, but is it supposed to be that long? Seems kinda odd. I suppose I should measure, but I'd say it's about a meter (3 feet) long. Any idea on whether the WD21 is just a long one, or whether I somehow got an aftermarket one from the junkyard? I guess I could just cut the end off....
  15. Well, I did have to pay around $100, so I guess I got an expensive piece of paper at least!
  16. http://www.nissanpathfinders.net/forum/index.php?showtopic=25662
  17. What do you mean it isn't "rolling up"? You can't push the UCA up far enough to get the ball joint in place? If so... maybe push harder or use more lube??? The half shaft can't come out unless you remove the split ring on the end under the hub, but perhaps this is necessary to mess with the UCA. Anyway, if it came out, put it back in... no big deal. If the boot is cracked, that's because it is worn out, not because the half shaft moved a bit. Replacing the boot ASAP is a good idea if you want to save the shaft. Of course it doesn't even do anything if you aren't in 4wd and it will even work in 4wd until it wears out, so if you are in a rush you could leave it (though of course this would be a convenient time to deal with it since you have it all apart already...
  18. That sucks. When I had mine done I got a printout with all kinds of data about each injector and how it performed. I chose to replace one as a result.
  19. The LSD oil sticker is the most durable part on the truck! Probably the best way to find one...
  20. sewebster
    3000rpm
    You can tap into the wires at the MAF or at the ECU with a multimeter. The correct voltages are in the EF/EC section of the FSM.
  21. Did they not flow test them etc to see if they work properly?
  22. Maybe you can buy another R50 that needs to go in for the recall for $2000 and get another $4200 for it? If you do this for all 195000 pathfinders being recalled, you could earn over $200 million.
  23. Could just be your fuel pressure regulator is busted... it's only like a $50 part, so I would test the pressure with a gauge (procedure in the FSM for the specs with the regulator vacuum plugged in and not) and replace it if it's broken.
