6
Everything posted by sewebster
Ahh. Can't you just swap out the clutch packs then? Maybe too annoying.
Presumably there's some trade off, slipping clutches/bands presumably reduces shock loading somewhere else? But maybe not too much since you've got the "give" in the torque converter too. How many autos actually end up dead because the clutches are worn out though? Seems to me they always die in some more heinous way.
Your diff is soooooo shiny!
Lots of things are easy in theory and occasionally more complicated in reality On another car I once thought I was going to need to use a winch to remove the spark plug wires. On this truck it's the #6 plug that is a bit of a pain, but once you've figured out "the system" it goes a heck of a lot easier. Good job getting the plugs changed yourself!
Lots of people here recommend the regular plugs too... shrug
Hmm. Interesting that you have no code but it seems to be in failsafe mode. I would try wiggling/adjusting the MAF wiring to see if that does anything I guess. Maybe something happened when you cleaned it somehow...
VG30E Missing/Running Very Rich, Sensor Problem? ECM Problem?
sewebster replied to robertjame's topic in The Garage
The engine runs better with the fuel pump unplugged? Presumably until it runs out of gas... maybe your fuel pressure regulator is broken... could try checking the fuel pressure with a gauge. -
so you still can't go past 3k rpm?
If it's knocking then using higher octane gas might actually help.
Try to feel behind the engine. The knock sensor wire is the only thing that is coming out from below the lower intake, in the valley between the two cylinder heads.
Hard to say... I get lots of BETTER parts online for cheaper than an inferior part at a local shop... depends on the situation. Some parts vary more in terms of quality than others too... no real personal experience with wires. The ones I got from rock auto were about $30 I think? They have a wide variety from $17 to $70. I probably wouldn't get the $17 though, who knows...
Always good to get it solved!
The voltage at pin 18 of the ECM should be between 1 and 3 volts with the engine running (depends on temp). Page EF&EC-129 of the 94 FSM. This is with it connected and a small probe wire carefully inserted. -
Those shims are the "normal" ones... geometrically it is possible for them to fall out. If you install them properly and don't off-road much they probably won't fall out... but obviously some people have had problems. So using washers is "better" just less convenient. Mcmaster-carr doesn't have M14x1.5 10.9 so I don't have any ideas there...
Thoughts: make sure you are messing with the right temp sensor, not the one for the dashboard gauge. If the ECU throws the code then either there is a problem with the sensor, with the wiring or the ECU. You can test the sensor and the wiring... if those check out then you have to try a known good ecu unfortunately... -
It sounds to me like you have more than one problem... I would be curious if you still get the MAF code when you have the wiring straight to the ECU (after resetting codes). But maybe it doesn't even run well enough for you to check? If it's just idling at 2000 rpm that is probably ok... If fixing the wiring DOES get rid of the MAF code then I'd move on to solving the next one. If you don't want the ecu to be able to increase the idle speed unplug the AAC connector. Then your idle will just be based on the mechanical stuff... idle adjust screw, vacuum leaks etc....
This should be a how to or sticky or something...
Some shops use impact wrenches irresponsibly. Got my tires mounted at a fountain tire and I had to get my impact out just to take the wheels off. Thank goodness I didn't notice in the middle of nowhere with a flat I couldn't change...
So 94+ came with rounded tooth sprockets?
I think your problem lies in the wiring.... it doesn't matter if the truck seems worse when you think you fixed it... if you are measuring different signals at the MAF and ECU when they should be the same then you need to fix that. Once you've done so you can figure out why your truck idles too high with it fixed or whatever. I don't know if that's actually what's causing your problem, but it's really hard to diagnose stuff like this (especially over the internet) without being methodical about it...
It is possible to reassemble the crankshaft pulley such that the timing marks are in the wrong place unfortunately. It sounds like you have this problem. Of course this only makes it more hard to time your vehicle etc. The good thing is your truck started again after it died. This means your timing belt didn't just snap... but you should really replace it if you don't know if it's ever been done and you have 186k miles! The change interval is 60k miles. It's only 100k miles if you have the rounded tooth crank and cam sprockets that came with the VG33. When you change the belt you can fix the crank pulley to make timing it with a light easy. Alternatively you can find TDC another way and make new marks on your pulley...
Didn't you already determine that your MAF wiring was busted?
either a wiring problem before the ignition coil or a power transistor problem. Unless you also have a crank angle sensor code (11) in which case it could be caused by that. EF+EC page 42 in the 91 FSM.
If your engine computer thinks your engine is knocking because of the knock sensor, then yes, the engine will perform poorly. The knock sensor is held on by a single bolt, and has a single electrical connector, BUT it is under the lower intake manifold, so either you have to do a lot of disassembly to get to it, do a lot of wiggling from the rear, or bypass/relocate it by disconnecting upstream. I suppose it's also possible that the sensor is working properly and is retarding engine performance to prevent knock... but probably you just have a bad sensor.
