skulptr
Everything posted by skulptr
  1. i put 33x12.5 on mine with no lift and 3.75 bs, so with 31s you should be fine stock.
  2. yeah he only put spacers in the front because he used 33s. before the 33s he was fine
  3. you can pretty much use what ever rims you want with it. 01silva used stock rims with his suspension lift and much larger tires than that.
  4. found that 2 bolts in my manual hubs were missing, 2 fell out but were rattling around in the center cap, and the other 2 were still threaded in but not very much. got the 2 new bolts ad 4 new lock washers for 3 bucks and got er all fixed up. and tightened the power steering belt.
  5. now all you need is manual hubs and paint the center of the rear wheel hubs black to match
  6. Tahuya run! Feb 19(saturday)! Meet at Belfair Safeway at 9am! Try to make our way to the trailhead about 9:15. Come geared for wet weather and wet trails! Attending: 5523pathfinder +1 Kyle94 (maybe plus one... dk yet.) Maybe: Skulptr +2 (pending my return status!)
  7. and how, might i ask, did you find that!
  8. bumpers easy too make, but you need to chose your mounts carefully. the stock bumper mount is not nearly strong enough to hold the bumpers weight, but i put 2 blocks between it and the hitch for added support, since i dont have the ability right now to built a hitch into the bumper itself.
  9. yeah just take the cross bars off. all they are is bolts with big knobs on them. but the rails are bolted straight into the sheet metal, with torx bolts. not worth taking off. i took my cross bars off, only took a few minutes.
  10. well we're going after all, our tax return as it sits right now, its 11 bucks short of 5k!!!
  11. yes, when the sensor goes bad, the fuel mixture gets messed up. that will probably fix some issues. when you replace it, wipe the CEL codes FIRST, then leave the key off, and replace the sensor.
  12. can you get some video of that baby doin some real work? lol
  13. yeah it cant decide how it wants to be busted. and its interesting that it busted when no one was even in the rig to bust it, and it hadnt been used for several days prior
  14. well it changed again. now i have no wiper movement on the wash cycle. i hold it in, the washer fluid pump runs and does its thing all over the back window, but the wiper doesnt move. but it moves in its speeds in the 2 different speed options.
  15. yer search function be your best friend! (much better than pezzy breathin fire down your neck )
  16. hell i did evans on nothing more than 31 bfg at's and some skill (not to mention all my extra weight in steel). tahuya should be a cinch
  17. the hotter one, no matter what oem is, is always your best option.
  18. what i did with mine originally, was took the front roof rack rail, unscrewed it, flipped it around (so it goes forward a few more inches), then slid it all the way forward. it was about even with the front of my sunroof. i eventually changed my setup to accomodate more lights, but the rack itself is more than capable of holding them. plus if you peel back the rubber liner inside the rail, theres a nice channel to tuck the wires into.
  19. well i put the fuse back in today, so far so good, its wierd. stupid gremlins.
  20. anyone know which relay runs it? or if there even is one?
  21. the 3.5 is a combined system where the 3.3 is 2 separate ones.
  22. well you have the 3.5l, the only part number i'm finding for you is MPE TS5583SB at napa. course any parts store carries it, lookin like its about $27 bucks.
