87pathy
Everything posted by 87pathy
  1. http://www.ringpinion.com/downloads/yukoninstman.pdf This is the best intallation procedure you can find. It shows step by step as well as how to read your print from the marking compound.
  2. you can't check the back lash with marking compound. The marking compound only tells you if your pinion depth is right. to get the proper backlash you need a depth mike on a magnetic base. you must have got lucky cause the way you checked the back lash is wrong sorry if i sound a little harsh.. but...
  3. ok, this is a really old post, but i have been out of the bbs for quite a while, and to defend myself, i was on a golf corse not too long ago outside of new castle new south wales and there werwe 8 roos on the 7th hole.. i have seen lots of them in Australia. i lived in sydney new castle area for almost a year.. and maybe were your at you don't see them that often but I know for a fact that they are plentiful
  4. 87pathy
    lift kits
    i'm not over qualified.. i just got you fooled into thinking so with all the info thrown at him, he should be able to figure it out.
  5. i broke my timing belt once... bent 6 of 12 valves. I put them on grinding machine to see if they were bent. 5 of them you could see by eye but the 6th one you couldn't see until i spun it on a valve grinding machine. 3 intake 3 exaust. doing all the work myself cost 400 bucks. but in the process i reground all my valve seats and match ground the valves.. ran like a new car after.. still does at 240k.. wel it did when i parked it 2 years ago for the sas that still isn't finished... but i should be done around xmas..
  6. 87pathy
    lift kits
    Wild horse 4x4 bronco 3.5" lift coils, cut the top retainer off and you get 3" of lift, get the 5.5" lift coils and you get about 5" of lift.. see mine?
  7. Hell, if you are going to go throught that much trouble to make a nissan tranny fit, why don't you just get a pre 86 divorced tranfer case?
  8. Those bumpers are so common in oz. But there is a reason for it, Kangaroos!!! they are everywhere in the bush, you can even see small utes with those kind of bumpers.
  9. I have one on the other side as well, they body panels are fiberglassed inside to seal. I have about 600 watts going to both. these are Resonant Engineering 8" subs, they can handle about 600 each.
  10. Mr. Pickles, Do you use the AM PM on Meeker in Kent, nex to the golf corse? Thats the one that gave me bad gas. Twice, my truck ran like crap after filling there.
  11. Mine has done that on 2 different occasions. Both of them When i got fuel from an AM PM in Kent Washington. Ran good fuel in it and went away.
  12. 87pathy
    SAS Pathy
    I never owned an EB. I owned a 66 F100 4x4 but never an EB or we can confuse others and call it by its true name. =U100. I did my SAS with Full size stuff. He is 59"wms-wms i'm 65". I didn't have to do a sub frame as he did since my radius arms were farther outboard since i used full size componenets.
  13. Yep,, got plans, even got the spare doors. just haven't done it. I guess getting the thing back on the road takes priority. I'm going to cut them down just past the door handle, and then come up just behind hte mirror. this way i can still latch the door. I'm also going to keep the upper part of the door just for looks.
  14. OOPs Didn't pay attensin that i was in the 90 -95 secition,, if the 87 will work on the newer ones i have one to sell
  15. Track bar, pan hard bar, all the same.. Sway bar.. no no no thats something different. Hey if you want a pan hard bar let me know, i have one in perfect condition i would sell for 30 bucks plus shipping. where are you at? email me if you are interested
  16. Where do you find that stuff? I need some of it.
  17. you should have a look at Mookies ride...
  18. Ok.. so anybody who has done an sas should shim in then.. its not that hard.. if you have the money. If you have all the parts, you could do a leaf sprung sas in a weekend.. no doubt! If your going to put a similar motor in, do the sas firts. If your going to put in a small block do the motor swap first. this is so you don't have to readjust yours ride hight a second time int he front. gandios claims? there are a lot of us who have done Solid axle swaps.. just ask,, what exactly are you trying to accomplish?
  19. Definately go ford! or even post 85 (i think) wagoneer. chunks are the same and any thing D44 will be cheap.. waggies will have a 6 lug pattern, D44 front and possible D44 rear or AMC 20. Do you want to be wider than original? Do you want to be the same width? Do you want leaf springs or coils? Do you want to use the original H233B? (this is not as difficult as you may think) Get a waggy front end, go leaf springs and you'll be done in a month or 2. If you go the route i did you'll need a couple of years...lol What size tires do you want to run? these will determin what donor you want.
  20. a Few things to take into consierdatin. you don't want a 77-79 D44 from a bronco. they do not have stong axle tubes... if you really check into it you'll see. the radius arm mounts on the axle are part of the axle not welding onto the outside. Be care ful with the early 70's F150's they had a big mix of rear ends and not even the salvage yards know that much of what is offered. could have a Ford 9" could have a Ford 9.5 or 9.375 (same just different name) this is a big problem cuase there are no gears for them. and you have to change the entire 3rd member to get 9" gears Also could have a D44-3 or D60 (odd with 5 lugs but did exist)(D44-3 is Dana 44 Power lock!) if your going to go with coil springs, look for a used 76 bronco axle.... good axle tubes, disk brakes.
  21. Yoshi got lucky and found a bronco set up. Those are really hard to find these days. He did one thing i don't understand. he went through all the trouble to make extended radius arms that use all the stock parts. The Radius arm design is inherant to binding. this is ALL ford radius arm designs. He went through all the trouble to build new radius arms and didn't put a wrist in them or at least change the frame mounting point to a heim joint. that just doesn't make sence. He would inclease his movment by either points above. The only reason i used the radius arms is cost and time. I do have plans in the future to change this to my own 3 link design. i even fabed my frame points to easily adapt them in the future. If you go with his design, wrist your radius arms or install Heim joints instead of the factory bushings. (My radius arm will be wristed in the near future. like before i'm done) Oh ya and as far as streetable.. there is a fine line of what is and is not legal... Besides the police don't work for the department of motor vehicles. as long as i get fender flares up front and mud flapps in the back they won't bother me too much. Besides, i'm building this for OFF ROAD use. Its gonna drive like crap on the road. Keeping it streetable is of low importance.
  22. Ok.. I broke my timing belt several years ago. Damage = 6 bent valves. 3 intake 3 exhaust. I changes the 6 bent valves. (darn expnsive too exhust were like 20 bucks each and intake were similar) I ground all my valve seats, i match grinded my all my valves, new and old. Changed valve seals.. all necessay gaskets.. ext. I did ALL of the work myself and it cost 400 bucks. Total time was about.. 10-12 hours of work. If the mechanic is charging you 5000, he's totally ripping you off, that means he is charging you at least 300 bucks per hour. But i do know that if you take your rig in to get the timing belt changed they will try to charge you 800. when the timing belt is only 20 bucks. Its not that hard to do it yourself.
  23. definately gussetting, Like i've stated in all of the notes.. I"M NOT FINISHED. i connected everyting first to make sure its working the way i want. it is so now to finsih up. Teh tubes will handle the torque just fine. I used the same material everybody else does in their rock buggies.. spyder trax, poison spider.. etc. I even have access to real engineers who have looked at my work and they say no problem. the link connection on the frame are diffinately not strong enough until i finish up all hte reinforcements.
  24. here is one more so you can see the links.. they are 1.5 x .25 wall DOM, I made the inserts, and everything.
  25. Ok, Rev asked for specs so here they are. Front: spring buckets, located on frame stand offs (this eliminated the necessity to shorten the axles) spring buckets were from a 76 ford F150. Radius arm mounts, Custom. I used 5 deg bushing for the radius arms. Then i had to locate the radius arm mounts at the proper angel to keep my castor angle correct. Springs are 5.5" wildhorse rock crawler series. These are normally for Early bronco. HPD44 axle Rear, Unless you have are very good in math, know somebody who is a geometry wize, who can fabricate anything necessary, and you have the formula to calculate it all.... Don't even try to do a triangulated 4 link. its not easy! (My job is custom fabrication of Heavy and specialty equipment) rear spring are 3.5" wild horse rock crawler series. They are located on 4 in stand offs from the axle. Ford 9" axle I have a 3 inch body lift installed. before i started I was running 30" tires, and had 13.5 inches of frame clearance. I know have nearly 24.5" I also have a custom Hand throttle, so i don't have to do the 2 foot 3 peddle shuffle. Stereo,, you only wish you had it! Over 600 watts, Resonant engineering 8" subs built into custom body pannels. I have added a couple of pics below so you all can see some more detail. I remind you ITS NOT DONE!!!
