adamzan
Moderator
Everything posted by adamzan
  1. Could use some advice, and turns out both my shocks broke off so I just took them off temporarily. This truck is not on the road yet FYI. Frame work is hard. I need all the help I can get. And I can't get rid of this truck. Oh and I cleared off the large amount of snow off, so it seems to sit more level now.
  2. Google brings up this linky Seems like a good idea, might have to obtain some.
  3. I tried synthetic in my 93 SE-V6, and it started leaking from somewhere :confused: , so we switched it over to 20w50 heavy duty oil.
  4. Im pretty sure that the gauge is reading right, mine always read around 1/4 when on the road, and when I was using it off the road, it'd go up to about half way, because there was not as much air circulating through like on the road.
  5. Good to see that things have turned around for you. Welcome back.
  6. But isn't the lever a direct link to the tcase, which means when you push it into 2wd, your arm action moves the gear? Are you actually moving it into the actual 2wd position and still feel the wheels being powered? Maybe its just taking more effort because the hubs are still locked and the diff in the front has to rotate by just the wheel power. And yeah, changing fluids is a good idea.
  7. In mine, if you don't go in the opposite direction 3 meters is it? The light will remain on even if you go to 2wd from 4hi or lo. Also mine used to be very stiff a long time ago but changing the fluid to a synthetic and using it more often helped that.
  8. My 93 when it was on the road, ran on 20w50 in the summer and 15w40 in the winter in ottawa. Never once a problem with the engine and its at 340000kms.
  9. I too did some extracting. Pulled my friends 2006 protoge out of a snow drift at lunch. Had to use moms isuzu rodeo as the pathy ain't drivable at the moment. Too bad to here about jim, its a great thing that he started. I right now also have no cash and the pathy's been off the road for 2 years next september :sniff:
  10. Yeah, I can see the wire going to the shock in the front and back when i had the tires off. I always wondered, are they gas charged, how does it work? Zach, you should've taken it back, as mine have 340,000 Km on them and still work, minus the one that snapped and i still have to fix. Im considering tacking it on with my mig welder temporarily?
  11. This may be slightly off topic but I have 340,000 kms on my 93 with an autotragic. This is the original trans with stock cooler. We've had this pathy since 1999 and never once had a problem with the trans. My dad had all the oils done regularly with whatever they call for, and 20w50 heavy duty oil in the engine. After reading this forum and what they have to say about the auto trans in the pathy's im shocked with mine. And it still runs fine and shifts smooth. Do I have the only good autotragic? No mods on this truck either, bone stock. And I can remember many road trips from ottawa to washington dc and more in the heat of mid summer.
  12. im pretty sure mine has them in the rear too, because my friend started pushing on the bumper and i switched it to sport and he could hardly push anymore, a great invention in my book.
  13. My 93 has one, its in the bottem left corner of the dash, and it comes on if you go from at least 1/4 tank to empty, if you just get lazy and keep filling it with a jerry can, it doesn't light up when low and runs out of gas.
  14. Yeah that'd be good to know, are there aftermarket shocks that'll work with it? Seems like ill have to replace my rear originals because one has snapped off. But the button worked well for me.
  15. Yeah, I find it pretty useless, as you still loose control quite easily.
  16. My dad went from the 93 pathy that got 20 average to his 2000 that gets around 16, I guess its because you need to shift around 3500 in that thing to get any decent acceleration on the highway.
  17. If you don't like it, take the fuse out, thats what I did.
  18. Oh i forgot to mention, that the shock is hanging lower than the one in the pick smashfinder added. Like its about 1 inch past the axle.
  19. Is it even worth fixing if something serious has failed? I thought it could be that the springs are extremly tired as they are the original and I can remember when it was on the road that the tires used rub in the rear when dad hit a bump. OH By the way, I just realized that it is parked on uneven ground in that picture. It sat level when i moved it into the garage to clean the interior, it just is a bit of a "slinky".
  20. Shouldn't be driving at 150kmh then lol Yeah it is likely to be nasty along with the frame rot. WHY DO THINGS KEEP BREAKING, and the cash keeps draining for other things. In the pic i have circled what seems to be broken. Remember this is a completly stock truck with frame rot, severe might i add.
  21. I found a pic of what the back looks like, if it helps any. If you look at the right of the rear bumper, you can see where that same idiot hit it with his 4 wheeler.
  22. K i can't get a pic of it. But does anyone have a pic of their suspension so i can point out what im talking about? "theres no way your rear shocks are good if you still have one connected and it bounces "too much". ive driven for weeks one a single shock and the difference was minimal" Maybe they're still OK but they can't go it alone?
  23. Mine must be in that 1% also, as the elec suspension worked very well, untill this happend. And if he ruptured a brake line, don't count on him being friends with me much longer. You just don't screw with another mans vehicle, massive frame rot or not. I'll get another look at it some time. But I REALLY don't like moving it around with a damaged frame (see my other post), barely any brakes, and a disconnected shock as it bounces too much. Oh and about the snow, its been sitting for a while.
