221
Everything posted by adamzan
Some people have all the luck.
Since you have a 5 speed, can you not just push start it if you need to?, just kidding. Had the same problem, but after tightening all connections, especially the ones near and on the battery.
that same exact thing happened to my 93 and it just stopped. I checked oil, fine, we just filled up with a tank of hi test gas and a few bottles of STP. never had a problem since.
i did when i wheeled it a bit, we must have good luck pavelow rennwerkes, i'd buy that pathy if it had little rust and drives well.
93 with 340000kms with no cooler. I think if you don't drive the piss out of it you don't need an aftermarket one.
Get some new coils, it'd be better in the long run, you don't want to look like a ford explorer for too long.
I remember helping dad change the front and rear bumpers. But they were so rusted that we had to break them off first.
That orange doesn't look that bad actually.
I saw the car domain page on that truck, he did fix the frame, according to the car domain page. There are pics. Can't find the link though.
I found this thread which was extremely helpful in giving me ideas but I have yet another question. My coil spring perch or whatever seems to look different compared to the ones in the other threads. How would I go about forming a piece of plate to go around my perch? this is the thread I've been looking at.Link to thread! thanks in advance.
Check your batter contacts, that exact same thing happend to me a while ago, just clicked loudly, cleaned and tightend contacts, not a problem since.
My ac idler pulley, when the belt is on makes a sh sh sh kind of noise. Could it be a bearing? Don't mean to hijack your post.
I think mine has the same leak, is the size of the oil drop a bit bigger than a quarter?
I'll be changing mine soon, and yeah its probably your alt/fan belt. I'll take some pics when I do it so you can see. Also be carefull with the adjuster bolt, the long one. I snapped the head off mine and just use a crowbar to move it now. Mine slips so bad that when it howls the battery light comes on inside the truck.
The weather here in canada sure loves to cooperate with my plans The truck is parked out side and If i move it it'll get stuck. Hopefully it'll dry out so I can get started again. If I cut a piece of steel for the side and bottem and have the bottom bent to the form and weld those 2 together, would that do the trick? Oh does anyone have the stock rear shocks? Mine broke off and I need temporary replacements. I couldn't get those clips out for the adjustable shocks so I just cut the wire at the shock. These are so shot that I can slide them up and down with my hands. What do i do with those hanging wires?
I have bosche platinums, seems to run just fine, where does it reccomend NGK's?
I'm definitly not getting rid of the truck, its in too good of mechanical condition to part it out. I was thinking that if I can't get a piece of another frame, that I could maybe take off that one coil spring holder thing(whats it called?) and weld in a frame cap. The frame is solid from the lower controls arms down to the front of the truck. How does that sound? I've been thinking about it for a while now in between other stuff dealing with a death in the family.
Yeah Im surprised too, I had a look at them and they're still coated in some kind of rust proofing as is the rest of the frame down to the front of the truck.
How long to you think it'd take to take the rear end frame of another pathy and weld it in on mine? Can I just keep the donor frames panhard rod crossmember mount thing and its upper link mount? Because What else after the lower control arms is attached to the frame?
Money for me is real tight right now, so I can't even afford to buy a parts pathy. Although coincidentally there is an 88 for sale up the road from mine. All I can pay for is the new shocks in the rear and the metal that I bought (3/16 plate) to cut and try to weld in. Edit: One other thing is, you know those metal shrowds that cover part of the roter, those were kinda rotted on each side so I just ripped them off, can you get replacements and are they neccessary?
Sandor, how much did that set you back? Must have been pricey. People keep telling me that I'll never get a safety passed. Man, they sure do like to wreck your dreams these days don't they?
Grinding is the easy part, its the welding in the new thats gonna be hard. I don't know how but I ended up owning 3 angle grinders and never used any of them. I took out the cheapest one today. Is there an easy and cheap way to fix this? Plus there is all that mud and S**t in there that I have to clean out. There was a big pile on the floor today:(
I've seen some pics, but none really compare to the magnitude of mine. Its hard when theres just 2 people lol. I'm trying to get more buddies to help me out.
Just south of ottawa.
The bottom of the frame is in pretty sad shape and some of the sides as well. From after the lower control arm mounts back its kinda bad too. Someone on here suggested a frame cap, Something like this i guess? [___]??
