adamzan
Moderator
Everything posted by adamzan
  1. I only got into offroading recently, before that I was so obsessive about the paintjob (still am) but it all started when i plowed through a snowbank getting onto the highway that was the most fun I've had in so long. Yeah they plowed the highway, but not the on ramp Tree huggers can hang themselves in the trees.
  2. Then again my truck is completly stock. Don't know about jpawela
  3. Mine was doing this and it turned out that my original cat's were clogged AND my o2 sensor is shot. I have a new cat and still running the old 02 (don't have any cash right now) its a bit sluggish on acceleration but once it is on the highway it'll stay locked in OD. How is your gas mileage? I know these aren't great on gas, but you should get at least 320 miles to a tank. Depends on how you drive though. Unplug your o2 sensor and see if it runs any better.
  4. All I can say is that with Co-operators here in Canada (my path isn't in my name) it is 465 a year for my truck. But that's with a second vehicle discount and zero claims ever. If I were to go on my own BASIC coverage would cost me 5600 and with collision it'd be 7200 a year.
  5. Hey guys, just after repairing the two rust holes under my rear seat, I've noticed that on the side where I could see the muffler it is getting somewhat hot under the rear seat. Is there supposed to be some kind of heat shield under there? Or is it nothing to worry about. It isn't like scorching, but it is quite warm to the touch. Also I noticed that when they put my new cat on, it burned off all the under coating in the area. Can I re-undercoat it and not have it come off again, or did they put the cat too close to the body? It was a universal cat fyi. Thanks a lot!
  6. You let dogs in your truck I will never let an animal inside mine, ever. It's looking REAL good mike. Hopefully I'll be down there sometime in the near future and can check it out!
  7. Well I managed to do it, although I was sore after
  8. I was told the best way is to, unless you're not strong enough (no offense), do it with the truck on the ground, so you don't have to do it again after it settles and you don't like the height.
  9. Yup and the adjusters are on the crossmember in the middle of the truck if your looking at it from the side standing up. IIRC you need two 19mm wrenches.
  10. Your torsion bars have sagged, though I think most wd21's were higher in the back anyway. You can adjust them. There is a thread in the garage.
  11. Actually I think the new ones are still C channels.
  12. Ok Ticker, just an FYI. I went today to see how much it would cost to have my rear sway bar link mount welded back onto my frame. They did an inspection of the entire frame, and found no other holes, serious rust, or corrosion. The guy said it would be about half a day's work, at 70 an hour for 280, plus materials and two new stabilizer links, it would be around 330~ ish to get it fixed. Your rust isn't that bad yet. You can definitely find a better place man. I'm sure as hell taking mine in. I do not want to loose the rear end on the highway.
  13. I unplugged mine today and it runs a hell of a lot better but I didn't get a CEL
  14. Well for the belt you could probably use a longer belt for the a/c and attach it to the s/c as well....
  15. adamzan
    Idle speed
    mine is at 750 more like 850 when the a/c is on though.
  16. Do you still have reflective white? I don't see that option.
  17. Well if your frame looks like this: http://www.nissanpathfinders.net/forum/index.php?showtopic=13522&hl= I don't think there are much options. Poor truck
  18. Are the service managers for all dealerships named mike? The one here is too
  19. I'm having a similar issue, where did you find the plug?
  20. I don't think you get what I mean. This is what they were gonna do. Correct me if I'm wrong.
  21. Oh ya the dudes that quoted me a grand, were implying that they were going to actually rebuild the rear frame. As in cut out the old one reuse the cross members but put in new steel rails
  22. You loosen the bolt on the power steering pump, it is behind the pulley, thats why there is a hole in the pulley, you have to line it up. Then there is an assembly on the ps pump to tighten and loosen the belt.
  23. Woah that's intense. Why was he doing that? There was this guy who harassed, abused, beat up, stole from, and god knows what else to my mom. Those months were friggin hell for us. He went to jail, after me and my brother ran to the neighbors and they called the police. After he got out, relatives of his promised us to let us know if he ever came near again. He used to call and leave those kinds of messages as well.... I was like 8 at the time this happened.
