9
Yep its possible.u just need all the parts and time and some electicql work..nothing major tho
also may not be the threads but the "bevel" or "bead" they have called out...it looks a lil big and may not allow you to get good thread engagement and then even still it may not "compress" the flange to get a good seal...the AC lines i've designed usuaylly have a flat side toward the flare nut where you have a seal
I just learned about BSPT vs NPT IIRC BSPT was a 1/8-17 and the NPT was 1/8-18...Teflon tape worked but i woudlnt recommend it to anyone else to try
IIRC 10.8 has the same material properties as grade 8 and 8.8 has the same materials as grade 5
yea some pix would be nice...after my water mud crossing this past weekend nad lack of some power, i'd really like to step up the fan...do u have a controller or is it just on off? b/c too much cooling could be a bad thing
http://www.gulchesorvpark.com/ Basically I want to go this weekend...sat i'm going to cut the slider off the passenger side and reweld...replace compression rod bushings and hopefully make a day run on sunday... I know theres a trail run section but no1 ever responds...i'd like to get at least one truck to go with me
ouch....i woulda checked the shock bolts to see if they were the same and if so i woulda ran shockless up front just to get back to the main road...i'm a big fan of disabling something to enable something more important but glad to see you got it back in mostly one piece
that's probably my problem...mines intermittent...
their A arms seem to be ok...but they do squeak...my turck used to only have the typical nissan crack and pop from up front...but listen to this guy.... the bum bum bum sound at the end is the tires grabbing the rear fenders...i need to do some more trimming
I can't wait to install my new upgrades
unccpathfinder replied to unccpathfinder's topic in General Forums
Got 3 hours of sleep in and we r loaded and hitting the highway -
one side is on and its on good...the other side SUCKS...@!*%tiest flux core i've ever used...it looks like a kindergardener welded it together....i'll be grinding that off and redoing it in the near future if i dont rip it off tomorrow...but i'm going to bed for 2 hours and then we're hitting the road....being up 26 hrs on 3 hrs of sleep the night before SUCKS...almost put the pathy in a concrete wall on the way home b/c i was so tired -
Still welding -
Thanks 87...I basically did the same mounting but on the other side...I like the compressor under the tank since That booger gets hot -
LOL...yea my buddies house so he wanted to show some complience...the Pres is pissed...I wanted to out it at the. End of the drive and take all the wheels and doors off and count down the days on the side...this guy is a mini driving doucher who needs to mind his own business...I could understand if it was the work I did in CA but this wasn't maintainence or repairs...it was upgrades... Next weeks agenda is changing his wife's brake pads in the driveway innothing but a hot pink banana hammock...LOL -
not the safest working environment but it didnt come crashing down as i wailed away with the 4lb sledge -
aight holy @!*%...third efffffing time i've typed this and it didnt post...so this is the bull@!*% version...starting with the bull@!*% first...we wasted an hour relocating the truck to the hot as hell garage (i hoped that dochebag neighbor says something to me someday...he's on his way off of hte board of directors as of monday since he bypassed the president in sending us that letter who is furious over it since we made the truck look like a truck even tho it wasnt' functioning: hope this is my problem: before: after: dont laugh at the welding...i havent welded in about 2 years and this is the first time i've ever used this welder...it got a lot better towards the end but i think that'll do it for now till i can get some gussets: I hope tomorrow hwen the new poly bushings go in it fixed my gangster lean -
Sounds like u got ureself a deal...if u add a couple 0s on the end. -
locker works amazingly...verified with a 2 wheel peal in a gravel lot and turning on dry pavement...i have to replace the ****** regulator from harbor freight (half expected) and sealant...can't believe it didnt set up....but i have bigger problems keeping me from going this weekend...thinking about laying out of work on thurs to try and get her trail worthy...heres the pix from tonight truck is sitting about 2-3" lower on the passenger side so i think the sleeve in the compression rod broke in half...that's also the side that got slammed at URE... rugh rough shaggy: think this is my problem: -
My buddy is gonna get the pickle and oil cleaned off and then when. I get off I'm gonna go over and hopefully get them select up and the tomorrow weld them on -
Diff is out: drilling the carrier: locker built up: ARB almost installed: beaux says this is taking too long and i'm ready to go wheeling already: -
alright some quick pix before i crash...gotta get up at 5 for work and work 12-14 hrs then go work on the truck some more to finish the pneumatic and electrical routings...id still love to get my sliders on too... here's a rough routing from the dash back to the tank: cleaned up: Wrapped: Routing air line: my buddies wifes quote after she got home "where's the toaster oven?": her response...oh ok cool i didnt know that heating it would expand it (we're both engineers so she's learning and actually had a good idea on moving my roller bearings after they fell apart...i'll explain sometime) Open diff: ehhh crap what did we get ourselves into: he's excited about the locker: -
Locker engauges off of shop air...got the rear axle together...gotta bleed the brakes install the wheels and gear oil and electronics but I want to take a test drive to see if she howls -
Good to see you are still around wheelman...keep hour eyes out there are lots of pathys and hbs for sale around the area...at least in upstate sc.... I'm gonna try to upload some pic tonight but I stopped taking them for a while BC I was pressed for time...got home at 2 and was up at 7 for work...probably working till 10 tonight... Kbut pics and text to come....arbitrary instructions suck -
Bad day...locker is in but untested....couldn't leave it on jaxksrandsbc of hoa -
I forgot i did take some pix on my phone to post...so heres some quick shots of the install My necked up work light...50 Halogen fog that i plan to install under the chassis in 4 places as trail spot lights: i'll try to upload more of the routing and bundling pix tomorrow
