RedPath88
Admin
  1. I would think that a Speedo... meter (just sounds wrong without the last part) shops should be able to get those parts, if not the dealer/parts stores. I don't know of to many of them, but there is one in this area (Tacoma Speedometer)
  2. The shop will not honor the warrenty if you use a larger, better quality and better flow cooler? ...find another shop
  3. Replace the studs It's not a common problem so doing that should solve the issue for a long time to come.
  4. RedPath88
    33's
    You want to get a rim that is 15x8 (x8 unless you plan on a 9 or 10in wide rim) with a backspacing of 4.xx (whatever you decide on) they are not "called" anything special. The backspacing is an additional spec of a wheel, but not one commonly refered to in the wheels size. If you bought a 15 x 12.5 in rim then the rim itself would be 12.5in's wide and would be to wide for a 12.5in wide tire. The backspacing does not make the rim wider, it simply designates where in the rims width the mating/mounting surface is located.
  5. Which photo? The one on the left (MiniMe) has 31's while the truck on the right (King CaCa) is on 33's.
  6. Yep, repair manuals pretty much have step by step in them.
  7. Made of Rubber? If so, then Steve... Vsicks has them.
  8. I'll try and dig up a dump run reciet *Check back here for info if I have it* ***hmm, cannot seem to find one, but I'll keep looking***
  9. RedPath88
    stock height
    Yes, I removed everything but the info requested, to limit the size of the pic... Do you need the other info?
  10. RedPath88
    stock height
    You can figure out where it was when stock, using the info below.
  11. I guess it's like anything Nissan... trim levels mean squat!
  12. hmmm, if you mean that only the XE's (early models XE's) had the drums, well my SE has them.
  13. No that price does not include torsion bars. Before you write off a set of tbars, you might try reindexing them first. When you buy new TBars you are only getting replacement bars.
  14. Ok, I was a little off.. thanks
  15. Local wrecking yard for the JCG Coils ($20-maybe $60) Or a local parts store for some new ones.. probably $80-$100+ Call Rough Country directly and order just the Upper control arms for a Nissan HardBody... not the entire HB lift kit, but make sure you get the hardware for the arms (bolts, bushings, etc) Not sure what they are going for right now... $150-$160 shipped to your door?
  16. RedPath88
    Body Lift
    When I replaced me stock shocks I went with longer rears... my truck is currently still stock height Longer rear shocks allow for more downward travel
  17. I can say one thing for sure about that... I know I have
  18. I can't help much on the lights, sorry... perhaps someone with personal experience with those brands can chime in here.
  19. That falls along the same lines as when a friend of mine put a 70's (76 iirc) Celica body one an 80 Toyota 4X4 truck frame. They told him that the bumpers were to high (it would be licensed as a car and thus had to fallow those rules) BUT if he took it to Oregon, licensed it, then brought it back to Washington, then they would license it no problem
  20. Did you get your centerlink from Phil?
  21. Yes 8E From left side of vehicle to right... 8E, 2E, 3E, next two are 4E, then the following two are 6E, and forward a little to 7E
  22. Pic 1: EF & EC 155 Pic2: EL-41 Pic3: EL-86 And this pic is on: EF & EC 15
