47
Everything posted by XPLORx4
If you're installing the AC springs, keep the bumpstops in. I tossed my bumpstops when I installed the airlift bags. Bad move! The airlift bags are completely ineffective with the AC springs installed without bumpstops, and since I don't have my bumpstops, I pretty much don't even use the airlift bags for anything EXCEPT as bumpstops now! And no, after you pull out the factory springs, the bumpstops weren't hard to remove with 13mm socket and a deep extension (as shown below).
Rears: including shocks, less than an hour. Fronts: 2 hours minimum, more like 3. Compressing the springs with those little compressors and an impact wrench takes forever! Don't forget that when you do the rears, you'll need to unbolt the rear brake line bracket and disconnect the diff breather tube from the top of the diff so that they don't overstretch when you get that rear axle dropped. Also, it also helps if you unbolt the rear sway bar brackets so that the sway bar doesn't bind.
How To Improve Sound With Aftermarket Audio System?
XPLORx4 replied to XPLORx4's topic in 96-2004 R50 Pathfinders
No, I haven't even touched the truck since Sunday. I'll probably tinker with it tonight. -
Yikes! I just called a local JLAudio dealer for a quote on that Stealthbox, and it's $549! I don't think I want bass THAT badly... BTW, if I *did* replace the front speakers with components, it doesn't look like aftermarket tweeters will fit in the OEM locations and retain the OEM grille. Thoughts? -
Uh, yeah, you don't need spring compressors for the rear. If you wrangle the right side of the axle downwards and the left side upwards enough to articulate the rear suspension, you can get both springs on easily. You do, however, need compressors for the front. I'm actually thinking about buying professional-quality strut compressor (such as this one), instead of the el-cheapo ones that are operated with an impact wrench. I might, however, go with a middle-of-the-road model, such as this one.
Question About Strut Spacer Installation
XPLORx4 replied to arcano's topic in 96-2004 R50 Pathfinders
There's not really much shearing force on the upper mounts, so I wouldn't worry too much about it. -
No, that is not the correct place to install the spacer. Doing so has damaged the strut mounts (isolators), and they will need to be replaced. The spacer should be placed between the fully-assembed strut and the body. -
On the R50, 4.3's were tuned to put the engine in its powerband when turning 28" (235/70R15) tires. When upsizing to 31" tires with 4.3 gears, the engine doesn't have enough power to keep a steady 70mph cruising speed in overdrive because the RPM's are too low, so the tranny constantly hunts. Add to that the 10% speedometer error, and the perceived fuel economy is even worse! If the engine had a little more HP, the Pathy probably could have been geared higher. In fact, that's probably why 3.5 liter R50's have 4.363 gears instead of 4.636! As tmorgan pointed out, the cheapest and easiest way to regear is to find a used set of diffs at a wrecking yard. You need one of these: and one of these: If you get the front and rear chunks, you don't even need to pay for gear setup. It's a straight remove and replace!
To be honest, I'm totally fine with the power output of the Alpine amp. When I replaced my Bose system last fall, I didn't set out to build a competition sound system, I just wanted: 1) DVD in-dash 2) get rid of the annoying buzzing from one of the OEM speakers and get *slightly* better sound. 3) replacement components HAVE to occupy no more cargo/passenger space than OEM. I mounted the Alpine amp in the cavity that the OEM Bose amp left behind, even using the original brackets. It's a perfect fit. I specifically chose the amp because of its size, so it's staying. 40Wx4 provides satisfactory power for me. The system just needs to have more low end, especially when the volume is at 1/3 to 1/2 of max. Bass response doesn't really seem to even come in until the volume is 2/3 to max. It looks like I may have to compromise on my "can't take up more space than OEM" position. Does anyone have opinions about JL Audio products, specifically this? -
Actually, it's 4 IMPERIAL gallons! lol!
I agree with Alex. It looks like the entire engine, tranny, t-case, diff, and subframe were assembled as a unit, then lifted up into the chassis all at once on the factory assembly line. It's very unlikely that the motor was dropped in from above, as you often see with typical motor swaps.
I measured the height of the cargo tray, and it's about 2-5/8" high. Unfortunately, not enough for that 10" Pioneer sub, which is 3" deep. -
Update: I've re-evaluated the sound of my system, and I think it's actually OK now for not having a sub. While searching for empty cavities to install a sub, I realized that I still had my factory bottle-jack under the rear passenger seat (which I've never used, since I have the hi-lift). After removing the jack, I relocated my tow strap, chain, and snatch-block to that space, which freed up the rear cargo tray under the carpet. So, what I want to know NOW is, what can I put there, and how should I install it? Pioneer 10" Shallow Sub? Since I regularly use the cargo area, I assume I need to keep the lid to the tray, and mount the sub beneath the lid, so it doesn't get damaged by having stuff on top of it. Should I cut or remove the plastic tray bottom so the sub uses the body sheetmetal? Do I need a custom fiberglass enclosure? Dynamat? I would drive the sub using Ch3+4 of the Alpine amp, and drive the rear 6.5" speakers with the HU. Any advice? Pics of sub installations in that tray? Would I be able to hear the sub if the cargo area is full of gear? -
I have. It wasn't easy. The rear bushings are easy enough to pull off, but I had to burn out the front bushings, then cut a channel in the remaining metal collars and use an air-chisel to get them out. The replacement poly bushings are a piece of cake to put in, and they're still squeak-free.
Uh, use the press?
Recovery gear: tow strap, chain, winch remote, snatch block, shackles. Would a sub even do any good in that location if it were covered up by camping gear? -
All right, so let's say that I have to get a sub. I don't need hatch-rattling power, I just want some nicely filled out bass. I really don't want a box in my cargo area taking up space for gear. As I said earlier, what's the point of a sub, if it's never in the truck when I drive it? I'm thinking about the JVC CS-BB2 powered sub. It's pretty compact, and might fit under the driver's seat. If not, it's small enough to attach to a cargo panel above one of the rear fenders and leave permanently attached. Thoughts? -
OK, so this morning, I fixed the speaker polarity issues and disabled the high-pass filter on the amp. The sound is marginally better, but still not that great. There's still hardly any bass at low and mid volumes, and when I crank it up loud, it sounds sorta 'boomy' and hollow. The bass isn't sharp and crisp. I need someone with "tuned ears" and experience with different audio systems to listen, and tell me if I can do any better without a sub. -
I still am using the tweeters in the A-pillars. Actually, they're wired in parallel with the door speakers. (Is that bad?) This evening, I discovered that I had enabled the amp's high-pass filter on the rear speakers. Oops! I also discovered that two of the speakers are wired in reverse phase. Somehow I connected the + speaker wire to the - amp output, and vice-versa. Double oops! This would explain the poor base response. When I have a chance, I'll fix the wiring and see how much that helps. -
I'll try some settings on the HU and verify I set up the amp correctly tonight, and see if it sounds any better. Derrick- Dude, when you move out to SF, help a bro out. Sounds like you know yer stuff. -
I recently replaced the OEM Bose audio system in my R50 with a Kenwood DVD HU, an Alpine MRP-F250 4-channel amp, and 4 Alpine SPS-17C2 6.5" speakers. However, I'm not happy at all with the sound. The clarity and volume are great, but it sounds way to "bright", with almost no low range. My Mazda's OEM Bose system sounds better, richer, fuller sound. I suspect the poor sound is due to the speakers. The first thing many of you may probably say is, "Get a subwoofer." However, I do NOT want to install a sub, which would take up valuable cargo space. The only time I use my Pathy is when it's loaded for hauling cargo or camping, so it doesn't make sense to install a subwoofer, only to remove it whenever I use the truck. Are there other 6.5" speakers that have a better dynamic range (or perhaps can substitute as subwoofers) than the Alpine speakers I have now? Maybe just swapping out the rear speakers? I've looked into compact powered subs such as the JVC CS-BB2 and Kenwood KSC-SW1 on Crutchfield, but I don't think they'll fit under the passenger seat. What about mounting the sub to the roof in the cargo area? Is that too funky? What can you audio-system gurus recommend? Thanks.
In that first pic, it doesn't look like the link is very tightly secured to the strut. Doesn't it make all sorts of clunking sounds like that? BTW, JKS disconnects don't work on the R50. I tried them (click here for my old write-up), but the first time I tried using them, the disconnected swaybar banged around on the CV axles and bent the ABS wire bracket when the wheels were turned and the suspension cycled. Also, the JKS disconnects require frequent lubrication, or they seize. Therefore, I don't recommend them for our application.
Right back at ya! One of the first things I did after I bought the Pathy was to figure out where the intake was.
Whoa. Hydrolock and SE-R in the same thread? Wow! Talk about coincidence! Before I bought the Pathy, I owned a '92 SE-R, which I occasionally drove off-road. (What was I thinking!) Once, I crossed a stream full blast fast (about 30mph), and dontchaknowit, I stalled halfway through the stream crossing. At first I thought I'd merely gotten the ignition system wet, but the engine wouldn't crank... at all. I knew things were bad when, as I was getting tow-strapped out of the water, I put it in 1st gear, let up the clutch, and the front tires skidded. Uh oh... I towed it back home, and pulled the plugs. All were wet. Ooops! After drying off everything and using compressed air to blow out the cylinders, I had it towed to Nissan, saying only "it won't start". And much to my disbelief, Nissan replaced the entire engine under warranty. (The car only had 50K on the odometer) They said that the oil pickup had broken, so it was all covered! Hey, who would complain about that?!? Since then, I've learned to take it easy through water (or at least know where the intake is, to prevent future occurrences!)
I just stumbled on this thread. It's a great idea to have an annual or semi-annual NPORA event. The first one (this year) can be in Annacortes, WA. But, it sounds like many of you can't come and would prefer a location that is more midway between both coasts and planned out a year or so in advance. Moab, UT and Ouray, CO are excellent locales for spectacular scenery mixed with awesome 4-wheeling. If this event were pushed out to, say August or September 2008, and held in Ouray, CO, how many of you would SERIOUSLY commit to attending? (You'll have no excuses, except for maybe if the world runs out of gas by then...) Years ago, there used to be a week-long Xterra-only event known as "GOX" or "Gathering of Xterras" that was held annually in Ouray, CO. And many of you have probably heard about goneMOAB as well, which is open to all Nissans. With enough advance planning, there's no reason why NPORA can't do something like GOX. That sound like what many of you are asking for. Why not start planning it now? It's 18 months away! Is that enough time for you?
