GrimGreg
Everything posted by GrimGreg
  1. I think that oil spraying is a Canadian thing. Never seen it offered here.
  2. Of course, the sensor just has a male tab, and the wire a female clip. And since the boot is obviously long gone, makes it even easier.
  3. To get the snap ring on I had to give it a reach around .... grabbed the CV and pulled it toward the back of the hub, that made the stub shaft stick out far enough to get the thicker one on.
  4. Yeah, can't go wrong with BFG, if you can aford to give up your first born.
  5. Use a deep socket with a long extention and go in from the splash guard. WTF is this wrench crap?
  6. Just follow the wire with your hand and you'll find it. It is a PITA, but not all that hard. Nissan actually gave us a spark plug tool made specifically to get to that plug. Should be in the kit with the stock lug wrench. Otherwise you need a 6" extention, a swivel, a ratchet and a plug socket (a second extention would also help).
  7. You think right. That is why theives are cutting them off any car they can.
  8. That's the company that makes the ladder rack I have on my van , if the basket is like those, then it is simple and solid.
  9. I have never seen a high flow that is a "bolt in", most just have stub pipes at either end so they can be used on anything. As for the tranny, I would hope the shop would at least use the proper type of ATF, the Nissan type isn't the only one that will work properly, though most brands aren't fully compatable.
  10. Yeah, because they search our forum looking for people comming out there. The place I go here searches your toolbox and if you look like you are attempting to hide something they might question you. How's this, keep the receipt with you and take your tool box in. When they search it on the way out say, "yeah I bought those here last week and forgot to take them out of the box," and show them the receipt.
  11. Yeah, but the one you pictured looks similar to Surco Baskets which run around $250 and up without mounting hardware. The Coleman/Sportrack one is similar in style to the Yalima Load Warrior. There are tons of options out there, it is just weeding through which ones are worth what they are charging for them, and how much you are really gonna use it.
  12. Here is when they said "oh it was just a bad batch" ....B.S. http://www.procomptires.com/news/web_news.htm
  13. Wasn't me, I won't go near them. Here is one story from a search: http://www.toyotanation.com/forum/showthread.php?t=53548 and I remember the same thing happening to a Frontier owner a while back, and in responce to his there were other similar stories that came to light.
  14. If it is a U-pull-it type place, just wear some cargo pants and fill your pockets.
  15. Yep, there is a piece that is held on the axel stub by a snap ring. That is the part that actually locks in when you lock them.
  16. Most all baskets made to fit on an existing rack come with hardware to clamp onto the cross bars of the rack. I bought my Coleman basket on clearance at Target for $99. On my 88's stock rack:
  17. Yeah, because they are crap and fall apart without warning.
  18. My wife's former 94 D-21 had factory triple guages under the radio. You might be able to get a set of those for your's?
  19. Yep, the rear arm bushings are a common cause of our trucks being squirrelly.
  20. No, there is no "click", all is well there. Just keep the pointer pointed to the right position and it should stay put.
  21. I carried 20, 16' 2x6s on my Thule once, the bars bowed a little but handled the weight just fine. I think they are rated at 250lbs/bar IIRC, but that is the "recommended" limit, you know they never put the true max rating on things. There are no rails, they clamp to the rain gutters under your doors, and have feet that rest on the edge of the roof to distribute the weight.
  22. 88+ have a 4speed non OD final gear, 90+ have a 4speed with OD final gear. Same exact tranny, just different electronics and gears in it. All the 88+ VG V6s had the RE4R01A automatic tranny, and they can be cross swapped, but they aren't all the same. They will fit the 87s also, but require the tranny ECU to be swapped(which is not in the tranny BTW) because they used a L3N71B. 2wd models used a 4 speed variant of that, the E4N71B until 89, in 90 they started using the RE4R01A also. If your 89 had lockup and OD then it was a late 89 build and one of those weird inbetween models like we were talking about earlier this week in POHO. Or it could be that a PO replaced your TC or tranny at some point before.
  23. Well, the VG30I has a Throttle Body Injection system, basically it is just a pair of injectors firing into the intake. The throttle body unit does resemble a carb in looks, but that is about it.
