hastifc Posted November 1, 2005 Share Posted November 1, 2005 will a header mfg'd for a 90 v6fit an 89v6? not scared of a little fab. should, right? Link to comment Share on other sites More sharing options...
Vsicks Pathy Posted November 2, 2005 Share Posted November 2, 2005 I guess so, but it's just a guess. Link to comment Share on other sites More sharing options...
Vsicks Pathy Posted November 2, 2005 Share Posted November 2, 2005 Good to see that out of the 21 views to this post (as of this writing) no one was willing to offer up any help, suggestions, knowledge or ideas. In fact 90+% of topics have not been added to all f*cking day. Is this site just for voyers now? CRAP! Link to comment Share on other sites More sharing options...
Simon Posted November 2, 2005 Share Posted November 2, 2005 Geez V6!!!! Maybe no one is sure, and doesn't want to offer up the incorrect information. Relax man! Have a or 12! Link to comment Share on other sites More sharing options...
hastifc Posted November 2, 2005 Author Share Posted November 2, 2005 vsicks, i appreciate your candid response guess i'll never know.... might as well spend the money and find out for myself. Link to comment Share on other sites More sharing options...
Revco Posted November 2, 2005 Share Posted November 2, 2005 I would add that if the manufacturer's application notes do not mention the year, it's likely that it will not work for some reason. In the case of headers, it could be due to a different bolt pattern, intake arrangement, not enough room, or simply that "too much" customization is needed to get them to go in. I would note that Throley makes two separate types of headers - one for '86-'89 & one for '90-'95. Pace Setter has a similar setup. They're doing this for a reason. Unfortunately I don't have a FSM for pre-90's 'Finders, so I can't say for sure about specific differences. Link to comment Share on other sites More sharing options...
SC88Pathy Posted November 2, 2005 Share Posted November 2, 2005 I'm sure it has something to do with the differences in the VG30E and VG30I engines, there are definatly some major differences in the intakes between the two so I would assume that would lead to differences in the exhausts of the two. Link to comment Share on other sites More sharing options...
Precise1 Posted November 2, 2005 Share Posted November 2, 2005 I guess so, but it's just a guess. Well V6, if I can't elaborate or I have no idea , I generally don't post. Seeing as you had already covered the "I don't know" side of things, I figured I'd leave it to the people who did. Seems to me the answer is "No, probably not easily. Better just buy the right year" from the replies... B Link to comment Share on other sites More sharing options...
nige Posted November 3, 2005 Share Posted November 3, 2005 will a header mfg'd for a 90 v6fit an 89v6? not scared of a little fab. should, right? why not get headers for an 89? Because judging by this page, which was painstakingly scanned by 88pathoffroad, says they are different part numbers. I can't tell you the exact difference, but I assume they are not the same. Why bother with fabbing when you can buy what fits. This place was good when I bought my set: Rocky Road I got my thorley headers for 329 bucks. If they don't have them in stock, call the factory because they aren't a popular product to keep stocked all the time. The factory will usually have them stocked so just ask the retailer to do a drop shipment to your place from the factory. That's what I did. There are other places to buy them, and there is also pacesetter brand headers availible for your engine. Do a search as it's a popular topic around here. Link to comment Share on other sites More sharing options...
Revco Posted November 3, 2005 Share Posted November 3, 2005 There's another discussion brewing at the moment about doing an engine swap between the old & new styles. Lgranch noted that the manifolds are different between the two - though specific details were not provided. Read about it here: Differences Between Blocks Link to comment Share on other sites More sharing options...
88pathoffroad Posted November 6, 2005 Share Posted November 6, 2005 The exhaust manifolds are different because they changed the locations of the EGR tube bung and added an O2 sensor bung, I do believe. Link to comment Share on other sites More sharing options...
Trainman Posted November 6, 2005 Share Posted November 6, 2005 I guess so, but it's just a guess. Good to see that out of the 21 views to this post (as of this writing) no one was willing to offer up any help, suggestions, knowledge or ideas. In fact 90+% of topics have not been added to all f*cking day. Is this site just for voyers now? CRAP! I only post when I think my answer might actualy be helpfull (I know some are not, but that is another thing ). I try not to "guess" as quite often guessing can lead to an expensive wrong result. And it appeasr that may be the case here Link to comment Share on other sites More sharing options...
CT Pathy Posted November 22, 2005 Share Posted November 22, 2005 The headers will not fit easily as the 90+ pathys have a flange on them and the bend is different and this will hit the frame crossmember that is different on the 90 and up. It is much farther forward,so unless you are good at bending and welding I would suggest you find a set made for an 89( how do I know this, because I had the same problem and bought the 90+ header anyway as a last resort....It didnt work) Hope you get the message in enough time. Link to comment Share on other sites More sharing options...
hastifc Posted November 22, 2005 Author Share Posted November 22, 2005 The headers will not fit easily as the 90+ pathys have a flange on them and the bend is different and this will hit the frame crossmember that is different on the 90 and up. It is much farther forward,so unless you are good at bending and welding I would suggest you find a set made for an 89( how do I know this, because I had the same problem and bought the 90+ header anyway as a last resort....It didnt work) Hope you get the message in enough time. thx, ct pathy, i appreciate that. got the right ones finally Link to comment Share on other sites More sharing options...
