warn premium manual hubs
neri33
hello all, i saw the procedure to change from automatic to manual locking hubs,
but what's up with the lock washer?.
for the automatic this lock washer is on inside slot, for manual, it is necesary?
i changed automatic to manual locking hubs but the mechanic put the washer on outside slot, it is correct?
thanks
Guest 89PATHFINDER_SEV6
I plan on doing the conversion this week. Where can I find the how to on the web? I promise this time I will read the instructions first.
Thanks in advance!
:beer:
Tom
  • 1 year later...
If no1 chimes in PM 88Pathoffroad may know but by searching around you will find it...I think its 33 but as long as you give them the year you will get the right ones...Make sure to replace the studs with ones not provided by warn I used regular grade 8 bolts (not from lowes or home depot)
  • 1 month later...
