neri33 Posted October 3, 2005 Share Posted October 3, 2005 hello all, i saw the procedure to change from automatic to manual locking hubs, but what's up with the lock washer?. for the automatic this lock washer is on inside slot, for manual, it is necesary? i changed automatic to manual locking hubs but the mechanic put the washer on outside slot, it is correct? thanks Link to comment Share on other sites More sharing options...
Filthy Luker Posted October 3, 2005 Share Posted October 3, 2005 Yes it is correct. Link to comment Share on other sites More sharing options...
Guest 89PATHFINDER_SEV6 Posted October 10, 2005 Share Posted October 10, 2005 I plan on doing the conversion this week. Where can I find the how to on the web? I promise this time I will read the instructions first. Thanks in advance! Tom Link to comment Share on other sites More sharing options...
neri33 Posted October 12, 2005 Author Share Posted October 12, 2005 I plan on doing the conversion this week. Where can I find the how to on the web? I promise this time I will read the instructions first. Thanks in advance! Tom installing warm premium manual hubs this is the link Link to comment Share on other sites More sharing options...
exploited789 Posted September 27, 2007 Share Posted September 27, 2007 anyone know how many splines we have so i can buy the correct ones? Link to comment Share on other sites More sharing options...
unccpathfinder Posted September 28, 2007 Share Posted September 28, 2007 If no1 chimes in PM 88Pathoffroad may know but by searching around you will find it...I think its 33 but as long as you give them the year you will get the right ones...Make sure to replace the studs with ones not provided by warn I used regular grade 8 bolts (not from lowes or home depot) Link to comment Share on other sites More sharing options...
88pathoffroad Posted September 28, 2007 Share Posted September 28, 2007 WD21 87-89 V6 with the H233B/R200A combo has 27 spline CV axles, 4-cyl with the C200/R180 combo has 28 IIRC. The rear diff in an 00-up (IIRC) R50 has 33 splines... 31 on the rear diff for 87-95's. Link to comment Share on other sites More sharing options...
TerranoNZ Posted September 28, 2007 Share Posted September 28, 2007 So much misinformation out there (Internet) 91 Pathfinder hub spline count Summit=31 Automotive Accessories Connection Inc=28 for both 4cyl and 6 WTF? AutoParts Warehouse=31 Link to comment Share on other sites More sharing options...
TerranoNZ Posted September 28, 2007 Share Posted September 28, 2007 Well I just went out and counted mine...... 28 See (Mines a 1991) So will these fit? http://store.summitracing.com/partdetail.asp?part=SPW-400543 Even though they fit Dodge/Mitsubishi, Ram 50/Mighty Max/Montero Link to comment Share on other sites More sharing options...
Simon Posted September 28, 2007 Share Posted September 28, 2007 According to Warn's site. pre '90 = Part # 28739 Post '90 - 2004 = Part # 29091 Link to comment Share on other sites More sharing options...
exploited789 Posted November 23, 2007 Share Posted November 23, 2007 can anyone copy and paste the installation directions from http://wd21forums.damagedreality.com/phpbb...wtopic.php?t=21 it wont load Link to comment Share on other sites More sharing options...
RedPath88 Posted November 23, 2007 Share Posted November 23, 2007 The WD21Forums are long gone... "maybe" '88 has them saved somewhere.. but I doubt it but why not give this one a try http://www.nissanpathfinders.net/forum/index.php?showtopic=1405 Link to comment Share on other sites More sharing options...
GrimGreg Posted December 5, 2007 Share Posted December 5, 2007 If you can find them, a set of manual hubs from a 4cyl HB will be the best/strongest you can buy. Link to comment Share on other sites More sharing options...
