adamzan Posted August 13, 2014 Share Posted August 13, 2014 I want to add a pressure gauge to my rig, but i really, really, don't want to mess with the stock idiot light sender, as it is quite tight in there with the headers already. So I found my relocation kit I never installed on my old truck and noticed it has a spot in the centre where it looks like you could drill for a sender. I found a pic showing Tex's install and he did something similar. Just wanted some thoughts on it. I know I would have to drill it straight in a drill press and tap it to 1/8 NPT for the sender... Link to comment Share on other sites More sharing options...
ferrariowner123 Posted August 13, 2014 Share Posted August 13, 2014 What lines are you planning on running? If its AN, you can just get one of these (one on the far right) http://www.redhorseperformance.com/collections/adapters-pressure It will adapt the NPT to AN size and give you what i'd assume is an 1/8 NPT threaded port which everyone but GReddy uses for pressure sensor sizes. Or you can get what i'm going to try and make work, which is one these ebay oil sandwich adapters http://www.ebay.com/itm/UNIVERSAL-BLUE-ALUMINUM-OIL-FILTER-COOLER-SANWICH-PLATE-ADAPTER-M20-M22-X1-5-/331197008951?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d1ce14c37&vxp=mtr It just sits between the filter and the engine, and mine gives three 1/8npt holes for sensors, BUT the stupid PS arm gets in the way by .00000000000000001 mm and prevents it from threading on smoothly to a VG33. So some modifying was necessary, but being as i didn't have an angle grinder, that project got sent to the back burner. Hope that helps.... -Kyle Link to comment Share on other sites More sharing options...
ahardb0dy Posted August 13, 2014 Share Posted August 13, 2014 I like that first fitting pretty cool idea ! Link to comment Share on other sites More sharing options...
ferrariowner123 Posted August 13, 2014 Share Posted August 13, 2014 Yeah, I'd recommend that for pressure but not temp, usually (from what I'm told,) you want a temp sensor closer to the engine pumping for oil I guess... Idk But AN Is EXPENSIVE! my planned oil relocation setup alone is pushing $250, $100 of that alone is XRP -10 hose... Hence back burner project. Lol -Kyle Link to comment Share on other sites More sharing options...
adamzan Posted August 13, 2014 Author Share Posted August 13, 2014 (edited) What lines are you planning on running? If its AN, you can just get one of these (one on the far right) http://www.redhorseperformance.com/collections/adapters-pressure It will adapt the NPT to AN size and give you what i'd assume is an 1/8 NPT threaded port which everyone but GReddy uses for pressure sensor sizes. Or you can get what i'm going to try and make work, which is one these ebay oil sandwich adapters http://www.ebay.com/itm/UNIVERSAL-BLUE-ALUMINUM-OIL-FILTER-COOLER-SANWICH-PLATE-ADAPTER-M20-M22-X1-5-/331197008951?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d1ce14c37&vxp=mtr It just sits between the filter and the engine, and mine gives three 1/8npt holes for sensors, BUT the stupid PS arm gets in the way by .00000000000000001 mm and prevents it from threading on smoothly to a VG33. So some modifying was necessary, but being as i didn't have an angle grinder, that project got sent to the back burner. Hope that helps.... -Kyle The kit came with 30" hoses, with NPT fittings at each end, I will probably just use those to keep it simple. But you have given me the idea to get a T for one end so I don't have to drill anything, which would be nice. I was looking today at lunchtime at PA, they have in the hydraulic section a ton of fittings. Found at T that has 2 female and 1 male 1/2" npt ports. I would still need a 1/2 to 1/8 or 1/4 (the autometer gauges come with an 1/8 to 1/4 bushing) adapter though. Just adding more places to leak That sandwich plate won't work on the wd21, as the vg30 uses a 3/4-16 thread for the oil filter (weird, right?). I'm sure there are others, though. AN looks real nice but damn, kind of out of my price range at this point Edited August 13, 2014 by adamzan Link to comment Share on other sites More sharing options...
ahardb0dy Posted August 13, 2014 Share Posted August 13, 2014 I bought the lines and AN fittings for when I was going to use the relocation kit on the former pathfinder, I Bought the push on fittings and hose from Summit, Link to comment Share on other sites More sharing options...
Nefarious Posted August 13, 2014 Share Posted August 13, 2014 Another reason you need a vg33e swap! The front mounted oil filter bracket has an extra set screw in the housing you can remove for an extra oil feed watch out with those sandwich adapters. Most give you unfiltered oil. Not the biggest deal for a gauge but I wouldn't supply something like a turbo with it. Link to comment Share on other sites More sharing options...
ahardb0dy Posted August 14, 2014 Share Posted August 14, 2014 Back on Adam's topic, So if someone else did this already what's the problem??? LOL JUST DO IT !!! 1 Link to comment Share on other sites More sharing options...
SpecialWarr Posted August 18, 2014 Share Posted August 18, 2014 And let me know how it goes so I can install my AutoMeter Oil Pressure gage!!! LOL! Link to comment Share on other sites More sharing options...
tmoore4512 Posted June 6, 2015 Share Posted June 6, 2015 Found this topic and am thinking I may go sandwich similar...relocating my oil filter anyway, and the kit comes setup with an NPT sender port...or oil feed for the turbo I will never have.I think I am more excited about not having il pour all over my dang starter than I am the oil pressure gauge...those things are not cheap. Link to comment Share on other sites More sharing options...
adamzan Posted June 7, 2015 Author Share Posted June 7, 2015 Never had a problem with the whole oil/starter thing. Also, I've still not done anything on this, LOL. Pretty busy these days and time to work on the truck is at a premium. Link to comment Share on other sites More sharing options...
RedPath88 Posted June 8, 2015 Share Posted June 8, 2015 Found this topic and am thinking I may go sandwich similar...relocating my oil filter anyway, and the kit comes setup with an NPT sender port...or oil feed for the turbo I will never have. I think I am more excited about not having il pour all over my dang starter than I am the oil pressure gauge...those things are not cheap. I've cut back on adding it at Subway the past few years. Link to comment Share on other sites More sharing options...
tmoore4512 Posted July 12, 2015 Share Posted July 12, 2015 Well... I cut flour and sugar from my diet...no bread...no sugar...4 months later I am down 37 lbs...feel pretty dang good.But I miss eating sweets haha.Back on topic...I ordered a sandwich adapter for my Autometer sender...and a Summit relo kit...will photograph and post when I get it in... Link to comment Share on other sites More sharing options...
Precise1 Posted July 12, 2015 Share Posted July 12, 2015 Fatass!! Bread is ok if it is in limited quantities and isn't enriched, bleached flour. Try a dark rye or German/French country bread... But yeah, sugar is the debil. Seems overkill when you can just drill/tap the relo kit, but it is your $. B Link to comment Share on other sites More sharing options...
tmoore4512 Posted July 12, 2015 Share Posted July 12, 2015 Yes, I had gained a bunch when I was lifting heavy, but did not change my diet when I stopped hitting the weights as hard.I agree on drill/tap the relo plate, but I scored the sandwich plate for next to nothing with free shipping. So if in the end it does not work, then I will just toss it in the spare part bin and mod the relo... Link to comment Share on other sites More sharing options...
tmoore4512 Posted August 14, 2015 Share Posted August 14, 2015 Okay guys...question:After looking at the room situation with the oil sending unit and a subway sandwich adapter along with my relo-kit...So the factory oil sending unit is simply an "idiot light switch" based on what I can see...I cannot confirm that the ECU actually takes a "reading" from this one wire, so unless I am missing something (which is possible)...why not just put the new Autometer oil pressure sending unit in place of the factory? Thoughts? Link to comment Share on other sites More sharing options...
Kingman Posted August 14, 2015 Share Posted August 14, 2015 ECU does not take a reading. And it is just a dummy light, only the '86.5-87s had an actual pressure gauge. I have an Autometer sending unit in the factory spot. 1 Link to comment Share on other sites More sharing options...
ferrariowner123 Posted August 14, 2015 Share Posted August 14, 2015 Same too on the R50's right? It just triggers the gauges on the dash when the resistance is met? -Kyle Link to comment Share on other sites More sharing options...
tmoore4512 Posted August 14, 2015 Share Posted August 14, 2015 Yes, I believe this to be the case...essentially when motor is running and you ground that wire the light on dash comes on. So out it goes!!!!Woo Hoo! Link to comment Share on other sites More sharing options...
Precise1 Posted August 14, 2015 Share Posted August 14, 2015 Yep, and a buddy of mine just ate his top end driving across Nevada when the oil filter relocator adapter loosened and leaked. Idiot light never came on, but he noticed a leak when he stopped for gas. Pulled the relo kit off, put a filter on, topped it off, drove to Colorado and did an oil change, and another, and another. He described it as 'panning for steel'. "New cams, lifters, rocker arms, and bottom end bearings. She runs great once again." Mind you, it never stopped, lost power (how would you tell) or knocked, he just started looking for the missing chunks... Yeah, screw idiot lights, if you want to know what is going on, install gauges; oil pressure, volt meter at minimum, tranny temp if it applies. Why don't cars come with them new? From the factory, it is a few hundred bucks max and incorporated. No excuses, my '84 D720 had them... B Link to comment Share on other sites More sharing options...
tmoore4512 Posted August 15, 2015 Share Posted August 15, 2015 I concur...completely.It makes no sense to delete the gauge and add a light that NEVER comes on... Link to comment Share on other sites More sharing options...
